Old Oct 17, 2009, 06:08 PM
yellowblue is offline
Find More Posts by yellowblue
yellowblue's Avatar
west yorks. UK..Home of the Hudds mafia
Joined Apr 2006
Foils for 60" planks in Light air
Ok today we had the 60" EPP Nats...wind was light to nothing. Some toys flew/coped better than others.... so there is a big need for a new toy to handle these conditions.....This would be a homebrew toy not a commercial one
I would like to pick your brains on what would be a good foil for 60" flying wing (plank'ish format).
I've used MH64 in the past for light air, an was wondering if any of you have found anything better.
Thanks in advance Brian
yellowblue is offline Find More Posts by yellowblue
Old Oct 17, 2009, 06:17 PM
ZIPPER is offline
Find More Posts by ZIPPER
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
Pw51
ZIPPER is offline Find More Posts by ZIPPER
Old Oct 17, 2009, 06:24 PM
yellowblue's Avatar
Joined Apr 2006
Originally Posted by ZIPPER
Pw51
I've used that a lot, it seems to prefer a bit of a blow
Old Oct 17, 2009, 07:26 PM
alkoo is offline
Find More Posts by alkoo
speedfreek
alkoo's Avatar
Newcastle, Australia
Joined Apr 2003
PW75?
From recollection, Peter Wick designed it for lighter air.
Maybe Peter can chime in here.
Waz
alkoo is offline Find More Posts by alkoo
Old Oct 18, 2009, 05:10 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
There was another one (p1121?) that I think he designed for a DLG plank - worth a try?
S
Shedofdread is offline Find More Posts by Shedofdread
Old Oct 18, 2009, 10:23 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
From the PW site: "PW106: mainly for more thermal oriented slope flying"
http://www.b2streamlines.com/PWairfoils.html
Are we speaking of the traditional taped / film covered EPP wing construction technique? If so, then IMHO, the achievable building tolerances will most likely exceed the differences between many of these similar airfoils.
DT56 is offline Find More Posts by DT56
Old Oct 18, 2009, 12:19 PM
Geode is offline
Find More Posts by Geode
Geode's Avatar
San Jose, CA
Joined Jan 2007
A few case studies for your reference:
Birdwing (PW1211) - http://www.rcgroups.com/forums/showthread.php?t=746520
Composite Manta (AG modified) - http://www.rcgroups.com/forums/showt...5#post12434074
EPP Manta (PW51 thinned) - http://www.rcgroups.com/forums/showthread.php?t=1071157
Also, checkout my blog for other flying wings - http://www.rcgroups.com/forums/member.php?u=133609
Geode
Geode is offline Find More Posts by Geode
Old Oct 18, 2009, 12:51 PM
ENGINETORQUE is offline
Find More Posts by ENGINETORQUE
ENGINETORQUE's Avatar
United Kingdom
Joined Feb 2005
It's probably less about the section (i.e. use one of the recognised sections that 'works' - PW51 or whatever...) and more about wing loading allied to something that doesn't resemble a bag of washing wrapped in parcel tape and weighing as much as a small car....!
Light winds need light models - something that 60" has been steered away from!
ENGINETORQUE is offline Find More Posts by ENGINETORQUE
Old Oct 18, 2009, 01:10 PM
skirmish is offline
Find More Posts by skirmish
skirmish's Avatar
West Yorkshire, UK
Joined Dec 2004
You're right that light winds need light models but the standard EPP60 model has evolved into an object to cope as well as possible with a wide range of conditions in which to fly. Most, I think do pretty well with this and i think it has to be healthy for the class that as few models as possible are needed to successfully and enjoyably compete without breaking the bank.
It was noticable though how many folk did have problems struggling with heavier models in light lift - some even used ballast! Very careful smooth flying is also a big factor in keeping aloft and those who are good at that seemed to be rewarded.
Having said that the wind speed for the final was extremely low and no one would normally have wanted to fly in that let alone race!
It's good though that new requirements bring new ideas and developments.
skirmish is offline Find More Posts by skirmish
Old Oct 18, 2009, 02:47 PM
Peter Wick is offline
Find More Posts by Peter Wick
Kopenhagen
Joined Apr 2005
Hej
I would go for a PW1211 with more camber or JWL 065 section.
Yours Peter
Peter Wick is offline Find More Posts by Peter Wick
Old Oct 18, 2009, 05:28 PM
yellowblue's Avatar
Joined Apr 2006
Originally Posted by Peter Wick
Hej
Yours Peter
Thanks for your input Peter, was looking at various foils of yours...wanted to find out what others are using before putting wire to foam.
As Skirmish said, wind was bad, with some sink coming through at times, in some heats paper bags wouldn't fly.
Enginetorque...not bags of washing these days...nice smooth and slick what with the "New Stuff" an yes they can be light, even for a 60" plank...One of mine that was lost in the fire had a loading of 7oz/ft.
Thanks for all your input guys, just trying to move on with the development of our planks. I have some light weight EPP on order, as soon as it arrives I'll be off to the Timinator to burn some foam on his new CNC toy
Old Oct 19, 2009, 05:08 AM
United Kingdom
Joined Feb 2005
You need a light one and a heavy one - the rules allow a model change presumably ?
Cost isnt' really a factor - two servos, a chunk of foam and a receiver - how cheap is that!
Old Oct 19, 2009, 10:28 AM
rumbey is offline
Find More Posts by rumbey
Speed is Good!
rumbey's Avatar
Chippenham, Wilts
Joined Oct 2005
My mistake apart from Paul putting pressure me on was slowing my S-15 up too much in the final. I should have just kept her flying the same as the previous 9 legs....Resulted in stalling it in
The S-15 profile does seem to suit light conditions and is normally good up to 20mph
Also I thought my s15 was lighter BUT its 32.4oz nearly 8oz heavier than Paul Townsends homebrew
rumbey is offline Find More Posts by rumbey
Old Oct 19, 2009, 12:14 PM
phamiltonsmith is offline
Find More Posts by phamiltonsmith
New Orleans, LA
Joined Nov 2004
have a look at Don Ayres (sp?) foils...
I fky at 3000 m altitude and have used his 8% thk, 2% camber foil with great success...
Paul
phamiltonsmith is offline Find More Posts by phamiltonsmith
Old Oct 19, 2009, 12:23 PM
atjurhs is offline
Find More Posts by atjurhs
agony sweetns the victory
atjurhs's Avatar
Any Flying Field Across America
Joined Jul 2005
I've used the PW106 airfoil on a 48 inch wing and it works well, but over time my model has gotten heavier and so more air/lift is required.
From my experience, I do think it's a combo of wingloading and airfoil.
I think I'll check out the PW1211 for the new version of my light sloper....
atjurhs is offline Find More Posts by atjurhs
Discussion Key rig set up to make boom wing in light air A.B. Sailboats 9 Aug 11, 2009 11:41 AM
Rave The Golden wing is a 60" forward swept wing for thermal/light air slope. kylekroker Flying Wings 47 Oct 17, 2008 10:37 PM
Video extreme in light air,daxanator prplgoat Sailplane Talk 2 Jun 02, 2007 04:24 PM
Another great day in light air! RCFlybry Slope 14 Aug 03, 2005 10:22 AM
For Sale: New in Box TSK Acrostar 60 CCPM robdoyle Aircraft - Electric - Helis (FS/W) 0 Apr 17, 2002 11:16 AM
