Mine takes off fine from short grass ... long thick grass of course would not work.
It is a light airframe, so given enough power it's perfectly suited for grass takeoffs. The flyfly struts are marginal @ 8lbs, I use tams retracts which are strong, but at some point I might have to replace the struts with something more durable. But for now they works, so I keep them on. I have no wrinkles on the aluminum foil (or aluminum monokote) because my F-86 airframe is fully glassed. So the foam it has a thick rigid shell, just like a composite airframe. I think it's pointless to put an alu finish on bare foam, it will indeed wrinkle where the foam bends. I don't use epoxy for gluing except in a few places that require it, most of gluing was done with lightweight PU if you read the thread, http://www.rcgroups.com/forums/showp...5&postcount=14. Also, I don't use polycrylic, it's a waste of time, http://www.rcgroups.com/forums/showp...2&postcount=16 |
Latest blog entry: BAe Hawk 90mm EDF
Yes ... good luck with the z-poxy, it should work well
I didn't find z-poxy at my local HS, so I picked up something called "Finishing Epoxy". Its called a 20 minute epoxy, and it is very clear and shiney.
I put a coat of it on one intake duct on my mig-29. I thinned it with alchohol so it was watery. Here is what I noticed: It gets tacky quick. It needs lots of heat to cure It is hard to get on there "Even" enough. With sanding it makes a good under layer for the paint. Much stronger than PU but not much more weight. I question how hard it would be do to fiberglass with the takckyness, it would pull on the fiberglass while scraping. Question: Have you ever used the z-poxy as a "top coat" for the paint? I think the gloss and paint protection would be great if I could figure out how to brush it on even. I don't think an airbrush would work, but maybe what I got is not the same as the z-poxy. While from a distance it would look fine, clearly there are brush strokes and places where it "builds up" more than others. This is what I have here: http://www.amainhobbies.com/product_...=Product-Feeds |
http://www3.towerhobbies.com/cgi-bin...poxy&search=Go http://www.hobbypeople.net/guru/hps_962692589.asp The fast cure (30min, 5 min) epoxies get increasingly softer and more rubbery ... For laminating you need some hard shell stuff. That usually is rather slow cure I think ? Besides Z-Poxy there might be other laminating epoxies like that (I would guess west marine has a west system laminating epoxy). |
Yes the West system stuff is probably a much cheaper substitute to the Z-Poxy for higher volume JePe Fast Foam work
No as far as I know. What Chris uses is a two part epoxy based paint w/o harsh solvents.
I have used acrylics such as Future or any brushable clearcoat such as varathane pu or polycrylic, or testors clearcoat in an airbrush. The problem with some (actually most) spray paints or spray clearcoats is the solvent in the aircan version. Also most Tamiya acrylics in a can are foam safe, most Testors are not (different solvents used). You need to test them first !! So the best way to find out is to take your can and spray on a piece of bare white foam ... Not the plane ... That is what I always do. |
JePe has a new page specifically on how to finish foam; he discusses in some detail the pros and cons of both water-based and epoxy products. A very good reference.
The only drawback is that I have no idea at the moment what some of the correspoding products might be in the US, e.g. the water based acrylic primer sounds interesting. http://jepe.org/finishing%20foam/finishing%20foam.htm Here is my own conversion to pdf: . |
| Thread Tools | |
| Discussion large F-86 Sabre,any clue who makes it? | MustangAce17 | Electric Ducted Fan Jet Talk | 12 | Dec 20, 2007 09:47 PM |
| Question Which large, non-foamie F-86? (was: Retracts on K&A F-86 Sabre?) | surfimp | Electric Ducted Fan Jet Talk | 99 | Jul 20, 2007 10:40 PM |
| F-86 Sabre - My first EDF project | BQuick | Electric Ducted Fan Jet Talk | 5 | Sep 27, 2004 06:54 AM |
| F-86 Sabre jet video! | pohlmeyr | Electric Ducted Fan Jet Talk | 17 | Jan 13, 2002 09:35 AM |
