This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Dec 12, 2009, 06:03 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
It has been raining here now for three days in a row ... good time to get some more painting done on the Sabre ...
Herb is offline Find More Posts by Herb
Old Dec 12, 2009, 11:56 PM
kaon is offline
Find More Posts by kaon
Joined Aug 2008
Nice paint. Here's what I ended up with last night, using regular spray paint. doh!
kaon is offline Find More Posts by kaon
Old Dec 13, 2009, 12:06 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
It looks like you are using some foam friendly (water based) paint??
I would try first sealing the foam, using some water based Varathane or Polycrylic or whatever you have at hand (light or white color preferred).
And then add the read paint ... otherwise the red will just soak in the foam.
Edit: Oh no, I think I see the foam being eaten by the paint
Then you need to get some red devil or similar interior lightweight spackle and close all the holes. After that, paint it with a water based paint (eg krylon h2o I think).
Old Dec 15, 2009, 05:47 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Over the weekend I was able to do a little bit of work on the paint & finish - which is taking forever
I made templates for the fuse sides, and then applied the aluminum paneling. Same thing on the wing.
Old Dec 15, 2009, 05:50 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
More work needs to be done to finish up the intake, and join the intake tube to the lip.
Old Dec 15, 2009, 05:54 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Next I will have to custom make the decals using monocote, cut out all the lettering one by one Maybe after the maiden ...
Old Dec 15, 2009, 08:52 PM
MYC is offline
MYC
Find More Posts by MYC
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
I know its a lot of work Herb, but that bird is looking sharp! Keep at it, the plane is coming out beautifully!
MYC is offline Find More Posts by MYC
Old Dec 16, 2009, 04:00 AM
ParkJeff is online now
Find More Posts by ParkJeff
Birds do it, bees do it
ParkJeff's Avatar
Australia, WA, Perth
Joined Feb 2003
Herb,
Could you tell us what you used for the aluminium paneling? It looks great!
Jeff
ParkJeff is online now Find More Posts by ParkJeff
Old Dec 17, 2009, 08:55 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Thanks for the comments ...
These foam flyfly jets really have potential, they are very well made for what they cost. Already thinking about my next one .
Old Dec 17, 2009, 09:00 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by ParkJeff View Post
Herb, Could you tell us what you used for the aluminium paneling? It looks great! Jeff
I used the Monokote trim sheets, which I used before on a T-33 with great results:
http://www.monokote.com/trim.html
Since they are basically a polyester film, they are extremely lightweight. The aluminum foil in comparison weighs a ton and would have added a lb in weight, not good in an edf ...
I ended up using four trim sheets for wings & fuse. The monokote foil does not stretch much, so you need to do a lot of paneling, which actually makes it look a lot more realistic.
I plan on using aluminum foil for the intake and some more detailing.
Jeff, I see you have the same scheme How did you do your minuteman decals?
Old Dec 17, 2009, 09:06 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by Socomon View Post
Very nice work, Herb.
Thanks it's moving along slowly as I don't have much time for anything leisurely these days ...
My weight rtf is now 8.1 lbs with a 9S 3200 TP setup, which is comparable to a good quality 90mm all composite (Schreiner F-86).
Power is around 2600-2700W on 9s.
That includes everything at this point (so eg without gear doors which will be added later).
The BVM one below is only slightly larger, but at $2k vs. $0.2k ...
Old Dec 18, 2009, 02:39 AM
ParkJeff's Avatar
Joined Feb 2003
I love the scheme but my finishing is not as well done as yours. Decals were made using inkjet waterslide and label paper. I think I'll try a colour laser next time as I had some problems with ink coverage with the inkjet.
Jeff
Old Dec 18, 2009, 06:56 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Here's a closeup of the F-86 cockpit
Not sure how the batteries will fit in there with that tub - might need to fly w/o plastic tub & pilot.
Old Dec 19, 2009, 02:03 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Ran up the power system today - finally and for the first time.
On 9S it's pulling 2700W @ 91A on close to 1-yr-old TP 3300's pro .
That gives it about 330 W / lb. Should fly ok
The fan (WeMoTec Midi pro rotor in Hy shroud) / motor (Neu 1515 1.5y) combination runs very smoothly ...
The fuse has no annoying resonances ... The intake is very quiet.
Old Dec 21, 2009, 11:41 AM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
When is the maiden? I will make sure to drop by with my camcorder.
Steph280 is offline Find More Posts by Steph280
Discussion large F-86 Sabre,any clue who makes it? MustangAce17 Electric Ducted Fan Jet Talk 12 Dec 20, 2007 09:47 PM
Question Which large, non-foamie F-86? (was: Retracts on K&A F-86 Sabre?) surfimp Electric Ducted Fan Jet Talk 99 Jul 20, 2007 10:40 PM
F-86 Sabre - My first EDF project BQuick Electric Ducted Fan Jet Talk 5 Sep 27, 2004 06:54 AM
F-86 Sabre jet video! pohlmeyr Electric Ducted Fan Jet Talk 17 Jan 13, 2002 09:35 AM
