More wing joint reinforcements.
Zinc cromate water based paint prevents the automotive primer from eating the bare foam. . |
Latest blog entry: BAe Hawk 90mm EDF
First coat of metallic silver applied,
More light coats of aluminum silver (fuse, wing top & tail) and red (wing bottom) to check for overall smoothness of finish.
A bit more work today while the wife's out shopping ...
After more sanding and priming (in red) of the fuse I trial - fitted the intake, fan and exhaust. Some foam carving and sanding eventually made everything fit. The intake duct is rigid enough to also hold the weight of the batteries (it was designed that way). A clean intake should mean good in-flight efficiency. I have been told by JePe that the stock one makes all sorts of horrible intake noises at flight speed ... . |
I am using a Turnigy 100A HV.
It will be placed either in the cockpit or directly over the duct, as I have it in my F-16 shown below. The latter setup saves some space in the cockpit, it is going to get a bit cramped in there ![]() Yes the stock location is nice, if you can fit your esc there. It also helps with the CG, moving some weight towards the back. I have a big chunk of motor in the back, so that should help a bit with the CG. Also the motor/fan can be moved back a bit. . |
I've seen some people assemble these models (F-86, Mirage, Hawk, ... ) first, and then fiberglass them.
I personally find the latter procedure quite inconvenient ... It is much easier and cleaner to sand, fiberglass, fill, sand and prime each component (fuse or fuse halves, wings, tail surfaces) individually before assembly, using only the amount of FG cloth used for that specific part. Since a good amount of finish and paint work is needed for each part, it makes the whole process a lot easier ![]() . |
If you look at the pictures, you will notice that the wing is one piece, and so are the fuse left & right sides ...
As far as the tail surfaces are concerned, the epoxy joint area is actually the strongest part, so it would be kind of pointless to make that part even heavier and stronger. The stabilizers and fin have now been glued in place. . |
To finally close up the two fuse sides, the ducting had to be fixed, the nosegear assembly had to be glued in, and the power, servo and air lines had to be routed.
| Thread Tools | |
| Discussion large F-86 Sabre,any clue who makes it? | MustangAce17 | Electric Ducted Fan Jet Talk | 12 | Dec 20, 2007 09:47 PM |
| Question Which large, non-foamie F-86? (was: Retracts on K&A F-86 Sabre?) | surfimp | Electric Ducted Fan Jet Talk | 99 | Jul 20, 2007 10:40 PM |
| F-86 Sabre - My first EDF project | BQuick | Electric Ducted Fan Jet Talk | 5 | Sep 27, 2004 06:54 AM |
| F-86 Sabre jet video! | pohlmeyr | Electric Ducted Fan Jet Talk | 17 | Jan 13, 2002 09:35 AM |
