This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Oct 27, 2009, 03:34 PM
vq35721 is offline
Find More Posts by vq35721
Family,RC Planes & Gym....
Santa Ana/92705
Joined May 2008
Get it going :-) Im waiting for the HET F86 to come out, that should be a fun build for me :-/
vq35721 is offline Find More Posts by vq35721
Old Oct 29, 2009, 06:26 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I only find time to work on this thing over the weekends ... and then if the weather is nice you know where I end up
I still have to order the motor. I am still debating on either a custom Neu 1415/1.5y with opend endbells (36.5mm diam) versus the standard Neu 1515/1.5y (39mm diam). The latter does not fit the WeMoTec MidiFan ...
This 101mm fan is I think a bit on the big side, because of the fuse surgery needed ...
Herb is offline Find More Posts by Herb
Old Oct 30, 2009, 04:33 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The front retract unit assembly is almost complete.
Need to reinforce the sides of the mount, add the pull-pull steering steel wires and mount the stering servo (hs-82mg).
Because of the standard 3.15 mm wire size, I can use either the spring lg or a normal steel wire lg.
Old Oct 30, 2009, 04:39 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The Neu 1515/1.5y fits the 90mm shroud I am using quite prefectly (39.5 mm diam motor opening).
Next I need to machine down the rotor to 89mm.
Old Nov 01, 2009, 08:12 PM
sheppard559 is offline
Find More Posts by sheppard559
Joined Mar 2008
herb...how do you cut your rotors down?...I know its kind of ghetto but i use alittle stand with a motor bolted to it,,then i attach the rotor i wanna cut, run it up about 1/4 throttle , and then hold self made sanding block( 4in by 4in block of wood with 80grit sand paper glued to it) on the rotor while it spins..... seems to work fine
sheppard559 is offline Find More Posts by sheppard559
Old Nov 03, 2009, 01:13 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
is that the fly fly shroud?
corsair nut is offline Find More Posts by corsair nut
Old Nov 05, 2009, 01:58 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by sheppard559
Herb...how do you cut your rotors down?...
A drill press is perhaps the best tool, but I have used just a dremel in the past as well.
You clearly mark where the cut is supposed to go on the rotor (with a bit of margin left) and then cut away. Has worked for me for years.
Flow around the rotor tip is highly turbulent, so the cut and finish need not be absolutely perfect ... The tip gap is not critical either, as long as it's < 1mm.
I am still considering sticking with the 101mm fan, it's a lot more rigid than the 90mm variants.
It will require quite a bit of foam surgery through; both the intake and the exhaust have to be modified.
Yet there is plenty of intake area, even for the 101mm fan (see pic below).
I did not like the fact that the Neu 1414 motor - which has a smaller 36mm diam can and therefor fist the WeMoTec MidiFan - has closed enbells.
Claims to the contrary notwithstanding, years of experience have taught us that rotor cooling in edf is a crucial longevity factor.
Steve Neu had kindly offered me a few months ago to make a custom 1414 EDF motor with open endbells to take care of the rotor cooling problems.
But in the end I decided to just go with the slightly bigger 1515, and use a larger shroud to accomodate the 39mm can. It took me just three days to get one from Esprit ...
Old Nov 07, 2009, 01:36 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Very nice work Herb!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Nov 08, 2009, 01:48 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Thanke Kev !
I finally glassed the wing bottom with 3 layers of 3/4 oz cloth; it will only be one or two layers max on top.
The persistent sanding and filling paid off, the wing surface still looks quite ugly at this point, but is in fact really smooth - as one can see when looking at it sideways.
I did a preliminary stress test of the wing, to see if further work might be needed, and it seems pretty strong. I cannot detect any flex now.
I am comparing ultra-thin adhesive aluminum tape to stick-on polyester film. The latter is a lot lighter, but does not conform well to compound curves. I might end up using both, and later use steel wool to cut down the shiny-ness.
Old Nov 10, 2009, 02:07 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Over the weekend I managed to do some priming and sanding....
Automotive primer (rustoleoum from ace) was used to fill in the weave. Most of it was wet-sanded away later, giving a reasonably smooth finish. I used a B&D Mouse to do most of the sanding work.
Old Nov 10, 2009, 02:12 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Primer fills in the weave nicely.
You sand too much and the glass will comes off as well, which you want to avoid at all costs.
A side view of the wing shows nicely the thin epoxy - glass layer.
Old Nov 10, 2009, 03:58 PM
fredo21 is offline
Find More Posts by fredo21
Never too much detail
fredo21's Avatar
Australia, VIC, Hampton
Joined Jan 2007
Hi Herb
Following your build with great interest, looks great. I have a flyfly Sabre and have the objective of glassing it and finishing it in a spazstix mirror chrome paint. I am in the process of testing the finishing methods. My plan is to glass the plane, get a very smooth surface(priming and sanding). paint with hi gloss black/mirror chrome then multiple clear coats. I need to test this to determine the chrome effect achieved and the durability of the finish.
I tried WBPU and found, surprisingly, the automotive primer went through it and ate the foam. I knew the primer would eat the foam however I thought 3 coats of WBPU would protect it. I am considering using a laminating epoxy as you have suggested. Is the brand of automotive primer you are using "foam safe" or are you relying on the epoxy to separate it from the foam?
Stuart
fredo21 is offline Find More Posts by fredo21
Old Nov 10, 2009, 04:24 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by fredo21 View Post
... I tried WBPU and found, surprisingly, the automotive primer went through it and ate the foam. I knew the primer would eat the foam however I thought 3 coats of WBPU would protect it. I am considering using a laminating epoxy as you have suggested. ...
Good question.
No the primer I am using is NOT foam safe, it is standard (rustoleum) automotive prime. Cheap and very effective.
First let me say that I do *NOT* recommend anything but laminating epoxy.
I have tried all other methods (pu, wbpu, polycrylic), and believe me there's no comparison. No, you do not save any money either.
Laminating epoxy (Pacer in my case)
* is easy to apply (I mix it with rubbing alcohol to dilute)
* can be mixed with microballoons
* dries fast and hard (12-24 hrs)
* is tough and structurally very strong when combined with fg cloth
* sands extremely well, does not gum up sanders
* sticks to anything
* forms an impenetrable layer
How do I prevent the primer from eating the foam?
I deviate from JePe's method - he first puts the cloth on the bare foam, then paints the laminating epoxy on it.
I do the reverse, first I use a large (1 inch) paintbrush and apply the thinned epoxy everywhere. Then I put the cloth on, and apply more epoxy.
My method ensures that there are no bare foam spots left! This is crucial (btw JePe makes it all look so easy. It is not).
Old Nov 11, 2009, 03:17 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The nosegar strut needs to be lengthened a bit, and the mains shortened just a bit.
Other than that, it looks good so far
Old Nov 13, 2009, 04:38 PM
tehachapi, CA
Joined Jan 2006
nice herb mysabre gained a little over a pound after alum finish. didnt seem to hurt performance at all though.
hopefully steve will do holes in the 14 series. i tend to agree with you on that as well. when i got my first one, i was like..."huh?" no holes? does well with a decent cool down run after flight to help with heat soak. i run a small heat sink on mine. i thought i cooked my 2y, turned out it was a broken wind like tumblers. the 1.5Y never gets close to cooking at 2.5kw on 8s without cooling holes. the 2y on 12s is a solid 3.5kw, and is pretty close to its limit.
Discussion large F-86 Sabre,any clue who makes it? MustangAce17 Electric Ducted Fan Jet Talk 12 Dec 20, 2007 09:47 PM
Question Which large, non-foamie F-86? (was: Retracts on K&A F-86 Sabre?) surfimp Electric Ducted Fan Jet Talk 99 Jul 20, 2007 10:40 PM
F-86 Sabre - My first EDF project BQuick Electric Ducted Fan Jet Talk 5 Sep 27, 2004 06:54 AM
F-86 Sabre jet video! pohlmeyr Electric Ducted Fan Jet Talk 17 Jan 13, 2002 09:35 AM
