Old Oct 23, 2009, 06:48 AM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Originally Posted by jetstreaming
Roman, cheers thats great info - the wikipedia link.
This helps ALOT, as I'm currently re-vamping my Ground Station.
I take it a Patch Antenna will also benefit being higher up, for a greater opportunity to have LOS of the plane with no ground obstructions? Hence why you see them mounted at the top of masts - however, contradicting info people have posted here, where its best close to the ground!
It's good close to the ground when flying close in.
Mounting the patch close to the ground helps to avoid multipath reception.
galaxiex is offline Find More Posts by galaxiex
Old Oct 23, 2009, 06:55 AM
jetstreaming is offline
Find More Posts by jetstreaming
UK
Joined Mar 2009
Thanks for that additional info Galaxiex.
With the usual Omni / Patch configuration (Omni for close flying) - how high above the ground would be optimum to mount the patch, to take care of longer distance flying?
jetstreaming is offline Find More Posts by jetstreaming
Old Oct 23, 2009, 07:07 AM
galaxiex is offline
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Not an antenna expert... but I *think* you want the patch to be near a multiple of the wavelength above the ground.
Could be I have this wrong.... experts chime in?
Old Oct 23, 2009, 08:31 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
depends on which video tx you are useing 900, 1.2 or 2.4, 5.8
try a search "diversity antenna" or something similar
galax should know I told him 2 times already
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Oct 23, 2009, 09:04 AM
tungym is offline
Find More Posts by tungym
tungym's Avatar
Planet Earth
Joined Jul 2005
Originally Posted by VRflyer
Hueber
wow that's a setup. You sure to take attention when you use that. Question, What you say to policeman if he ask what you are doing? Fly r/c plane for fun
That is a suicide machine that the lipo can bomb your head off, when the plane lost control!
tungym is offline Find More Posts by tungym
Old Oct 23, 2009, 10:25 AM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
You are correct,
It is better to have your patch higher up, and close to the ground Like was said before, having your antenna higher up gives you better reception as a general rule, but patch antennas benefit from having a ground plane next to them, especially at the lower frequencies ( 900 MHZ !! ). So if you mount a patch on a big tower, it has a nice ground plane behind it, if you mout it on a pole, you do not... I got my best performance and longest range from my 900 MHZ patch by setting it RIGHT ON THE GROUND Get the patch high enough like 20 feet, and it would probably be better than on the ground... On the Car is better also, it gives a the patch aground plane and lets it be 5 feet high or so.. But a patch on a tripod seems to be a real low performance height for them, they dont have a ground plane, but are not high enough to make it worthwile loosing the ground plane...
This is why I have stopped using patches completely , and am now using Yagi Antennas. I can have them on my Tripod and they do not need a big ground plane to work well
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Oct 23, 2009, 10:58 AM
galaxiex is offline
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Yeah but I don't listen to you because you post so much crap, most, if not all of the time, it's not worth reading.
Old Oct 23, 2009, 01:29 PM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
I thought I was the only one who thought that about Dave22, I put Dave on my ignore list and now all is calm.
Tarro is offline Find More Posts by Tarro
Old Oct 23, 2009, 01:31 PM
Shikra is online now
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
What sort of performance increase are you seeing with the Yagi? I'm using patch on a 1.5m tripod and very happy with the quality at 3-4km, but at 7 it's starting to get a tad grainy. Quite happy with that, but if I can improve...
Shikra is online now Find More Posts by Shikra
Old Oct 23, 2009, 03:06 PM
downeym is offline
Find More Posts by downeym
Electric Addict
downeym's Avatar
United States, GA, Atlanta
Joined Apr 2002
and another thread goes down the rabbit hole....
downeym is offline Find More Posts by downeym
Old Oct 23, 2009, 03:32 PM
David22 is offline
Joined Apr 2008
Jet stream
here is a link for you.
Omni / patch configuration means you are useing diversity.
I use this to position my antennas whether they be omni, patch or yagi.
The centre of a yagi is the collector or right where the cable goes into it.
The height of the patch determines how far and low you can go.
For really long distance low flying it would be up high and close to vertical.
Use a tape measure and postion the omni at a different height but at the calculated distance.
Depending on the video tx you are useing.
works for me
http://www.rcgroups.com/forums/showp...&postcount=989
Old Oct 23, 2009, 04:19 PM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
So the link you posted to Thomas' explanation states that I should have both Omni antennas on my 900mhz setup .33 meters apart?
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Oct 23, 2009, 04:23 PM
David22 is offline
Joined Apr 2008
Old Oct 23, 2009, 04:27 PM
David22 is offline
Joined Apr 2008
Read Thomas' post more carefully
Old Oct 23, 2009, 04:30 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
cmon man, no games...do you know?
thats what it looked like it said to me
Administrator
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg FPV Talk 2 Dec 03, 2008 02:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
