Old Oct 22, 2009, 03:04 PM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Originally Posted by webdr
question, why does DPCAV sell the extensions as "Ideal for remotely mounting 434MHz - 1300MHz wireless video (A/V) antennas."
http://www.dpcav.com/xcart/product.p...cat=261&page=1
Pratorian,
12 inchs and 23 inch extensions are relatively short and wont hurt to badly, but it will hurt. The higher the frequency, the worse the loss. The amount of Loss at 435 MHZ is not bad at all, its very little. By the time you get to 2.4 GHZ everything changes, even short lengths have a lot of loss Just each connector at 2.4 GHZ has loss, which is probably why DPCAV is saying up to 1300 MHZ.
So I would say for those very short coax extensions, if it is for 900 MHZ video, it probably will be OK, not great, but usable..... For 2.4 GHZ video, I would not use any extension no matter how short it is.
One rule of thumb at our frequencies, do whatever it takes to mount the receiver itself at the antenna. You will get best performance if there is no coax at all.
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Oct 22, 2009, 03:09 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Pick your type of cable and run it here. As you think you know better.
http://www.timesmicrowave.com/cgi-bin/calculate.pl
Martin Y is offline Find More Posts by Martin Y
Old Oct 22, 2009, 03:12 PM
pratorian is offline
Find More Posts by pratorian
No guts no glory
pratorian's Avatar
Quebec, Canada
Joined Sep 2007
Originally Posted by JettPilot
Pratorian,
guess you meant Webdr ?
pratorian is offline Find More Posts by pratorian
Old Oct 22, 2009, 03:13 PM
Martin Y is offline
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Thats why I wont use that DVCAP cable.
http://www.dpcav.com/xcart/product....&cat=261&page=1
Old Oct 22, 2009, 03:19 PM
JettPilot's Avatar
Miami
Joined Apr 2005
Yep, I meant Webdr, hhahaha, to many responses and got them mixed up !
Site Sponsor
Old Oct 22, 2009, 03:24 PM
JettPilot's Avatar
Miami
Joined Apr 2005
That is the table I was talking about, Times Microwave cable is the best you can get that is practical for FPV uses. Remember , some of the very low loss cables in that chart are very large hard line, like pipe, so many are unusable for our purposes. There are many very hard to deal with, and very large pipe like coax listed in that chart, make sure you know what you are buying ! LMR 100 is the best small cable, and LMR 240 ultraflex is about as large a cable that is practical for our ground stations.
Then dont forget to add in the connector losses, assuming someone used the best connectors and did a perfect job of solding them to the line By the time you get to 2.4 GHZ, any type of extensions are just a bad idea and wont work well.
Site Sponsor
Old Oct 22, 2009, 03:37 PM
Martin Y is offline
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
I using LMR-300 on my antenna(s). And I have a bit of M27500 cable to use also. This is also good to use http://www.xagyl.com/store/product.p...cat=252&page=1
Old Oct 22, 2009, 09:50 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
solder the rx to the antenna for best performance, so it is dirrectly in the centre behind it.
from there use high quality cable so you can sit down comfortably away from the antenna. which is clear and free
distance is not a big deal, test out far away compared to being very close.
With a good "powered" video splitter connected close to the oracle your video will be better. dvr etc.
If you use only one antenna even better , say a 10 foot cable, video audio, to your goggles or tv screen would be best "for your eyes only" lol
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Oct 22, 2009, 10:22 PM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
How long does your battery power that 15 inch TV ???
I had my first flight with the 15" tv today.
After a 30 minute flight, with a 3s 2200mah pack powering the tv and the oracle, it was at 73% remaining.
Not bad...
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Oct 23, 2009, 01:30 AM
QUIKSILVER is offline
Find More Posts by QUIKSILVER
QUIKSILVER's Avatar
UK
Joined Sep 2002
Not bad...
Wow, good result
QUIKSILVER is offline Find More Posts by QUIKSILVER
Old Oct 23, 2009, 02:53 AM
jetstreaming is offline
Find More Posts by jetstreaming
UK
Joined Mar 2009
General ground station Q, is it an advantage to mount your omni-directional Video Rx high up, for better reception?
ie: So would it at 3 metres off the ground be more effective than a foot off the ground? Cheers in advance.
jetstreaming is offline Find More Posts by jetstreaming
Old Oct 23, 2009, 05:43 AM
Hueber is offline
Find More Posts by Hueber
Switzerland
Joined Oct 2006
Yes, it can make a big difference, especially if you're flying low! Line of sight is only half the truth, you need also free space over and UNDER this line. Otherwise, you can loose up to 6dB, which results in half the range, even if you have direct sight to the plane.
See here: http://en.wikipedia.org/wiki/Fresnel_zone
Cheers, Roman
Hueber is offline Find More Posts by Hueber
Old Oct 23, 2009, 06:27 AM
QUIKSILVER's Avatar
UK
Joined Sep 2002
Cheers, Roman
I started to cry when i read this part
Fn = The nth Fresnel Zone radius in metres
d1 = The distance of P from one end in metres
d2 = The distance of P from the other end in metres
λ = The wavelength of the transmitted signal in metres
The cross section radius of the first Fresnel zone is the highest in the center of the RF LoS which can be calculated as:
My ears are bleeding
Old Oct 23, 2009, 06:39 AM
UK
Joined Mar 2009
Roman, cheers thats great info - the wikipedia link.
This helps ALOT, as I'm currently re-vamping my Ground Station.
I take it a Patch Antenna will also benefit being higher up, for a greater opportunity to have LOS of the plane with no ground obstructions? Hence why you see them mounted at the top of masts - however, contradicting info people have posted here, where its best close to the ground!
Old Oct 23, 2009, 06:47 AM
KristianS is offline
Find More Posts by KristianS
FPV addict
Giske, Norway
Joined Aug 2009
I've started to place my antennas (11dB patch and 3dB omni connected to Duo Diversity) on the roof of my car and I've got much better signal/range now.
Kristian
KristianS is offline Find More Posts by KristianS
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg FPV Talk 2 Dec 03, 2008 02:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
