Old May 14, 2011, 12:23 AM
FlyingMcCoy is online now
Find More Posts by FlyingMcCoy
Joined Mar 2010
I just had a peek inside my RC305 receiver from HK and I see a 7805 regulator, which means the module runs on 5 volts.
Maybe the HK version is different from the Range video?
FlyingMcCoy is online now Find More Posts by FlyingMcCoy
Old May 14, 2011, 01:53 PM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
yes it is. they run on different frequencies.
whakahere is offline Find More Posts by whakahere
Old May 18, 2011, 12:45 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I'm not finished with it yet.
I still need to cut in a slot for a tracking antenna, when it's finished.
& I'll probably carry my transmitter in this case.
http://www.youtube.com/watch?v=-xPzQLf6els
m_beeson is offline Find More Posts by m_beeson
Old May 18, 2011, 02:49 AM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
That thing is huge!!.
How and with what are you going to carry that to your field?.
Maybe add a pair of wheels on one side and a handle at the other so to make transport easy.
Teo
teopbako is offline Find More Posts by teopbako
Old May 18, 2011, 11:01 AM
garris2 is offline
Find More Posts by garris2
Melbourne, Australia
Hey Mike, thats real nice, I like it!
cheers
Geoff
garris2 is offline Find More Posts by garris2
Old May 18, 2011, 12:14 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Teo
You're right, it is big, but it's a solution to a problem...
I don't think it'll fit in the trunk of a car, but i'm sure my truck won't have much of a problem...
cheers
Geoff
Thank you Geoff,
Old May 19, 2011, 08:28 PM
garris2 is offline
Thank you Geoff,
Somehow I just new that would be your sort of vehicle used for FPV toting.
I wish I had one, I squeeze everything into the back of a Toyota RAV4 including 2.4m Cularis.
Nice mountain background too.
Geoff
Old May 19, 2011, 09:26 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Geoff
I've got plans for those mountians, as soon as the weather clears up
Old May 19, 2011, 09:39 PM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
I was hoping you would.
I stayed out there when I worked at Thiokol.
We drove a rental car up to Willards Peak and watched planes fly below us.
scrape is offline Find More Posts by scrape
Old May 19, 2011, 09:54 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Scrape,
I took some pictures up there last summer, but I can't seem to find them.
If you're not from an area where there are mountains; It can be a little overwhealming.
I stopped to get a drink from a spring while I was up there, and the water was soooooo cold, that I bet a guy I was with, that he couldn't hold his hand under it for 30 seconds. He made it to 17
Old May 19, 2011, 10:29 PM
scrape is offline
Joined Mar 2006
That's one scary road, reminds me of Ice Road Truckers Deadliest Roads.
http://www.youtube.com/watch?v=x_JLtET19vs
Old May 20, 2011, 08:53 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
HOLY S>>>>>
On a better note, someone asked me while ago about volt meter (display) for GS.
They are back in stock :-))
http://www.amazon.com/XScorpion-Red-.../dp/B001RS1ERC
http://www.darvex.com/store/pc/XScor...tor-11p119.htm
better price here
nakelp86 is offline Find More Posts by nakelp86
Old May 21, 2011, 09:04 PM
Glenstr is offline
Find More Posts by Glenstr
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
Just threw this one together quick like, I originally had the monitor down near the bottom, then when I added the 2nd rx and the Eagle Eyes I decided to move it to the top. I found that while flying FPV I was often glancing down at the screen and then up at the plane, so I thought that if I have the monitor up higher it will be easier to switch between looking at the two. I also thought it might help with the daylight glare being that it's aimed at a down angle.
I also have a cardboard hood for it, not shown here.
Glenstr is offline Find More Posts by Glenstr
Old May 22, 2011, 09:33 AM
Mechnan is offline
Find More Posts by Mechnan
Schweiz, BE, Neuenegg
Joined Apr 2011
my mobile groundstation
Motor Scorpion SII2212-885KV
ESC ePower 18A Regler für 2-3S LiPos mit 2A L-BEC
Servo MKS-Servo-DS470
Battery ePower EXP eco-20C 2200mAh 3S1P 11.1V
RX Futaba Empfänger R617FS 2.4GHz FASST 7 Kanal
CPU KKmulticontroller SMD v5.5 Blackboard
Propeller GWS 9x4.7" SF
Chassis 1mm CFK
Tubes 11x10mm Länge 280mm
Weight ∼700g
Max Thrust ∼1800g
Endurance 13:30min (Schweben 15min)
Spez. Efficency 12.57mA/g (9x4.7“)
FPV
Camera GoPro Hero HD mit LVF
A/V Tx ImmersionsRc 5.8GHz 600mW (200mA)
Weight ∼900g
Endurance ∼10:30min (Schweben 11:30min)
Ground Station
Battery Zippy 2200mAh 20C 3S1P 11.1V
Battery 9v block
A/V Rx Airwave 5.8GHz A/V Receiver (210mA)
Monitor Fat Shark Base RCV922 Goggles (230mA)
Endurance ∼5h
Mechnan is offline Find More Posts by Mechnan
Old May 22, 2011, 09:37 AM
flyboy321 is offline
Find More Posts by flyboy321
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
Where did you get the TX case?
That really looked like a nice, clean setup!
flyboy321 is offline Find More Posts by flyboy321
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg FPV Talk 2 Dec 03, 2008 02:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
