Old Apr 18, 2011, 08:02 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Originally Posted by My_design View Post
Actually the Tripod came with a camera mount (I think that many of them do. I simple screwed and glued the camera mount to the case. It then locks to the tripod.
That seams obvious solution but the aluminum in these cases is paper thin and if you do not do some reinforcement it will fail soon.
So I think you have to make some bracket. Have to come up with ready made somewhere.
nakelp86 is offline Find More Posts by nakelp86
Old Apr 19, 2011, 01:10 AM
jkarnacki is offline
Find More Posts by jkarnacki
USA, CA, San Carlos
Joined Nov 2007
I considered using the stock camera mount glued to my case but I too thought it might be a little flimsy, considering the cam mount uses a quick release mechanism I didn't think it would be very stable. Guess I'll just have to try it and see! Either way it beats setting my case on the ground and kneeling down to fly!
- Jeff
jkarnacki is offline Find More Posts by jkarnacki
Old Apr 19, 2011, 01:37 PM
My_design is offline
Find More Posts by My_design
My_design's Avatar
Champaign, Il
Joined Apr 2007
My case has aluminum rails, but has a thin sheet plastic and board body, rather flimsy.
But I mounted the quick mount in the center, with the top tilted the weight is rather balanced and I don't use a tracker system. So as long as no one takes a swipe at it or yanks the cables too hard it will be fine. I'll take some more pictures as well.
-B
My_design is offline Find More Posts by My_design
Old Apr 21, 2011, 02:00 PM
Wizzard033 is offline
Find More Posts by Wizzard033
KF5LDN FPV Junkie!!!
Wizzard033's Avatar
United States, TX, Lubbock
Joined Nov 2009
Originally Posted by jkarnacki View Post
I'd also like to know how to mount an aluminum case to a tripod, been trying to figure it out for days!
- Jeff
WHy not removethe interior and epoxy ply or hardwood hard points on the inside
Wizzard033 is offline Find More Posts by Wizzard033
Old Apr 22, 2011, 12:16 PM
My_design's Avatar
Champaign, Il
Joined Apr 2007
Here's the pic I mentioned. I've since gone back and added a second case which holds the 3 viewing lenses and the 12 volt battery. This case sits on the ground underneath the tripod. So now the 2 receivers and the diversity system are all off the single 12 volt and the goggles are off of a single lipo battery.
Old Apr 22, 2011, 01:27 PM
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
Originally Posted by timnilson View Post
here is my ground station i just finished tonight. Inspired by the mk-stefan ground station, the goal was to create a small gs that packs a punch and looks good. I wanted to be able to have everything on one tripod -- monitor, batteries, antenna & tracker, everything. The gs has a 7" monitor as well as goggle connections for fatshark goggles. The gear includes:
Video rx: Immersionrc duo5800
distribution: Immersionrc powerbox
dvr: Not yet in
antenna: 19db patch and 9db omni
antenna tracker: Immersionrc eztracker
power: 2 redundant 5000mah lipos
the hardest part of this build was to design and custom cnc manufacture the lexan enclosure. build log of this gs.
http://www.youtube.com/watch?v=zsxf1k5nttu
SWEET !! Me wants !
idletime is offline Find More Posts by idletime
Old Apr 22, 2011, 04:33 PM
chuck99z28 is offline
Find More Posts by chuck99z28
Mongolia, Ulaanbaatar, Khan Uul
Joined Jan 2011
If you need a heavy duty tripod, these speaker tripods for use with PA systems are normally 1 1/2 inch tube.
http://www.musiciansfriend.com/navig...speaker+tripod
You can get mount adapters which go underneath whatever you are mounting.
You can find them on Craigslist for $20 a tripod.
chuck99z28 is offline Find More Posts by chuck99z28
Old Apr 22, 2011, 09:26 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
this looks better:
http://www.google.com/products/catal...d=0CEUQ8gIwAQ#
Old Apr 22, 2011, 10:15 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Risky business using hot glue to hold the bracket on. It seems like a good idea but what happens if the glue rips clean off the plastic? I'd drill it and screw it.
airbagit13 is offline Find More Posts by airbagit13
Old Apr 22, 2011, 10:32 PM
timnilson is offline
Find More Posts by timnilson
timnilson's Avatar
United States, FL, Sarasota
Joined Nov 2010
Originally Posted by idletime View Post
SWEET !! Me wants !
Thanks Idletime... I am honored that your first post in your RCG career was to express your appreciation for my GS!
timnilson is offline Find More Posts by timnilson
Site Sponsor
Old Apr 22, 2011, 10:34 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
if anyone has any success with finding glue which will bond to Pelican case plastic please let us know :-)
Old Apr 22, 2011, 11:09 PM
Wingnut13 is offline
Find More Posts by Wingnut13
I do all my own crashes
Wingnut13's Avatar
United States, NH, Rochester
Joined Jan 2011
3M Super 77 spray adhesive works well for me. ~Wingnut13
Wingnut13 is offline Find More Posts by Wingnut13
Old Apr 23, 2011, 05:24 AM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Hmm
Old Apr 23, 2011, 12:03 PM
AnnihilaT is offline
Find More Posts by AnnihilaT
Joined Apr 2005
Work in progress...
But here is mine so far... still need to mount antenna's, receivers, and diversity controller to the AAT but then im pretty much done. Then ill need to devise a quick way of tearing down / building up.
Its hard to see from this picture but the ipad screen is just below eye level when I'm sitting next to the tripod and the capture device with preview screen is at eye level.
AnnihilaT is offline Find More Posts by AnnihilaT
Old Apr 23, 2011, 05:40 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
What is this blue thing with light on?
and what is you capture device? still looking for inexpensive and decent one.
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg FPV Talk 2 Dec 03, 2008 02:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
