Old Apr 15, 2011, 11:24 AM
CaliDave is offline
Find More Posts by CaliDave
CaliDave's Avatar
Bay Area
Joined Dec 2010
Originally Posted by timnilson View Post
Thank you CaliDave. The monitor is there just for back-up and passengers. The main viewing device are FatShark "base" goggles that plug into the side of the box where the volt meters are. I was not too concerned with glare for that reason.
Got it! Very clean.
CaliDave is offline Find More Posts by CaliDave
Old Apr 15, 2011, 11:51 AM
DarkHeli is offline
Find More Posts by DarkHeli
Future-proof EVERYTHING
DarkHeli's Avatar
NY
Joined Jul 2008
Timnilson,
Nice GS!!! I'm a fan of acrylic, good work there!
Where did you get those great looking voltmeters? They look very professional.
DarkHeli is offline Find More Posts by DarkHeli
Old Apr 15, 2011, 02:04 PM
metalfred is offline
Find More Posts by metalfred
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
Awesome GS Tim!!! very clean
metalfred is offline Find More Posts by metalfred
Old Apr 15, 2011, 04:57 PM
My_design is offline
Find More Posts by My_design
My_design's Avatar
Champaign, Il
Joined Apr 2007
My FPV GS
2 - 900mhz RX
1 Patch antenna 8dbi
1 Omni 2dbi whip antenna
1 Eagle Tree FPV Ground station system
Nine Eagle helicopter case
I'm modding some EVG goggles to be in a ski goggle but currently use Fatshark glasses. Going to add a drop cord for a 12V 4.5A sealed battery to power everything. I have another case, so I may put the battery in that case as well as have a spot for the glasses.
-Brian
My_design is offline Find More Posts by My_design
Old Apr 15, 2011, 05:10 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
How do you manage mounting the case to the tripod?
The case alum is so thin, did you make some braces??
nakelp86 is offline Find More Posts by nakelp86
Old Apr 15, 2011, 06:51 PM
timnilson is offline
Find More Posts by timnilson
timnilson's Avatar
United States, FL, Sarasota
Joined Nov 2010
Originally Posted by DarkHeli View Post
Timnilson,
Volt Meters: Part # XL3BL-20V Digital Blue LED Voltmeter from www.futurlec.com ($9.90 each)
Thanks Metalfred!! You still need to post yours!
timnilson is offline Find More Posts by timnilson
Site Sponsor
Old Apr 15, 2011, 07:38 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
You can still attach some shade there. By the way this is one of the best set ups I saw here.
I think I have same volt meter somewhere, with spring cleaning I may dig it out eventually :-)
Old Apr 15, 2011, 08:36 PM
timnilson's Avatar
Joined Nov 2010
The volt meters had to be very small and this one was the smallest I was able to find -- every piece that went into this design was carefully chosen for its size and performance. I went through a few 40mm fans to settle on the one I picked... it's noisy, but moves about 4 times the amount of air from the usual 'silent' 40mm fans while needing a modest 200mAh. The PowerBox is another critical component. It's tiny yet provides you the critical functions of power distribution and AV distribution.
Site Sponsor
Old Apr 15, 2011, 09:18 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Very impressive, I wish I had access to some machinery.
I will have to settle for my Pelican cases :-(.
Old Apr 15, 2011, 10:39 PM
timnilson's Avatar
Joined Nov 2010
I live in NYC and found a local CNC shop to do the CNC-ing of the lexan. It was not cheap, but well worth it.
Site Sponsor
Old Apr 16, 2011, 12:01 AM
swing2harmony is offline
Find More Posts by swing2harmony
Canada, ON, Toronto
Joined Mar 2011
I was going to make a similar GS and I thought I could use a flash bracket like this and attach it to the case so then you could screw it in and out whenever you want. Maybe somebody here has a more solid idea than mine which I too like know about it before I build mine!
swing2harmony is offline Find More Posts by swing2harmony
Old Apr 18, 2011, 11:50 AM
FloridaRCFlyer is offline
Find More Posts by FloridaRCFlyer
Joined Oct 2010
This is a 3D animation of my future groundstation. I am planning to build it over the summer. The groundstation is drawn to scale. The monitor is a vizio 16".
Feel free to use or adapt my design if you want.
A 3D Animation of My Future FPV Groundstation (1 min 10 sec)
FloridaRCFlyer is offline Find More Posts by FloridaRCFlyer
Old Apr 18, 2011, 11:54 AM
jkarnacki is offline
Find More Posts by jkarnacki
USA, CA, San Carlos
Joined Nov 2007
I'd also like to know how to mount an aluminum case to a tripod, been trying to figure it out for days!
- Jeff
jkarnacki is offline Find More Posts by jkarnacki
Old Apr 18, 2011, 12:40 PM
Wearyman is offline
Find More Posts by Wearyman
Just dog tired.
Wearyman's Avatar
USA, NY, Buffalo
Joined Dec 2010
- Jeff
I suspect that he fabricated a mount by attaching a compatible mounting bracket to some heavy gauge steel plate. Then all he had to do was strap on the case and done.
Wearyman is offline Find More Posts by Wearyman
Old Apr 18, 2011, 01:45 PM
My_design's Avatar
Champaign, Il
Joined Apr 2007
Actually the Tripod came with a camera mount (I think that many of them do. I simple screwed and glued the camera mount to the case. It then locks to the tripod.
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg FPV Talk 2 Dec 03, 2008 02:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
