Old Nov 30, 2010, 08:12 PM
SENTRY 62 is offline
Find More Posts by SENTRY 62
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
Not at all - toss in 1 earbud ... keep the other ear free. MAGIC. I'd much rather have 1 going to sound from my plance mic and the other to some tunes... u can easily rip out an earbud if u need to focus in a hurry.
I bet that the people that fly with no sound though are more keen on visual queues (camera / OSD) than others though. They almost HAVE to be. The people WITH sound are prob the ones that end up taking engines noise for granted (thinking that they are safe) while forgetting that up elevator they set and losing altitude fast - heh heh.
SENTRY 62 is offline Find More Posts by SENTRY 62
Old Nov 30, 2010, 08:13 PM
cherokee180c is offline
Find More Posts by cherokee180c
KB3VOJ
cherokee180c's Avatar
USA
Joined Sep 2007
Especially when I get my EPP flying wing designed for combat!!! I will be really brave then! At least it will make for good entertainment if I pick the right music!
cherokee180c is offline Find More Posts by cherokee180c
Old Nov 30, 2010, 08:14 PM
Po73 is offline
Find More Posts by Po73
Thou who know not
Po73's Avatar
USA, MI, Mason
Joined Jul 2010
Aye but the music I listen to would lead to attacking the earth.
Po73 is offline Find More Posts by Po73
Old Dec 02, 2010, 04:06 PM
fireslayer26 is offline
Find More Posts by fireslayer26
My Karma ran over my Dogma
fireslayer26's Avatar
United States, FL, Jacksonville
Joined Feb 2010
I received my new equipment from Cercom Technologies and immediately went to work on making my Ground Station. The Cercom products are small and compact, they make for a nice clean setup. Here is the result....
Carrying case from Harbor Freight Tools
Clean interior (you can see the 7ah SLA battery in the top left that powers everything. I still have room to put the Cercom googles whenever they are released)
The RED patch cable is what I will be attaching to the Ethernet port to run to the patch antenna on the tripod.
7" Haier Digital LCD TV and Rx w/SMA connector from Cercom
Close-up RX w/SMA (will be adding a pigtail SMA that will go from the RX to the top of the case where it will have a bulkhead connector so I can just screw a omni antenna onto it)
Ground station w/ Diversity from Cercom
Ethernet port mounted in side of lid for cable to Patch on tripod
Patch w/integrated RX
fireslayer26 is offline Find More Posts by fireslayer26
Old Dec 02, 2010, 04:26 PM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
fireslayer26 nice sticker
saucisse is offline Find More Posts by saucisse
Old Dec 02, 2010, 04:42 PM
Joined Feb 2010
Thanks! It is on all my R/C and FPV boxes now.
Old Dec 02, 2010, 04:44 PM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Looks real good.
man2000me is offline Find More Posts by man2000me
Old Dec 02, 2010, 07:00 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
FIRESLAYER --- over time your batt connection(s) will be less solid. Are there any kinda positive-lock batt connections you can use? I'd hate for them to slide off in flight. Maybe a more permanent/solid connection w/ in inline switch?
Old Dec 02, 2010, 07:10 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
It s very important to hear what is going on with your plane as it flys fpv
one ear bud is good for that
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Dec 02, 2010, 08:07 PM
KB3VOJ
USA
Joined Sep 2007
The one of Benedict Arnold?
Old Dec 02, 2010, 08:10 PM
KB3VOJ
USA
Joined Sep 2007
FireSlayer26, that ground station rocks! I may have to steal that Ethernet port connector through the case idea for my box. It would be much nicer to fix all the wiring inside the box and just have a single cable going out. Also relieves any tripping over the cable hazard to the Diversity. Sweet idea.
Old Dec 02, 2010, 08:26 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
Also Fireslayer ---- heatshrink your monitor brackets in black, or do some small foam blocks (black). Cut a slit in the blocks, throw some glue in there... and then you get a little "cushion" on the brackets for when you travel.
Actually... just cut slits in the foam, cover the brackets and then heatshrink it closed - this way it's more "removeable" than glue if you need to readjust it.
Old Dec 02, 2010, 08:50 PM
skunkworks2006 is offline
Find More Posts by skunkworks2006
skunkworks2006's Avatar
Michigan
Joined Nov 2006
That's good advice, Sentry.
Nice looking ground station.
skunkworks2006 is offline Find More Posts by skunkworks2006
Old Dec 02, 2010, 10:09 PM
nakelp86 is online now
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Gee, forgot about this thread :-)
Its funny how it works. I had small case with 7" monitor and barely could fit anything in there, forget Oracle diversity ..Aint gona fit there.
So I got NEW diversity GS from :http://www.cercomtechnology.com/ and all things went in reverse.
Now I have a 15" monitor and almost invisible diversity GS and plenty of room for ....... hmmm airplane
nakelp86 is online now Find More Posts by nakelp86
Old Dec 03, 2010, 07:07 AM
Joined Feb 2010
Thanks for the comments and ideas everyone!
Sentry- Yes, I think I will add a Deans connector and solder the wires to the battery for a secure connection. Also, I do need to dress up the monitor bracket a bit too.
Cherokee- Go right ahead. It does make the whole setup nice and clean. I will only have one rj45 cable going from my box to the tripod with the small Cercom patch antenna on it.
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg FPV Talk 2 Dec 03, 2008 02:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
