Old Feb 02, 2013, 09:34 AM
kc10kevin is offline
Find More Posts by kc10kevin
Lt Col, USAF, Retired
United States, IL, Swansea
Joined Jan 2010
Originally Posted by cmavr8 View Post
Looks great!
Do you have a link/description/product# for the switches and voltage meters handy? Could I have it please?
Thanks! A little overkill, but fun to build!
Here are some of my parts:
Case: http://www.amazon.com/gp/product/B00...ls_o08_s00_i01
Main Screen: 15.6" Samsung laptop monitor out of a broken Toshiba Laptop
Laptop Screen Conversion Kit: http://www.ebay.com/itm/110925504614...84.m1497.l2649
Backup Monitor: 9" Philips DVD screen
Computer:
Power Supply (PicoPSU): http://www.mini-box.com/picoPSU-160-XT
Motherboard: http://www.newegg.com/Product/Produc...82E16813157228
RAM: http://www.newegg.com/Product/Produc...82E16813157228
SSD: http://www.newegg.com/Product/Produc...82E16820239045
WIFI: http://www.newegg.com/Product/Produc...82E16833704078
Keyboard: http://www.newegg.com/Product/Produc...82E16823126264
USB/Audio Panel: http://www.newegg.com/Product/Produc...82E16813999356
Video Capture: http://www.newegg.com/Product/Produc...82E16815116048
Power Switch: http://www.frozencpu.com/products/10...v_pc=145#blank
USB Extension: http://www.amazon.com/gp/product/B00...ls_o05_s01_i00
Case Fans: http://www.newegg.com/Product/Produc...82E16811999199
Electrical:
UPS/Charger: http://www.mini-box.com/picoUPS-100-...8&category=981
Intelligent buck-boost DC-DC converter with USB interface: http://www.mini-box.com/DCDC-USB?sc=8&category=981
- Enclosure: http://www.mini-box.com/DCDC-USB-ENC...8&category=981
Switches: http://www.ebay.com/itm/160794722080...84.m1497.l2649
http://www.ebay.com/itm/150960768131...84.m1497.l2649
http://www.ebay.com/itm/150960768618...84.m1497.l2649
Volt Meters: http://www.ebay.com/itm/230913123442...84.m1497.l2649
Ammeter: http://www.ebay.com/itm/310551242752...84.m1497.l2649
AC-DC Power Supply: https://www.jameco.com/webapp/wcs/st...oductId=123432
Battery: https://www.chromebattery.com/12v-11...connector.html
12V to 5V Regulator: http://www.ebay.com/itm/140891595448...84.m1497.l2649
AC Plug: http://www.amazon.com/gp/product/B00...ls_o05_s00_i00
Audio/Video:
RCA to VGA Converter/Switcher: http://www.ebay.com/itm/190596379150...84.m1497.l2649
Video Amp: http://www.amazon.com/gp/product/B00...ls_o06_s02_i00
Misc:
Carbon Fiber Vinyl:http://www.ebay.com/itm/130806128673...84.m1497.l2649
kc10kevin is offline Find More Posts by kc10kevin
Latest blog entry: KKNG Rename
Old Feb 02, 2013, 09:37 AM
Qnzkrew is offline
Find More Posts by Qnzkrew
United States, RI, Cumberland
Joined Mar 2008
@kc10kevin
hey what computer are you using for your GS and what is the amp draw on that
EDIT:just saw your post
Qnzkrew is offline Find More Posts by Qnzkrew
Old Feb 02, 2013, 09:43 AM
Joined Jan 2010
Originally Posted by Amfamora View Post
I have a question if anyone can ease my concerns....
Have a 24 to 12v stepdown regulator with a a max of 5amps or 60w draw. TV alone shows 12v 3A max draw. Once I throw in USB Ports the Video receiver, video amplifier will I be pushing my luck?
Also says 24v input Ill be running off a 5000mah 4S Lipo. Anyone think Ill run into dramas?
I was a little concerned about the Amp draw as well on my monitor. I threw mine on a Watts UP and saw it only drew .5A and only a few watts. My guess would be it would draw much less than the 3A Max it is saying. Easiest way would be just throw it on an amp meter and see what it draws when turned on.
I originally went with this 24V to 12V stepdown regulator: http://www.ebay.com/itm/300839818825...84.m1497.l2649
I don't know which one you bought, but I'd make sure the voltage range input will handle down to 14.8V (4S). I was using a 6S and it worked great. Didn't have to worry.
As you can see from the above parts list, I going to switch mine around a little and use an SLA battery, picoUPS (for switching and charging) and a DC-DC regulator to get a constant 12V.
Old Feb 02, 2013, 09:47 AM
Joined Jan 2010
Originally Posted by Qnzkrew View Post
@kc10kevin
Computer specs are listed in the post above. I built it myself from the parts listed. Put it on a Watts UP and found it only draws between 2 and 2.5 Amps with the monitor on and only 20-30 watts. I was shocked it drew so little.
With everything on, I'm drawing about 4-5 amps.
The computer is inside the GS case.
Old Feb 02, 2013, 10:43 AM
Qnzkrew is offline
Joined Mar 2008
alright time to start building a proper ground station. thanks for the shopping list
Old Feb 02, 2013, 11:48 AM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
Wow ! All I can say is I'm looking at my tripod based GS with all its wires and things and I don't like it anymore You guys do a great job with your GS.
carguy1994ca is offline Find More Posts by carguy1994ca
Old Feb 02, 2013, 03:25 PM
Amfamora is offline
Find More Posts by Amfamora
Multicopter Crash Tester
Amfamora's Avatar
Australia, QLD, Brisbane
Joined Apr 2012
Thats the one I have purchased to replace the 5A Regulator just to be safe..... hmm may need a stronger battery as well to be sure eh.
*edit* Done and Done
Amfamora is offline Find More Posts by Amfamora
Old Feb 03, 2013, 01:27 PM
cmavr8 is offline
Find More Posts by cmavr8
Chris
The Netherlands, NB, Eindhoven
Joined Sep 2010
All ebay mate.... 20 of those switches cost me like AU$10 and the Volt Amp displays range from AU$5 - $9 each _
Switches:
http://www.ebay.com.au/itm/130810152...84.m1497.l2649
Voltage Display..... $3... I lied :P
http://www.ebay.com.au/itm/New-2-Wir...item4ab7c5f0f5
Amfamora and techspy thanks for the links!
I had some v-meters but they weren't as pretty.
And these switches are dirt cheap... wow
kc10kevin, great link line-up. Some of the components are completely new to me (microPSU, UPS, DC-DC...). Thank you too.
cmavr8 is offline Find More Posts by cmavr8
Old Feb 03, 2013, 01:30 PM
cmavr8 is offline
Chris
Joined Sep 2010
I just tried an old 15" sony tft monitor I had laying around and it draws 2 amps at 12V... Just the monitor alone (including inverter losses).
I guess I can run the monitor + Rx + composite to VGA converter on 2 paralleled 3s2200mah packs that I have...
(Trying to set up my really cheap, first-FPV here...)
Old Feb 03, 2013, 02:19 PM
Joined Jan 2010
You bet. These were new to me as well.
Interesting it's pulling that many amps when my lcd pulls less than an amp. You can pick up a 15.6" laptop lcd on ebay pretty cheap and the conversion kits is cheap as well. Both together for probably less than $70.
Old Feb 03, 2013, 02:24 PM
cmavr8 is offline
Chris
Joined Sep 2010
Yeah... it's an old old monitor (one of the first LCDs I think)...
I can also get a 15.4 for free from old laptops, but I'm not there yet...
My first tx/rx/cam haven't even arrived yet, so I'll test them with this setup for the moment.. I should get an hour on the 3s2p pack I'll make.
Old Feb 05, 2013, 08:30 AM
elador is offline
Find More Posts by elador
Joined Oct 2011
my ground control station
I've wrote a basic line do it yourself how to post
check it out here
features of the station:
up to 2.5 hours of use on a single 12v 7Ah sla battery
secondary screen switchable between av and vga (via pc hdmi port and vga converter)
wireless connection to antenna tracker (xbee repeater, Bluetooth, 5.8Ghz)
access point modem - for multiple connection to the station (andropilot for ex)
can be easily modified and upgraded
added some pictures of the station
elador is offline Find More Posts by elador
Old Feb 09, 2013, 05:09 AM
elador is offline
Joined Oct 2011
check it out here
[IMG]http://api.ning.com/files/0TyPLysMYmZSgpSp0lCMHb27PQ2Hzzub6B7ebxq3x6622Sqkjm fAnviBueh3PZWIl1RkAbGtoeCfRNncy1XoS*vIwPWaLPDc/IMG_1205.JPG?width=188[/IMG]
[IMG]http://api.ning.com/files/0TyPLysMYmbKttBlYvBj9Eep1VOcHlVIH46ORTolf2*tYRn5c-fKn*iNJFo-2eq6lSEpxtck3wwA*1YyHqgtHAxn2dMHwMDU/IMG_1211.JPG?width=188[/IMG]
[IMG]http://api.ning.com/files/0TyPLysMYmZMjfuIz2WHxafefK9uS3kn*ksGfToQIS1QCouWIq lzXWr-lCyaVUHPDCwV-DHvJGwy*ZJ5JHe7am5CUHv7mDuy/IMG_1216.JPG?width=188[/IMG]
I made a quick temp rough sketch of the power schematics
Old Feb 10, 2013, 12:17 AM
Pukin_Dog is offline
Find More Posts by Pukin_Dog
┼tvidaberg, Sweden
Joined Jul 2008
Originally Posted by Pukin_Dog View Post
I whant it to be all in one and nothing to put together or so. It thought to be mounted on a tripod. The only thing that has to be done at field is to put on the antenna trackingsystem that is fitted with Neodyne magnets on top. Everything powered by one or two LiPo.
It will have more functions when I have thought it through completely.
This is what it looks like now. It is more or less ready. It does what it is supposed to do. I'm not sure if this is final or if I'm to gonna use an aluminium case like most do.
Instead of a helical which was the intention from the beginning I instead use a Crosshair antenna.
Pukin_Dog is offline Find More Posts by Pukin_Dog
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg FPV Talk 2 Dec 03, 2008 02:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
