Old Jan 31, 2013, 11:52 AM
elador is offline
Find More Posts by elador
Joined Oct 2011
my gcs and plane
not done yet but getting closer
I wrote a short description how to do it here
case pelican 1520
main vga screen 15"
secondary video/vga screen 5"
temp lcd - temp in and out the case
main voltage and current meter
usb hub with its on voltage/current meter
ac dc power switch with pico ups for charging the sla battery and protecting from unexpected power cut when plugged to ac
access point modem for multiple connection to the station
at top of the case xbee antenna
gcs will talk wirelessly to an antenna tracker with xbee repeater and a 5.8 or 1.3 ghz rx for live video - didn't yet choose one
and the add-on
again not done yet but getting closer had a bad luck with my motor and is now hospitalized at intensive care
elador is offline Find More Posts by elador
Old Jan 31, 2013, 01:03 PM
kc10kevin is online now
Find More Posts by kc10kevin
Lt Col, USAF, Retired
United States, IL, Swansea
Joined Jan 2010
case pelican 1520
main vga screen 15"
video/secondary vga screen 5"
temp lcd - in/out temp
and the add-on
Hi...Nice setup.
I have a similar setup but went a different way with the power distribution: http://www.rcgroups.com/forums/showp...postcount=2536
I had a couple of questions if you don't mind.
1. "usb hub with its on voltage/current meter" - Do you have a parts list for that setup? That's the only thing I haven't worked out yet.
2. "ac dc power switch with pico ups for charging the sla battery and protecting from unexpected power cut when plugged to ac" - the picoPSU actually will charge the 12V SLA battery while on AC power? I'm using Lipos, but may change things up a bit if that is a better option. It also get rid of one of my regulators (24V -> 12V).
Thanks in advance.
kc10kevin is online now Find More Posts by kc10kevin
Old Jan 31, 2013, 01:21 PM
elador is offline
Joined Oct 2011
its a 7 port usb with on/off switches
lcd voltage and current switching meter from ebay 12v to 5.3v regulator
I choose the 12v 7ah sla battery to avoid using another regulator and for balancing the case as well plus it is easier to charge and cheaper to replace yes the picoups will charge the battery all the time while connected to ac it is actually 12.8v from the ac and so the sla battery
- tried as much to avoid using regulators and to keep things as simple as I can regarding the voltage
Thanks in advance.
you very welcome
Old Jan 31, 2013, 01:33 PM
Joined Jan 2010
Thanks in advance.
USB: Thanks. I already have the 5v regulator and switch ready. I was looking to build the USB port from scratch, but this helps a bunch. Already found some options.
picoPSU setup: Looking at this: http://www.mini-box.com/picoUPS-120-...8&category=980
Says 13-18V input. I have my AC-DC convertor set at 12V output. Wondering if that would suffice or if I'd have to adjust it up some? What picoPSU are you using? 12.8V no issue with any electronics? Computer?
Old Jan 31, 2013, 01:43 PM
cmavr8 is offline
Find More Posts by cmavr8
Chris
The Netherlands, NB, Eindhoven
Joined Sep 2010
Wow, very professional setups...
Embarrassed to ask: Is there anyone using a cheap 7 inch 480x234 display for FPV?
I'm trying to find a cheap solution but they all have this crappy resolution.
I guess it will not be enough even for basic flying, will it?
Chris
EDIT: I've found someone that has it in their station but they're not flying with it...
cmavr8 is offline Find More Posts by cmavr8
Old Jan 31, 2013, 01:44 PM
elador is offline
Joined Oct 2011
oh I just bought one as it is much easier and cheaper then to build one
you can then use something like fe1.1s or similar for usb2.0 hub and then can use one of its port to connect to another fe1.1s and so on..
yeap the one I got
the 12.8 instead of 13 is just because my ac/dc convertor isn't capable of outputting 13v might hack it but it isn't really important or in my todo list
no issue all electronic comes with regulators built in and +-10% is ok and even higher but with care!
usually the problem start when the voltage is lower then required
Old Jan 31, 2013, 01:48 PM
elador is offline
Joined Oct 2011
Chris
thanks! wasn't really hard to do it
I believe you can get a 800X6/4somthing resolution for less then 50$ shipped from ebay
just ask for small discount from seller
Old Jan 31, 2013, 01:50 PM
Joined Jan 2010
yeap the one I got
Sweet! My biggest concern was the power for the ITX motherboard; didn;t want to blow it up. Thanks for the info. Of course I'm almost done with my setup and now have to change it up!!
Old Jan 31, 2013, 02:00 PM
elador is offline
Joined Oct 2011
@kc10kevin
best of luck with your overkill setup are you planning image processing with your pc?
check your pc bare when first testing the new voltage but once again shouldn't be any problem with it you might also want to check the datasheet for your pc and see the voltage range and specs
Old Jan 31, 2013, 03:33 PM
Joined Jan 2010
@kc10kevin
Thanks. I always do things that way. Anyway, the computer is pretty low power. Just going to use it for mission planning and video recording. Didn;t want to lug my laptop around as well.
Old Feb 01, 2013, 12:57 PM
Disp0sablehero is offline
Find More Posts by Disp0sablehero
United States, CA, Marine Corps Base Camp Pendleton
Joined Jan 2013
this is my ground station
unfortunately its keeping me from completing my fpv groud station at home
anybody try using tv screens usually used in cars? ive got a buddy who has about 7 screens he ripped out of a BMW he bought (previous owner pimped his own ride...) figure if anything they would be better (and cheaper in my case) than gutting a small tv bought brand new...
Disp0sablehero is offline Find More Posts by Disp0sablehero
Old Feb 01, 2013, 01:02 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
You mean the blue thing ? So you do your FPV seated...
carguy1994ca is offline Find More Posts by carguy1994ca
Old Feb 01, 2013, 01:15 PM
Joined Jan 2013
well duhhh well see whos laughing when there miles out and duty calls
were between the taxiway and landing strip sooooo that blue box was a gift seeing how it wasnt there the first week and we had no way off our site for duty
Old Feb 01, 2013, 01:49 PM
Quebec, Canada
Joined Sep 2006
LOL ! Put it in loiter mode while you...em...concentrate on something else. As long as you don't mix up your RTH
Old Feb 01, 2013, 05:39 PM
BenLimeClouds is offline
Find More Posts by BenLimeClouds
I Like Clouds Made Of Limes?
BenLimeClouds's Avatar
United Kingdom
Joined Jun 2012
Work in progress!
Just a dry run of parts!
BenLimeClouds is offline Find More Posts by BenLimeClouds
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg FPV Talk 2 Dec 03, 2008 02:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
