Old Dec 13, 2012, 05:43 PM
McCleary.11 is offline
Find More Posts by McCleary.11
McCleary.11's Avatar
United States, OH, Delaware
Joined Mar 2006
This just your standard Harbor Freight tool box with electronics fitted inside. My goal with this box was to cut down setup time at the field and to simplify the multiple battery issue for all of the items. Since I have started using this, it has made setting up not be such a PITA and time waster. Also, I now know everything is hooked up correctly without finding out after takeoff.
- 9" Phillips LCD
- 1.3 diversity receiver located to the right and left of the LCD screen
- Eagle Eyes diversity/video splitter
- FPV Japan DVR
- Fatshark Base
- Fatshark Classics (Attitude)
- Lighted switches from Radio Shack
- LCD volt meter display from Amazon
- 8amp instant fuse for safety from shorts
- 4400 3s battery (mostly used for its weight as ballast in the front)
Pic from before adding labels to the panels:
In build process: (what a mess!)
First time in use:
Night time FPV with the 450: (Xmas lights for navigation )
I would like to add a 5.8 transmitter as a relay to my goggles. It would be nice to get away from the wires when needed. Another addition would be a sun visor for the LCD. I pretty much would only use the screen for backup or for making sure the video is working, but it would be nice if I ever had any spectators.
Switch order from left to right:
Eagle Eyes/Rx1/volt meter > Rx2 > LCD > Base Goggles > 5.8 relay (to be added)
McCleary.11 is offline Find More Posts by McCleary.11
Site Sponsor
Old Dec 13, 2012, 05:50 PM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
Originally Posted by McCleary.11 View Post
First time in use:
GoPro 3 and a Penguin nice!
greedyg76 is offline Find More Posts by greedyg76
Old Dec 13, 2012, 08:13 PM
branflakes is offline
Find More Posts by branflakes
branflakes's Avatar
Joined Jan 2011
Originally Posted by bakchos View Post
My new portable ground station for winter time.
- 1280mhz patch from L-Com
- 2 x 900-1300 VRX from foxtech
- EagleEye diversity
- 5.8ghz 10mw from foxtech to relay the signal to my fatshark's
- 3300 lipo 3s (should give me 7 hours of use from my calculation)
Ready for transport
Consumption
I have a very important GS question for my 900 setup which is similar
I noticed the cable for your patch runs out the top. Mine faces the other way, cable exit down
do you think Im limiting range by having mine inverted based on this pic above? I didn't think it mattered with LP as long as it was vertically oriented.
branflakes is offline Find More Posts by branflakes
Old Dec 14, 2012, 11:34 AM
mikenc is offline
Find More Posts by mikenc
Joined Jan 2012
That looks similar to the plugs that Sherrer uses for their UHF system. Might want to check out RMRC or another place that stocks Sherrer to see if the plugs match up.
Thanks McCleary I will give RMRC a try. Nice ground station to!
Best
Michael
mikenc is offline Find More Posts by mikenc
Old Dec 14, 2012, 02:46 PM
bakchos is online now
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
Up or down is the same, the patch is linear polarized, if you have the cable to the right or left, that's not good because you will be out of polarization.
bakchos is online now Find More Posts by bakchos
Old Dec 15, 2012, 06:40 AM
Jorgemaria is offline
Find More Posts by Jorgemaria
United States, DC, D.C.
Joined Dec 2008
I finished my one. I have to do some small things but basicaly it's ready.
Jorgemaria is offline Find More Posts by Jorgemaria
Old Dec 15, 2012, 08:37 AM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
Where can i buy the tool box?
timtimtim is offline Find More Posts by timtimtim
Old Dec 15, 2012, 09:05 AM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
Home Depot.
bracky72 is offline Find More Posts by bracky72
Old Dec 15, 2012, 11:14 AM
mattthomas78 is offline
Find More Posts by mattthomas78
Crash test dummy....
mattthomas78's Avatar
United States, TN, Waynesboro
Joined Mar 2012
If you're looking for a box like the one in the previous post to yours, I got one at Harbor Frieght...
mattthomas78 is offline Find More Posts by mattthomas78
Old Dec 19, 2012, 02:52 PM
boardman is offline
Find More Posts by boardman
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
May I present the El Cheapo groundstation.
5.8 VRx - Vupoint DVR - car DVD (I use the second screen without the player) - 1250 3 cell runs everything - dowels and PVC pipe with the bottom dowel sharpened to stick in the ground - shroud made from soft black foam sheet and a bit of black foamboard
All fits in a small backpack with the rest of my gear except for the quad or plane.
I had plans to make it slicker with fiberglass tubing to hide the wires etc, but still haven't and have been using it for about a year and a half. Thought I would go ahead and post it as is, since it is different than most posted here. Very simple, but works very well.
boardman is offline Find More Posts by boardman
Old Dec 19, 2012, 02:57 PM
BayAreaCrasher is online now
Find More Posts by BayAreaCrasher
BayAreaCrasher's Avatar
Joined Feb 2011
No
- 9" Phillips LCD
- FPV Japan DVR
- Fatshark Base
First time in use:
This is awesome. I'm going to copy this with my harbor freight. Do you any more detailed pics of the inside wiring? And how did you attach the black panels to the case itself? Just with some long screws?
And what material is that black panel. Need to find some of that locally.
BayAreaCrasher is online now Find More Posts by BayAreaCrasher
Old Dec 19, 2012, 04:29 PM
marcin.gala is offline
Find More Posts by marcin.gala
marcin.gala's Avatar
Joined Jun 2010
all I need.
marcin.gala is offline Find More Posts by marcin.gala
Old Dec 19, 2012, 04:56 PM
DJO is offline
DJO
Find More Posts by DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
I bought this case here for around $30 shipped:
http://www.activepowersports.com/hob...oam-hca140402/
Turns out that the foam isn't cut on the inside for a TX so I'll start modding it soon for an FPV ground station! Overall looks good quality and latches nicely. Also has a slot/hole for a lock if needed, but no lock is included. Lots of room on the inside for my radio, RX, battery, etc. I'll be mounting the patch on the inside of the lid and propping up the lid with a ruler or something similar to orient the patch at around 45 degrees.
Should be interesting!
Dan
DJO is offline Find More Posts by DJO
Old Dec 19, 2012, 10:06 PM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
Here is my latest setup...
I used to have it in the harbor freight box...but decided that was too big and downsized...i was able to stuff everything into smaller case.
I made the screen flip out and it all mounts to a tripod..
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Dec 20, 2012, 01:29 PM
Maarten112 is offline
Find More Posts by Maarten112
Joined Oct 2012
Originally Posted by greedyg76 View Post
Why do you have so many switches and how do you remember what they are with no labels?
Ghehe I really don't know....3 are useless right now, but will probably be used in the future. I have a great memory so Iīm able to remember where the 7 switches are for....
For now I came across a little problem; I have a groundloop. When I plug out the ground cable of my 5.8 GHz receiver, the receiver still is powered and the ground signal will go from my A/V out --> Video Booster. I made a drawing of this. The blue line represents the way the ground from my Rx is able to travel.
The only way to avoid the groundloop is to interrupt the ground/earth/- of the composite cable between the video booster and my receiver, but this results in a loss of image quality.
How did you guys solve this? I donīt want to power the receiver with an other Lipo. Thanks already!
(click for a larger version)
The text at the pointing arrow is saying: "If you interrupt the earth(- , ground) the ground signal is travelling from the receiver through the booster".
Maarten112 is offline Find More Posts by Maarten112
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg FPV Talk 2 Dec 03, 2008 02:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
