Ad |
You've not seen Hogster's work then. http://www.rcgroups.com/forums/showthread.php?t=1067009 http://www.rcgroups.com/forums/showthread.php?t=1048665 http://www.rcgroups.com/forums/showthread.php?t=1047192 http://www.rcgroups.com/forums/showthread.php?t=879521 http://www.rcgroups.com/forums/showthread.php?t=940977 http://www.rcgroups.com/forums/showthread.php?t=904015 |
My very simple base station
Well my base isn't much, but it works for me. I just open it up, plug in the battery and put on the glasses. The box has all of my antennas and FPV gear inside it so it makes for easy carrying. The patch antenna is mounted on the lid and propped up at the appropriate angle.
-Alex |
Latest blog entry: Project Covert Ops: Long range ground...
Update on my Poor Man's Base Station...
Someone asked about the "Windsurfer" Antenna Reflector:
Notice the solid video at 2.1 km...I use a 200mW VTx... Here's how the base station is worn: ![]()
I'm still here....
Just lingering. ![]() My last thread kinda exploded so i quietly "walked away" and hid behind a sofa lol.. Quote:
Code:
' {$STAMP BS2}
' {$PBASIC 2.5}
'*** SETUP STUFF ***
'Attach names to I/O values
'POWER CONTROL OUTPUTS
TV PIN 15
OUTPUT TV
RF PIN 14
OUTPUT RF
'RGB LED OUTPUTS
RLED PIN 10
OUTPUT RLED
GLED PIN 9
OUTPUT RLED
BLED PIN 8
OUTPUT BLED
'SPEAKER OUTPUT
SPKR PIN 12
OUTPUT SPKR
'AERIAL STUFF
SERVO PIN 6
OUTPUT SERVO
LIGHT PIN 3
OUTPUT LIGHT
'INPUTS
PWRBUT PIN 7
INPUT PWRBUT
AERIALSENSOR PIN 2
INPUT AERIALSENSOR
'DECLARE VARIABLE TYPES
counter VAR Word
timer VAR Word
pulseCount VAR Word
x VAR Byte
ModeSet VAR Word
aerialPos VAR Word
timeDelay VAR Word
timeDelay = 5000 '5000 = 17 minutes (+/-1) 1 loop = 0.2 seconds
'*** MAIN PROGRAM ***
GOSUB AerialIn
Standby:
ModeSet = 0
GOSUB Scan
'flash white & beep
FOR x = 1 TO 4
HIGH RLED
HIGH GLED
HIGH BLED
PAUSE 5
FREQOUT SPKR, 12, 1200+(1500*x)
FREQOUT SPKR, 6, 1000+(1500*x)
LOW RLED
LOW GLED
LOW BLED
PAUSE 25
NEXT
PAUSE 50
HIGH RLED
HIGH GLED
HIGH BLED
FREQOUT SPKR, 10, 3200
LOW RLED
LOW GLED
LOW BLED
PAUSE 100
'switch colour red ---> yellow
FOR x = 1 TO 150
GOSUB Scan
PWM RLED,150, 4
PWM GLED,x, 4
NEXT
'switch colour yellow ---> green
FOR x = 1 TO 150
GOSUB Scan
PWM RLED,(150-x), 4
PWM GLED,150, 4
NEXT
'switch colour green ---> cyan
FOR x = 1 TO 150
GOSUB Scan
PWM BLED,x, 4
PWM GLED,150, 4
NEXT
'switch colour cyan ---> blue
FOR x = 1 TO 150
GOSUB Scan
PWM BLED,150, 4
PWM GLED,(150-x), 4
NEXT
'switch colour blue ---> purple
FOR x = 1 TO 150
GOSUB Scan
PWM BLED,150, 4
PWM RLED,(x/3), 4
NEXT
'repeat
GOTO Standby
'*** SUB ROUTINES ***
Scan:
'scan sensors & buttons
IF PWRBUT=1 THEN ChangeMode
IF AERIALSENSOR=1 AND aerialPos = 0 THEN GOSUB AerialOut
IF AERIALSENSOR=0 AND aerialPos = 1 THEN GOSUB AerialIn
RETURN
ChangeMode:
'switch operation mode
IF ModeSet = 0 THEN Mode1
IF ModeSet = 1 THEN Mode2
IF ModeSet = 2 THEN ShutDown
IF ModeSet = 3 THEN Mode1
Mode1:
'Green Mode:
ModeSet = 1
timer = 1
'initiate button acknowledgement
'turn off stuff that shouldnt be on
LOW RF
'Turn on TV
HIGH TV
GOSUB BeepCommand
GOSUB Scan
LOW RLED
LOW GLED
LOW BLED
PAUSE 250
' beep & flash into mode green
FOR x = 1 TO 15
GOSUB Scan
PWM GLED,x*10, 5
PWM RLED,150-(x*10), 5
FREQOUT SPKR, 5, (3000+(x*200))
PAUSE 8
NEXT
GOSUB Scan
GOSUB BeepConf
'#---CYCLING---#
CycleR:
HIGH GLED
PAUSE 50
GOSUB Scan
IF timer = timeDelay THEN AutoShutdownR
PAUSE 50
GOSUB Scan
PAUSE 50
GOSUB Scan
timer = timer + 1
GOTO CycleR
AutoShutdownR:
LOW GLED
FOR x = 1 TO 20
HIGH RLED
FREQOUT SPKR, 10, 4800
PAUSE 40
LOW RLED
PAUSE 100
HIGH RLED
PAUSE 40
LOW RLED
IF PWRBUT=1 THEN GoBackToR
PAUSE 100
PAUSE 100
PAUSE 100
PAUSE 100
NEXT
GOTO ShutDown
GoBackToR:
GOSUB BeepConf
timer =1
GOTO CycleR
Mode2:
'Blue Mode:
ModeSet = 2
timer = 1
'turn on RF
'Turn on TV
HIGH TV
GOSUB BeepCommand
GOSUB Scan
LOW RLED
LOW GLED
LOW BLED
PAUSE 250
HIGH RF
' beep & flash into mode blue
FOR x = 1 TO 15
GOSUB Scan
PWM BLED,x*10, 5
PAUSE 8
NEXT
GOSUB Scan
GOSUB BeepConf
'#---CYCLING---#
CycleM:
HIGH BLED
PAUSE 50
GOSUB Scan
PAUSE 50
IF timer = timeDelay THEN AutoShutdownM
PAUSE 100
GOSUB Scan
timer = timer + 1
GOTO CycleM
AutoShutdownM:
LOW BLED
FOR x = 1 TO 20
HIGH RLED
PAUSE 40
LOW RLED
PAUSE 100
HIGH RLED
PAUSE 40
LOW RLED
IF PWRBUT=1 THEN GoBackToM
PAUSE 100
PAUSE 100
PAUSE 100
PAUSE 100
NEXT
GOTO ShutDown
GoBackToM:
GOSUB BeepConf
timer =1
GOTO CycleM
ShutDown:
'Power down to standby mode:
ModeSet = 3
GOSUB BeepCommand
LOW RLED
LOW GLED
LOW BLED
PAUSE 250
'Shut Telly servo and ramp LED & beep
FOR x = 1 TO 20
GOSUB Scan
PWM RLED,x*7, 5
PWM BLED,150-(x*7), 5
FREQOUT SPKR, 5, (6000-(x*200))
PAUSE 8
NEXT
PAUSE 120
GOSUB Scan
LOW RF
LOW TV
FOR x = 1 TO 20
FREQOUT SPKR,25-x, 2500-(x*90)
PAUSE 5
GOSUB Scan
PWM RLED,150-(x*7), 5
NEXT
PAUSE 100
FREQOUT SPKR,20, 1800
FOR x = 1 TO 50
PWM RLED,150-(x*3), 5
NEXT
PAUSE 100
FREQOUT SPKR,70, 1500
FOR x = 1 TO 50
NEXT
'delay before re-entering standby
FOR x = 1 TO 200
GOSUB Scan
PAUSE 100
NEXT
GOTO Standby
'SOUND EFFECTS
'Beep Command issued
BeepCommand:
'reset colours
LOW RLED
LOW GLED
LOW BLED
HIGH RLED
HIGH GLED
HIGH BLED
FREQOUT SPKR, 30, 4650
PAUSE 30
LOW RLED
LOW GLED
LOW BLED
PAUSE 30
IF ModeSet = 1 THEN rFlash
IF ModeSet = 2 THEN mFlash
IF ModeSet = 3 THEN pFlash
rFlash:
HIGH GLED
FREQOUT SPKR,30, 4870
PAUSE 50
LOW GLED
GOTO continue
mFlash:
HIGH BLED
PAUSE 50
LOW BLED
GOTO continue
pFlash:
HIGH RLED
PAUSE 50
LOW RLED
GOTO continue
continue:
PAUSE 200
HIGH RLED
HIGH GLED
HIGH BLED
FREQOUT SPKR,20, 4870
LOW RLED
LOW GLED
LOW BLED
RETURN
'Beep Confirmation task complete
BeepConf:
'reset colours
LOW RLED
LOW GLED
LOW BLED
HIGH RLED
HIGH GLED
HIGH BLED
FREQOUT SPKR, 30, 3260
LOW RLED
LOW GLED
LOW BLED
PAUSE 40
HIGH RLED
HIGH GLED
HIGH BLED
FREQOUT SPKR, 20, 4800
LOW RLED
LOW GLED
LOW BLED
RETURN
AerialIn:
'double check
FOR x = 1 TO 4
HIGH RLED
LOW RLED
PAUSE 200
IF AERIALSENSOR=1 THEN RETURN
NEXT
'close
AerialInCont:
FOR x = 1 TO 15
HIGH RLED
PULSOUT SERVO, 520
PAUSE 20
LOW RLED
PAUSE 20
NEXT
DEBUG "Aerial Socket Closed", CR
LOW LIGHT
aerialPos = 0
RETURN
AerialOut:
'open
'beep warning about to open
FOR x = 1 TO 10
HIGH RLED
LOW RLED
PAUSE 50
IF AERIALSENSOR=0 THEN RETURN
NEXT
HIGH LIGHT
FOR x = 1 TO 15
HIGH RLED
PULSOUT SERVO, 1150
PAUSE 20
LOW RLED
PAUSE 20
NEXT
DEBUG "Aerial Socket Open", CR
aerialPos = 1
RETURN
(not to mention the fact that i make things like this just to see if i can and to challenge myself. As a result, i learnt loads of stuff that i didn't know before, and for me, this hobby is all about that!!) The other thing, is that i found when using my ground station, because it was all integrated, i never forgot anything.... Everything is in the case, so i didn't have to go through a massive checklist before leaving the office to make sure i had all the stuff i needed for the job... Anyway, enjoy.. Cheers |
| Thread Tools | |
| Discussion Show us your FPV / RVP ground Base set up in action | Trackercal | Video Piloting (FPV/RPV) | 94 | Nov 05, 2010 10:21 AM |
| Discussion Show Us Your FPV Helo Set Up | Trackercal | Video Piloting (FPV/RPV) | 2 | May 11, 2009 11:05 PM |
| Gallery Show us your Ground equipment setup | a9amg | Video Piloting (FPV/RPV) | 2 | Dec 03, 2008 02:47 PM |
| go on show us your avatars | mudlark | Life, The Universe, and Politics | 105 | Dec 19, 2007 07:23 PM |
| Show us your choppers! | sneu | Electric Heli Talk | 23 | Dec 30, 2001 10:50 AM |
