Old Apr 13, 2012, 09:42 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
you might try some of the PC modding e-stores as well.... like Xoxide.com Performance-PCs.com or MNPCTech.com
great source of wire sleeving, switches, meter and such
Adidas4275 is offline Find More Posts by Adidas4275
Old Apr 14, 2012, 10:28 PM
KellyFPVER is offline
Find More Posts by KellyFPVER
I love to be above the clouds
Joined Aug 2011
my thomas 7 watt UHF booster with yagi and 1.2G lawmate receiver with 13dbi yagi on my badass tracker controlled by RVGS tracker GS 4s 16.8v max worm gear drive motor for tilt can handle up to 20 lbs of antennas and gear
http://military.flightdisplay.com/pr...descreen-lcd-5
KellyFPVER is offline Find More Posts by KellyFPVER
Old Apr 16, 2012, 02:42 PM
L14m is offline
Find More Posts by L14m
L14m's Avatar
Joined Apr 2009
Almost finished putting together my mark 2 ground station flight case. I've reduced the size of the case to slightly bigger than an A4 piece of paper. It has a Sata 2.5" hdd dvr and a 4 way video / audio splitter with amp to take the incoming signal to the monitor (9") ,dvr and a separate out put for goggles. There's a small LCD for voltage information. Just a couple more bits to do and she's finished.
Fpv Ground station mark 2 (3 min 0 sec)
Regards Liam
L14m is offline Find More Posts by L14m
Old Apr 17, 2012, 05:17 AM
RCPtero is offline
Find More Posts by RCPtero
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Liam,
That looks great! I love the clean design!
Tom
RCPtero is offline Find More Posts by RCPtero
Old Apr 17, 2012, 11:39 AM
L14m is offline
L14m's Avatar
Joined Apr 2009
Cheers just tried to keep it as simple as possible although I'm still trying to get a work around on my ez tracker working with lawmat 1.2!
Liam
Old Apr 17, 2012, 11:53 AM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
http://www.youtube.com/watch?v=Y1NWsvZedBQ
Regards Liam
Ill give you 10 quid for it?
badlands is offline Find More Posts by badlands
Old Apr 17, 2012, 12:26 PM
L14m is offline
L14m's Avatar
Joined Apr 2009
Cheers Martin lol
Old Apr 17, 2012, 03:30 PM
The Flying Farmer is offline
Find More Posts by The Flying Farmer
^Its what I do^ - FPVholic
The Flying Farmer's Avatar
United States, NY, Walker Valley
Joined Nov 2007
L14m
That gs is so nice! What did use for the cover material?
Got a link?
The Flying Farmer is offline Find More Posts by The Flying Farmer
Old Apr 17, 2012, 03:36 PM
L14m is offline
L14m's Avatar
Joined Apr 2009
Cheers just put a search in on the bay for carbon fibre vinyl. I got a roll 300mm x 1000mm for £5. It's self adhesive and you simply use a heat gun or hair dryer to get it in tight corners. This was my first attempt , also if you have a problem you simply peal back and relay it.
Liam
Old Apr 18, 2012, 07:25 AM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Regards Liam
Do you have a link to the screen you are using ?
- Kim -
SpookiePower is offline Find More Posts by SpookiePower
Old Apr 18, 2012, 10:41 AM
L14m is offline
L14m's Avatar
Joined Apr 2009
I bought the screen from Maplins UK about a year ago so unsure if it's still made as these things are constantly upgraded. It's a Nikkai tv 9".
Liam
Old Apr 18, 2012, 12:17 PM
chaosdestro0 is offline
Find More Posts by chaosdestro0
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
I think I remember seeing that one in maplins a couple of days ago, but I just bought a 8" off Dealextreme that is fine with bluescreen
https://www.dealextreme.com/p/pl8006...245?r=62963823
chaosdestro0 is offline Find More Posts by chaosdestro0
Old Apr 18, 2012, 12:46 PM
Chairwolf is offline
Find More Posts by Chairwolf
I think it'll work this time!!
Chairwolf's Avatar
399 feet above Roanoke, VA
Joined Jan 2007
Liam
Looks like they still carry them:
http://www.maplin.co.uk/9-inch-wides...-and-sd-280976
Bob
Chairwolf is offline Find More Posts by Chairwolf
Old Apr 18, 2012, 01:12 PM
L14m is offline
L14m's Avatar
Joined Apr 2009
Yeh only difference is I paid £99
Old Apr 18, 2012, 03:03 PM
wannabe is offline
Find More Posts by wannabe
At peace with his albatross
wannabe's Avatar
United States, CA, Vacaville
Joined Oct 2003
Originally Posted by simplyfly View Post
The system is powered using 4 3s 5000mAh lipo's. A car lighter adapter on an extension allows me to connect to the car. An intelligent Dc to DC regulator allows me to regulate 5 independent DC outputs from 5 to 36V > 10A. This USB programed regulator basically enables me to power 5 separate DC devices in this range. Virtually any DC component you can think of x5. I use the regulator to power the video Rx, and GCS data modem. I purchased the DC Regulator here: http://www.mini-box.com/DCDC-USB [/I]
Can you describe how you get 5 seperate outputs from the DCDC-USB unit? I only see two outputs on that.
-Todd
wannabe is offline Find More Posts by wannabe
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg FPV Talk 2 Dec 03, 2008 02:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
