Espritmodel.com Heli Air
Old Apr 06, 2012, 03:49 PM
Norway
Joined Feb 2012
Originally Posted by SpookiePower View Post
Do you have a link to where you bought that lcd monitor ?
- Kim -
I bought it used for 500 NOK (about 85$). It is named UNITED, so if you google you will find it.
RemiWM is offline Find More Posts by RemiWM
Old Apr 06, 2012, 08:48 PM
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, CA, San Ramon
Joined Oct 2002
Below are photos and specs of my older 1280 GS and my newly built 5.8 mini GS.
1280 GS specs:
Custom albumin case with:
~ Two +8db 1.2Ghz patch antennas
~ Two telescoping camera booms holding the patch antennas
~ Two 1.2Ghz Video RXs
~ Two 4000mah 3s lipo batteries in parallel
~ Two 12v Buck Inverters to power the VRXs and Diversity
~ Eagle Eyes Ground Station for video Diversity
~ Digital Voltmeter display panel for battery status
~ Three video, audio and 12v output for goggles, laptop, etc
~ Haier 10.2" LCD TV (runs off 12v)
5.8 GS Specs:
~ Pelican case "clone" #5 from Fry's Electronics
~ CarbonBird.com FPV DVR with screen
~ 5.8Ghz video RX with CarbonBird.com clover leaf antenna
~ Fat Shark 922 goggles
~ 5000mah 3s lipo
~ lipo cell monitor w/ alarm
~ Hobbkyking 5v UBEC (to power the DVR)
~ Camera tripod to hold the station up off the ground
crazyj is offline Find More Posts by crazyj
Old Apr 08, 2012, 03:44 AM
I love to be above the clouds
Joined Aug 2011
I just added the RVGS to my ground station . so nice to have tracking again. the RVGS is being powered off my ground stations two sealed lead acid 12AH batteries throu a plug I made with an old 3s balance plug that fits into the RVGS .
KellyFPVER is offline Find More Posts by KellyFPVER
Old Apr 08, 2012, 04:08 AM
L14m's Avatar
Joined Apr 2009
Hi KellyFPVER have you tested the rvgs for tracking and diversity and if so how did you find it?
Liam
L14m is offline Find More Posts by L14m
Old Apr 08, 2012, 08:28 AM
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
does the tracker works with only RVOSD?
nakelp86 is offline Find More Posts by nakelp86
Old Apr 08, 2012, 02:45 PM
Joined Aug 2011
Liam
its the best damb system I have ever tried ! both tracking and diversity work better then most out there . the Happy killmore GS part of it we are still waiting on a up date for . and yes it only works with the RVOSD because thats what overlays the hidden line of video that it uses to send all the data.
diversity is so clean and tracking is right on target and can be very fast! pluse its as easy as 123 to set up and just fly.
Old Apr 09, 2012, 12:40 PM
United Kingdom, England, Leicester
Joined Feb 2009
Here is my humble effort completed today.
Only thing you can't see is a connector towards the base on the side of the case that I plug the Fatsharks into.
Final upgrade will be to transmit the 2.4 vid signal on to the goggs via 5.8Ghz. Sure will look odd having a case set down somewhere with a tracking antenna spinning on top!
tesco is offline Find More Posts by tesco
Old Apr 09, 2012, 08:06 PM
2Vision-Air
bakchos's Avatar
Blainville, Quebec, Canada
Joined Aug 2009
My ground station V2
Let me share my ground station V2 ;
After getting 2.4 for video on my planes i needed 1.2 for my quad because i am flying on 2.4, so i had to make it all together.
  • Home depot case with recycled laser level tripod
  • 5A 12volt sealed pb batt
  • EagleEye diversity
  • 2x 1.2ghz video rx
  • 2x 2.4ghz video rx
  • 1 patch and 1 omni for each frequency
  • frequency select switch
  • vupoint recorder
  • 5.8ghz 20mw vtx to send image to fatshark's
  • external audio/video jacks
  • 7" liliput lcd monitor recycled from old CarPc project
  • switch to select onboard power or outboard using the back plug and extension cable with cig plug
Let the pictures talk for themself ;
bakchos is online now Find More Posts by bakchos
Old Apr 09, 2012, 10:43 PM
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
looks nice!
Adidas4275 is offline Find More Posts by Adidas4275
Old Apr 09, 2012, 11:50 PM
Multi Rotor Maniac
Stunt Double's Avatar
Joined Oct 2007
Does look good, i like the twin frequency setup too.
Stunt Double is offline Find More Posts by Stunt Double
Old Apr 10, 2012, 12:22 AM
Better then Sliced Bread!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I plan on doing led switches on my setup, I am curious... are you just using raw power being fed through it for the lighting? I've noticed some switches have separate leg for LED and some don't, also anyone have a good link for cheap led switches? Everywhere local is around $3 to $12 each.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Latest blog entry: Flying in the Neighborhood
Old Apr 10, 2012, 04:13 AM
Joined Oct 2010
Great platform tesco!! How about the pan-tilt system on the side of the case. Can you post more detailed images?
Thanks!!!
Regards...
ssancho is offline Find More Posts by ssancho
Old Apr 10, 2012, 07:06 AM
Joined Feb 2009
Thanks!!!
Regards...
No problem, its just 2 x 360 winch servos, one is hotglued to the side of the case. The other is hotglued onto the servo arm so it can be pushed on when setting up.
Plenty of power in them to move the antenna.
Old Apr 10, 2012, 08:46 AM
Joined Oct 2010
Thanks tesco!!! Really great and economical idea. Probably I'll copy it, if you're agree
Regards...
Old Apr 10, 2012, 09:31 AM
Joined Feb 2009
Regards...
So long as you know I own the worldwide patent
Discussion Show us your FPV / RVP ground Base set up in action Trackercal Video Piloting (FPV/RPV) 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal Video Piloting (FPV/RPV) 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg Video Piloting (FPV/RPV) 2 Dec 03, 2008 02:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
