Old Mar 24, 2012, 08:23 PM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
Based on the Juz backpack ground station design he posted, I decided to try one for myself. I used an old laptop/camera bag I was no longer using which worked out great. The bottom camera compartment holds all the wires and the Eagle Eyes along with my goggles and spare batteries. The Middle slot holds my radio then doubles for the patch holder once setup. The laptop slot holds the patch and tripod VRxs. Take it all out and setup in a couple of minutes. Very portable!
Plus the backpack stands up by itself because of the bottom camera pocket, nice!
2 Cheap Digital VRx
1 Omni for 1280
1 Patch tuned to 1280
Eagle Eyes Diversity
Fatshark Base goggles
Dx8 RC Radio w/Chainlink UHF LRS
FPV Japan SD Card DVR
All powered by 3000Mah 3s battery, except the DVR.
Here are some pics:
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Mar 27, 2012, 10:37 PM
tonkajeep34 is online now
Find More Posts by tonkajeep34
NTX Helidillos
tonkajeep34's Avatar
USA, TX, McKinney
Joined Sep 2009
That's pretty cool. I think I'm going to have to setup something like that. Are you just propping the patch up against the leg of the tripod?
tonkajeep34 is online now Find More Posts by tonkajeep34
Old Mar 27, 2012, 11:43 PM
aka Helidaho
Joined Jun 2010
Actually because of the firm base of the backpack it stands up on its own and I just prop the patch up inside the middle sleeve. It works pretty well and is very portable not to mention a quick setup and teardown.
Paul
Old Mar 30, 2012, 07:20 PM
signflyer is offline
Find More Posts by signflyer
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
I finally found a mounting solution I'm pretty happy with: two cafeteria trays that mate together pretty securely
signflyer is offline Find More Posts by signflyer
Old Mar 30, 2012, 07:23 PM
paintz2007 is offline
Find More Posts by paintz2007
Guess Who's Back? :D
paintz2007's Avatar
Joined Sep 2006
what school do you go too, imma send the lunch lady a link :P
paintz2007 is offline Find More Posts by paintz2007
Old Mar 30, 2012, 07:26 PM
2^p - 1
signflyer's Avatar
Joined Feb 2003
I'm a teacher, and the custodians and cafeteria staff are good people
Old Mar 30, 2012, 07:42 PM
paintz2007's Avatar
Joined Sep 2006
My KISS GS works good for up to 1 km i dont typically fly further cause quite frankly i don't wanna walk further to retrieve my plane..
Old Apr 02, 2012, 10:37 PM
KellyFPVER is offline
Find More Posts by KellyFPVER
I love to be above the clouds
Joined Aug 2011
Originally Posted by Taiping View Post
Here's mine
1x Lawmate 1.2ghz RX
1x Turnigy 3S 1600mah Lipo
1x 5.8ghz 10mw VTX (GS Relay)
1x 1280mhz 7.5dbi Helical Antenna
ok lets see the recorded video with this helix antenna
KellyFPVER is offline Find More Posts by KellyFPVER
Old Apr 03, 2012, 02:53 AM
Wirewolf903 is offline
Find More Posts by Wirewolf903
FPV ADDICT
Wirewolf903's Avatar
United States, TX, Austin
Joined Jan 2011
AP/FPV Witespy VC-550 Naza FC Ground Station
Here's my GS. I wanted something I can just grab and go for Arial Photography without any setup to mess with. I have a pair of Headplay goggles I use but find this setup is better for my solo AP/FPV needs.
Neck worn Ground Station:
9" Sylvania with internal battery(Walmart.com) LCD monitor
Dual 900mhz RX with breezecom fiberglass Omni antenna (this antenna seem to pick up signal better in builds and through obstructions) and 900mhz scanner antenna(this antenna purchased at radio shack seems to get better range)
RangeVideo diversity
3 3c 2200mah lipo for RX x2 and diversity
Plexiglas base
Weight 5.5lbs
Wirewolf903 is offline Find More Posts by Wirewolf903
Old Apr 03, 2012, 03:00 AM
FPV ADDICT
Joined Jan 2011
Like the ACU camo!
Old Apr 03, 2012, 05:34 AM
PinDuke is offline
Find More Posts by PinDuke
I can fly this plane
Kingdom of Sweden, Gävleborg County, Sandviken
Joined Jan 2012
Looks a bit heavy to carry around your neck for any longer period of time.
I am also building a fully portable GS since I am not a fan of the suite case/tri pod versions.
PinDuke is offline Find More Posts by PinDuke
Old Apr 03, 2012, 05:45 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
5.8ghz is the way to go for reducing weight
msev is offline Find More Posts by msev
Old Apr 03, 2012, 08:37 AM
BJM-Maxx is offline
Find More Posts by BJM-Maxx
BJM-Maxx's Avatar
Joined Sep 2007
Does your 9" screen have static or blue screen? It looks nice and small.
BJM-Maxx is offline Find More Posts by BJM-Maxx
Old Apr 03, 2012, 01:59 PM
FPV ADDICT
Joined Jan 2011
The screen stays with static as long and the signal is being sent. Once signal stops the screens show black screen. It stays with the static to where I have flown with a very bad picture but still able to see where I was. This monitor has a built in battery that runs about 6 hours on a single charge.
Old Apr 03, 2012, 02:25 PM
FPV ADDICT
Joined Jan 2011
It weighs right at 5.5lbs. It's not bad at all around the neck. I have a shoulder harness for it but it's a little more involved putting on. With my flights lasting 10-15 min each I like the quick on off and mobility of this setup. I fly a mixture of LOS and FPV. Also makes the AP very easy when you can see the picture your recording in he gopro Liveview. I love to fly over and around building and trees where at first approach is LOS then once out of view I switch to FPV. This makes it lots easier flying in unfamiliar areas and not being restricted to open fields.
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg FPV Talk 2 Dec 03, 2008 02:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
