Old Oct 17, 2009, 01:38 AM
Joined Apr 2008
RCLander new modified 90mm EDF set testing video
Dear All,
Attached is our new modified 90mm EDF set testing video for sharing with you. The modification step is added a new small size metal fan between the motor and main blade for increasing the ventilation performance in order to protect and raise the motor performance. The small size metal fan can be let the fresh air coming in from the new metal rear tube and pass through the motor out from the front window with the thrust air under the negative pressure during operation. It is shown a very well result and able support to take 8S power for 90mm size edf. This time I take a lower kv amount(1280kv) motor (same size as the 6S version) and use 8S power to make the test. This modification will be applied to the existing 6S 90mm version and coming 120mm 12S version.
I hope above to be solved some concern regading of the motor issue from our customer. If you have any question, please feel free to contact us.
Hope you like it.
Best regards,
Tim
Tim Wan is online now Find More Posts by Tim Wan
Old Oct 17, 2009, 08:07 AM
lefabdusud's Avatar
Fribourg - Switzerland
Joined Aug 2008
Hello Tim,
This is a great progress, I will be pleased to try it once available !
I spent many time trying to identify an 8S motor which could fit your 90mm EDF.
Could you let me know what are the motor reference you used, or a list or preferred motors for 8S setup ?
Also, I would appreciate to get the following, for the 90mm EDF :
- the max diameter of the motor
- the distance between fixing holes
- the type of screw required
Fabien
lefabdusud is offline Find More Posts by lefabdusud
Old Oct 17, 2009, 09:09 AM
Faster!
Joshua Wesley's Avatar
United States, NV, Sparks
6.77 lbs of thrust at just shy of 2000 watts of power, how does this stack up against the competition?
Do you know the eflux velocity?
Joshua Wesley is offline Find More Posts by Joshua Wesley
Old Oct 17, 2009, 10:43 AM
lutach's Avatar
New Jersey
Joined May 2004
Nice video. I learned a thing watching it and I'll use it for my car application.
lutach is offline Find More Posts by lutach
Old Oct 17, 2009, 10:50 AM
United States, LA, Bossier City
Joined Aug 2008
Things were getting pretty toasty after the airflow was removed! Wonder where the temp tops out?
BadClams is offline Find More Posts by BadClams
Old Oct 17, 2009, 06:22 PM
BadPilot
badpilotto's Avatar
United States, IL, Downers Grove
Joined Nov 2007
Tim,
What were the temperature of the same setup prior to the modification? I see the temp was hitting 62-68C.
John
badpilotto is offline Find More Posts by badpilotto
Old Oct 17, 2009, 11:10 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
tim i hate to say it, but that 120mm version blade sure looks like...err...looks exactly like a turbax rotor. thats not cool unless you got permission from JHI to use it.
corsair nut is offline Find More Posts by corsair nut
Old Oct 22, 2009, 09:01 AM
T-28 Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
SUBscribing....
For those that have the old 90mm 6s motors/fan setup, is there a way to upgrade it? If so, where do we order those parts and how much?
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Oct 29, 2009, 12:11 PM
T-28 Fanatic
Joined Jul 2008
How about an answer Tim.
Old Oct 29, 2009, 01:24 PM
Joined Apr 2008
Upgrade of our 90mm edf
Dear skyline_g35,
The upgrade version 90mm edf will be expected to launch on or before end of next week. Since we are stilling waiting the new upgrade spare parts which will be received on early of next week.
You can contact EJF to place your pre-order first. If you have any question, please feel free to contact us.
Thanks for your interesting and supporting our products.
Best regards,
Tim
Old Dec 03, 2009, 10:52 PM
T-28 Fanatic
Joined Jul 2008
I feel like your skirting around the question.
For those that have the 6s setup, are you going to be offering us the ability to purchase the 8s motor for our existing fans?
I would like a answer to this question. Thanks!
Build Log Falcon 120 Wing...NEW Twin 90mm flight video link in post #127...181mph!! Knife Liddle Electric Ducted Fan Jet Talk 448 Jun 04, 2012 11:58 PM
Video RCLander Mig 17 Gear Doors System testing video Tim Wan Electric Plane Talk 9 Oct 07, 2009 01:39 AM
Discussion F/A-18C NEW starmax 70mm EDF VIDEO Andy chen Foamy EDFs 2 Aug 23, 2008 01:25 PM
Video F-16 90mm EDF on board flight video TGoodwin Electric Plane Talk 10 Jul 22, 2007 10:01 AM
New modified T-Hawk video Hauntme13 Parkflyers 1 May 23, 2004 05:49 PM
