Old Oct 16, 2009, 11:59 PM
specriv is offline
Find More Posts by specriv
United States, CA, Walnut Creek
Joined Mar 2005
losi 1/24 micro crawler
http://www.radiocontrolzone.com/showthread.php?t=257337
Micro Rock Crawler RTR
The Micro Rock Crawler RTR is unlike any crawler youíve ever seen. First, itís the smallest crawler around. And second, itís the first Micro vehicle to have a radio system with Spektrum 2.4GHz DSM technology. That means you can run it wherever you want without any interference. It also means you wonít need as many batteries.
Measuring under 6 inches, the Micro Rock Crawler can pretty much crawl anywhere. You can run it on the couch, over your keyboard, and almost any place outside. The 1/24 Micro Rock Crawler RTRóitís small in size and big on fun.
Features
* Integrated DSM receiver/ESC combo
* Metal worm gears (eliminate the need for a special ESC)
* 4-link suspension
* Low-profile solid axle housings
* Molded telescoping driveshafts
* Micro transmission designed for low motor mounting
* Molded skid plate for transmission
* 3-wire micro crawling servo
* Powerful micro motor
* Chrome beadlock-style wheels
* Realistic soft-compound micro Rock Claw tires
* Twin vertical plate (TVP) aluminum chassis design
* NiMH battery and charger
* Fully decorated micro tuber-style body
Specs
Type:Rock Crawler
Scale:1/24
Length:5.85 inches (148.6mm)
Width:3.5 inches (86.36mm)
Wheelbase:4 inches (101.6mm)
Weight:6.63 oz (188g)
Chassis:Twin Verticle Plate (TVP)
Suspension:4-Link
Tire Type:Micro Rock Claws
Radio:Losi Radio System with Spektrum 2.4GHz DSM Technology
Batteries:4.8V 150mAh 4-Cell NiMH
Charger:Portable Alkaline Charger
Kit/RTR:Ready-to-Run
Body:Tuber-Style Rock Crawler Body in Blue or Black
Needed to Complete
Nothing! Everything is inlcuded.
LOSB0236 - 1/24 Micro Rock Crawler RTR - $149.99
Micro Rock Crawler Bind-N-Drive (BND)
The Micro Rock Crawler Bind-N-Drive (BND) is unlike any crawler youíve ever seen. First, itís the smallest crawler around. And second, itís the first Micro vehicle to have a radio system with Spektrum 2.4GHz DSM technology. That means you can run it wherever you want without any interference. It also means you wonít need as many batteries.
Measuring under 6 inches, the Micro Rock Crawler can pretty much crawl anywhere. You can run it on the couch, over your keyboard, and almost any place outside. The 1/24 Micro Rock Crawler BNDóitís small in size and big on fun.
Features
* 4-link suspension
* Realistic compound micro Rock Claw tires
* Twin Vertical Plate (TVP) aluminum chassis design
Product Specifications
Type:Rock Crawler
Scale:1/24
Suspension:4-Link
Radio:Losi Receiver with Spektrum 2.4GHz DSM Technology (Transmitter not inlcuded)
Batteries:4.8V 150mAh 4C NiMH
Kit/RTR:Bind-N-Drive
Body:Tuber-Style Rock Crawler Body in Gun Metal Grey or Green
Needed to Complete
Surface DSM Transmitter
LOSB0236BD - 1/24 Micro Rock Crawler Bind N Drive - $119.99
specriv is offline Find More Posts by specriv
Old Oct 17, 2009, 04:29 AM
LexusIS300 is offline
Find More Posts by LexusIS300
Illonois
Joined Oct 2007
http://www.youtube.com/watch?v=mG7uDoKNmZA
LexusIS300 is offline Find More Posts by LexusIS300
Old Oct 17, 2009, 04:35 AM
Illonois
Joined Oct 2007
i was working on a brushless micro t that still needs alot of new parts as is built from left over looks like im skiping that and making this brushless. is there a converter i can use to turn the brush output to brushless?
Old Oct 17, 2009, 05:20 PM
LMF5000 is offline
Find More Posts by LMF5000
67,000rpm
Malta, Balzan
Joined Oct 2009
No, there is no convertor that will allow you to connect a brushless motor to a brushed speed controller. Your only option is to buy a new brushless ESC (unless you already have one!).
The reason is that the output from a brushed ESC is just a DC voltage (actually if you wanted to be really accurate, it's a high frequency square wave whose pulse width varies with throttle position, but the motor and capacitors tend to smooth it into a practically constant voltage DC output...). A brushless ESC outputs a three-phase waveform from the three wires. The voltage in the wires is synchronised with the position of the motor's rotor, so the voltage in the wires is always being changed while the motor is spinning. The faster the motor spins, the faster the voltage in the wires has to change in order to keep up (i.e. the frequency of the output voltage increases). In a brushed motor the ESC simply supplies a constant voltage. All the voltage switching in sync with the rotor position is done by the commutator.
So basically unless you use some seriously complicated electronics like a VFD (variable frequency drive), you can't convert a brushed ESC's output to run a brushless motor. A real brushless ESC the easiest, cheapest and most reliable option
LMF5000 is offline Find More Posts by LMF5000
Old Oct 17, 2009, 06:59 PM
Illonois
Joined Oct 2007
theres a convertor for the vapor brick that does that brush to brushless but thats for planes and i seen bunch for planes but never for cars. i have everything for brushless just want to keep the dsm option. also i assume that the mini lst2 dsm tx will work with this
Article Losi 1/36 Micro Trucks Featuring the Micro-Baja Review Michael Heer Micro Cars 20 Aug 14, 2013 11:23 PM
Discussion Losi 1/18 Mini Crawler echoplanar Rock Crawlers 81 Mar 29, 2010 03:00 PM
Discussion Is the model Team Losi 1/36 Micro Baja RTR outdated already? RC Boat Guide Micro Cars 1 Jun 15, 2008 01:42 AM
Sold 2 Week Old Team Losi 1/32 Micro T Desert Truck Monstermanhbf Cars - Cars and Parts (FS/W) 0 Jan 31, 2008 09:48 AM
Discussion 1/24 scale crawler mgt714 Micro Cars 3 Aug 17, 2006 12:57 AM
