This thread is privately moderated by Darth_Elevator, who may elect to delete unwanted replies.
Old Oct 16, 2009, 02:49 PM
Darth_Elevator is offline
Find More Posts by Darth_Elevator
How do I change this text?
Darth_Elevator's Avatar
The Beautiful Mountains of Utah
Joined Oct 2006
Zak Yak info
I'm posting this information here so I can find it easily when I need it. Most of the following information is from Carlyle's post, with a few things that I added.
Zak Yak
Zak-Yak (1 min 3 sec)
Components and build guide for the Zak Yak a.k.a. Yak 55
Credit for the Yak 55 goes to LeadFeather of RC Groups. The link to his
builder guide is as follows:
http://www.rcgroups.com/forums/show... postcount=2818
LeadFeather's posts also contains full size drawings is you desire to cut your
EPP components.
Recommended components:
Motor
HXM2730-1500 HexTronik 24gram Brushless Outrunner 1500kv
ESC
TowerPro 9g 12 Amp ESC
Prop
Prop GWS 8x4
Servos (3)
HXT500 HexTronik 5g / .8kg / 10sec Micro Servo
Battery
R360-20-2 Rhino 360mAh 2S 7.4v 20C Lipoly Pack
Carbon Fiber (Destination Hobby)
CF for elevator is a 1/16" rod.
CF for wing is a 1/8" tube.
Glue
Gorilla clear Polyurethane
Welder's Glue - We were unable to find Welder's Glue locally but Levier
found a similar product that worked well for us. It is made my Loctite
and the name is NO MESS. I believe he found this glue at the Ace
Hardware store in Syracuse.
This glue is used for the control surface hinges and works similar to
hot glue hinges but is lighter as well as easier to work with.
Build tips
I recommend cutting out the servo slots before gluing the fuselage pieces together. I didn't do it, so I had to cut them out later. It's only a minor inconvenience to cut them out after, but it's something to avoid if you want to simplify the build.
Darth_Elevator is offline Find More Posts by Darth_Elevator
Old Feb 07, 2010, 01:23 PM
Rockin G is offline
Find More Posts by Rockin G
If It Aint Broke,I'll Break It
Rockin G's Avatar
United States, TX, Lockhart
Joined Dec 2008
Cliff, do you know if this is 1.3# or 1.9# EPP, or should I get ahold of Carlyle?
Rockin G is offline Find More Posts by Rockin G
Old Feb 08, 2010, 11:29 AM
Joined Oct 2006
Sorry, dude, I do not know. My guess is that it's 1.9# because I think that's what he had on hand when he was cutting Remix wings.
Discussion Hyperion 120 yak info?! losinground Sport Planes 27 Sep 08, 2006 01:57 PM
