Old Oct 16, 2009, 03:29 PM
EQMOD is offline
Find More Posts by EQMOD
EQMOD's Avatar
Joined Mar 2008
Walkera 4#3B: Bell Hiller 45 Degree flybar conversion using CB100 Bell Mixers
Ok first of all, who is the good samaritan ? I just got a package from the mail without the name of the sender. Its a CB100 Bell mixer set;
UPDATE: The links were from Cameron (Ampdraw) - Thanks Amp!!
It contains the two mixers, two brass bushing and two small screws. I decided to use this for a 45 degree flybar conversion on a bell hiller modded Walkera 4#3B head.
The ball links need to be placed on the other side for this mod;
EQMOD is offline Find More Posts by EQMOD
Old Oct 16, 2009, 03:31 PM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
and viola!, with the mixers in place;
and as assembled on the 4#3B head;
A short test flight / hover video;
Walkera 4#3B : 45 degree flybar using CB100 bell links - hover (1 min 15 sec)
and some hard cyclics;
Walkera 4#3B : 45 degree flybar using CB100 bell links - cyclics (1 min 14 sec)
Old Oct 16, 2009, 03:35 PM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
The only issue i have with this setup is the angle of the pitch links coming from the swash it is so slanted that they pop-off on extreme cyclics;
Results:
- Phase is maintained
- I cant see much on stability as they feel the same with the 90 degree version.
Old Oct 16, 2009, 08:29 PM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
i think it would be possible to bend that link so as not to stress the ball-link on the swash side.
Old Oct 16, 2009, 09:18 PM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
Do you prefer the 90* head or the 45? Must get around to locking and shortening the flybar on my b/h 4#3B. The measurement of the flybar you gave in the other thread...http://www.rcgroups.com/forums/showp...4&postcount=23
was that the raw bar length?
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Oct 16, 2009, 09:30 PM
lazer155 is offline
Find More Posts by lazer155
lazer155's Avatar
Phoenix, Arizona
Joined Jan 2009
Did you lock your flybar at 45*?
lazer155 is offline Find More Posts by lazer155
Old Oct 16, 2009, 09:38 PM
dcapi is offline
Find More Posts by dcapi
Joined Apr 2008
How is the stability compared to a standard 4#3?
dcapi is offline Find More Posts by dcapi
Old Oct 16, 2009, 10:25 PM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
Amp
Actually, after flying it some more, i noticed that i am issuing less cyclic corrections as compared to the 90 degree version. The initial videos was pretty much a quick test. But one thing important is that the blade phasing was not affected (stick to roll,elevator direction not affected) which means i dont have to shift those servos.
Yes, its the raw bar length.
Old Oct 16, 2009, 10:35 PM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
The flybar is as is - and it remained in phase with the phasing fork. The only thing that was shifted was the head ;
Old Oct 16, 2009, 10:45 PM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
The standard 4#3 uses a longer flybar, mine was a short one when i performed the test thus i cannot compare them. However if am to compare it with the 90 degree short flybar version (which is my default config), definitely there is some improvement (but not significant) as there are less cyclic corrections needed to keep it in spot - but not the MSR 45 degree flybar stability i am expecting.
Alert The ULTIMATE, PHASING-CORRECT ,~45 flybar 4#3B Bell head mod (aka Bell/Hiller Mod) robZulu Micro Helis 281 May 29, 2011 05:46 PM
Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head EQMOD Micro Helis 13 Sep 02, 2009 12:15 AM
Sold Walkera 4#3b without 4in1 $45 shipped LOWERED PRICE HeliStyle Aircraft - Electric - Helis (FS/W) 1 Jan 12, 2009 11:09 AM
Discussion WALKERA 4#3 BELL HILLER MOD Project - For AGILE/Minimal Delay Cyclic response EQMOD Micro Helis 96 Dec 23, 2008 10:42 AM
Discussion flybar on the walkera 4#3b? wishawhunk Micro Helis 2 Aug 12, 2008 04:58 PM
