Old Oct 16, 2009, 08:23 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Link
E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others
Way back on 10-7-09 I received my Blade mSR which now has over 90 flights on it. It took me a week to get around to testing the two 120 and 4 110 mAh cells I purchased with it due to not having the necessary super small connectors on hand.
The OEM 4 Bay charger has a 300 mA output per bay (2.5C) which while fast is most likely very hard on the cells. I chose a 1 amp. discharge rate as this would equal an approx. 6 min. flight which is the norm for many. The 3.2 volts cut off point was chosen as the cells recover to 3.7 in a few minutes ,same as after a 5 min. flight for me.
Included attachment of my modified OEM charger.
How to adjust charge rate pots
http://www.rcgroups.com/forums/showp...9&postcount=24
Update: Charging 4 Eflite 110 mAh cells at once . LiFePO4 no load 6.64 / min. voltage 6.43 / Peak load 1.27 Amp. / 403 mAh consumed.
Post by jj604 on many 110-138(?) batteries
http://www.rcgroups.com/forums/showp...&postcount=489
and here
http://www.rcgroups.com/forums/showp...&postcount=491
10-22-09 Added Graph Eflite 120 and Hyp CX 120 . CX 11-1/2 min. charges at .6A (5C)
11-7-09 Initial Flightmax 138 mAh flight test here
http://www.rcgroups.com/forums/showp...8&postcount=21
Charles
Old Oct 16, 2009, 10:02 AM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
Charles - nice, thanks for the results. Good to see the specs. are relatively accurate and the 120s really offer increased capacity. I wonder how those $2 plugs from HC compare. They claim 138mAh, and we all know that must be accurate since it is not rounded off to 140 (kidding).
Do you or does anyone else know where to pick up some of those tiny mCX/mSR/ParkZone Vapor connectors for the charger side of things?
- David
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Old Oct 16, 2009, 11:18 AM
Southern Pride
Hobby King has some JST- XH extensions listed , 5 for $1.98. I have heard they are OK but have not seen any in person. I have read that the Zippy flightmax 138s are sub par and only provide approx. 4 min flights when new and go down hill extremely fast especialy if flown to LVC.
May prove to be waste of money but I ordered some of the extensions and the super cells . At the very least I will be able to anounce to the world that I have tested Zippys.
JST- XH extensions
Old Oct 16, 2009, 11:51 AM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Hey Charles - In another thread I thought I saw where you and others agreed that charging at 2 or 3C was not detrimental to LiPo's. Are these tiny cells different?
feathermerchant is offline Find More Posts by feathermerchant
Old Oct 16, 2009, 12:04 PM
Southern Pride
Oh goodie another opitunity for a great debate.
I have charged Thunder Powers at 3c for years ,the ProLites were the first cells to use stacked construction. Hyeprion G use what I believe David called folded stacked or roll folded or some such term. It all gets very confusing at times. In another thread Charlie stated that E flite cells and othe cells under 320 mAh were most likely rolled constuction and charging at greater than 1c would shorten their life.
Hyperion G3 CX 120 cells are rated for 5C charging same as the ret of the G cells.
Charlie Wang's , Mr. Thunder Power post
http://www.rcgroups.com/forums/showp...59&postcount=7
Dave ,Mr. AC World / Hyperion post.
http://www.rcgroups.com/forums/showp...7&postcount=17
Charles
Old Oct 16, 2009, 12:26 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
So the answer to my question above is 'Yes'
Old Oct 16, 2009, 12:38 PM
Southern Pride
If you are asking if I think charging these E-flite 110-150 mAh cells at 2 to 2-1/2 C is good for then my answer is no. IMO E-flite LiPolys have most always been fairly low quality at best but then many believe all LiPolys are created equal.
Why would E-flite design and calibrtae a charge that would shorten the life of the LiPloys? Consumer preference same as Everyready,Sanyo,Ray O Vac and other NiMH AA / AAA producers. Consumers do not want to have to wait 12 Hrs. to charge their batteries.
Note for those who missed it. E flite charger is adjustable from approx. 70 to 360 mA per bay and TME 4 cell strip turns on slot into a 1 to 5 cell slot which means 1 at nonimal 300 mA,2 at 150ea. 3at 100 ea. (1c) etc.
Charles
Old Oct 16, 2009, 08:32 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Hi Charles; great info as usual!
Is the output of the A123 knocked down at all, or used full tilt/volts?
I did the single cell charger mod ( http://www.rcgroups.com/forums/showthread.php?t=955310 ) and got these results with variuos voltages/sources ( http://www.rcgroups.com/forums/showp...3&postcount=68 ):
jrb is offline Find More Posts by jrb
Old Oct 16, 2009, 09:08 PM
Southern Pride
I use them with no regulation. They hold over 6 v. for around 8 cells then start droping slowly . After around 15 they are down to around 5.5 and I can tell the charge rate is slowing. This is better than the D cells do from what I have read. I mostly use the wall PS and use the LiFePO4 when I go outside to fly 6 or 8 flights or so.
I read in a thread on Helifreak where someone used a 6V BEC and a 3S 2200 mAh LiPolys which fits inside but LiFePO4 are just so simple and I have plenty laying around.
Note the 2S LiFePO4 pack I am using happens to be two very old tired cells that are not A123 System ones and only deliver 1900 mAh or so.
If I can remember I will fly 4 of my cells down and place Inspector wattmeter in-line and see how many mAh are being pulled from the pack.
Charles
Old Oct 17, 2009, 08:12 AM
Charlie Wang is offline
Find More Posts by Charlie Wang
Joined Dec 2002
Quote from another thread:
"The vast majority of the RC lipo on the market till now use an internal construction arrangement called "stacked". This results in quick-response delivery of high C rates, relatively low cost of production, and a relatively light battery. However, life-cycle performance is relatively poor with the stacked arrangement, and cells tend to drift faster (ie imbalance in a pack)".
1) "Stacked" construction delivery of high C rates= True
2) Relatively light battery= True, that is why Thunder Power prolite is the prefer battery for 3D flying, F3A competition, F3C competion, UAVs.
3) life cycle performance is relatively poor= False, totaly misleading.TP ProPower has the best life-cycle performance.
4) "stacked" cells tend to drift faster (ie imbalance in a pack)= False, TP prolite pack is known for maintaining cell balance for a long time, still unmatch by others.
5) "Stacked" cell is relatively low cost of production= False, "Stack" construction is the highest cost in production, it provide the above advantages over all other construction technique.
Advantages of Thunder Power "Stacked" construction over other construction technique: High C rates( both charging & discharging), lightest weight, best performance & cycle life, stay balance.
I have charged Thunder Powers at 3c for years ,the ProLites were the first cells to use stacked construction. Hyeprion G use what I believe David called folded stacked or roll folded or some such term. It all gets very confusing.......
Charles
Charlie Wang is offline Find More Posts by Charlie Wang
Old Oct 17, 2009, 01:02 PM
Southern Pride
Updated post # 1 with following data.
Charles
Old Oct 19, 2009, 12:38 PM
Rumple is offline
Find More Posts by Rumple
Ignint McNugget
Rumple's Avatar
behind Jaggi lines
Joined Jan 2004
- David
David,
Glenn2626 sells them.
Rumple is offline Find More Posts by Rumple
Old Oct 22, 2009, 10:31 AM
Southern Pride
Added graph with Hyp CX 120 to post #1.
Charles
Old Oct 22, 2009, 10:53 AM
Joined Dec 2006
Thanks Rumple.
And Charles, looking forward to the results comparison from HC. I ordered some more packs from there for comparative purposes myself recently, it will be interesting to see how they stack up. I've also been thinking about caving in and getting an mSR, it seems everyone in the hangar nearby has one for their winter heli flying fix.
- David
Site Sponsor
Old Oct 22, 2009, 11:04 AM
Southern Pride
Two weeks and 122 flights on mine so as you can guess it really do not care to fly it much.
Last week my son was over the weather was nice and I had cut my local flying field but we choose to stay home and fly the mSR,go figure.
Charles
Found E-Flite Power 25 or 32 New, Used, Not Abused dlazarus6660 Aircraft - Electric - Power Systems (FS/W) 0 Apr 13, 2008 07:42 AM
Found E-Flite Power 32 New or Slightly Used countrygentleman Aircraft - Electric - Power Systems (FS/W) 1 Feb 25, 2008 08:56 AM
Wanted E-Flite Power 32 New or Slightly Used countrygentleman Aircraft - Electric - Power Systems (FS/W) 0 Feb 03, 2008 03:39 PM
Wanted E-Flite Power 32 New or Slightly Used countrygentleman Aircraft - Electric - Power Systems (FS/W) 2 Jan 25, 2008 06:45 PM
Wanted WTB E-flite Park 400 outrunner New or Used slowracing Aircraft - Electric - Airplanes (FS/W) 2 Sep 12, 2005 10:31 AM
