Old Oct 29, 2009, 09:26 PM
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
We normally use z-bends everywhere, but you could use ez-links on your aileron servo arm to make them easier to set. They add a little weight but it may be worth it.
RJ
hpapilot is offline Find More Posts by hpapilot
Old Oct 29, 2009, 10:09 PM
Esprit Model Team Pilot
wcc963's Avatar
Joined May 2006
RJ
i dont think 2 mini ez connectors would be much of a weight penalty at all
wcc963 is offline Find More Posts by wcc963
Old Oct 30, 2009, 02:14 AM
Horizon Hobby Employee
3D-Seth's Avatar
Champaign, IL
Joined Jan 2007
You would be surprised. Saving a few of those everywhere, added up with little tiny other things you do...saves a good amount of weight.
3D-Seth is offline Find More Posts by 3D-Seth
Old Oct 30, 2009, 02:20 AM
3D-Seth's Avatar
Champaign, IL
Joined Jan 2007
hey do you guys use the standard Z-bend or mini e/z connectors? i used the Z-bend on my Yak but had some problems getting the ailerons set evenly when the servo is centered... i know mini e/z connectors would solve this problem
How are you doing this?
Here's what I do:
Cut Carbon rods to length for both ailerons.
Make 4 Z-Bends, total length of the piece after the Z-bend about 1" long
Cut some heat shrink so that it will slide over the carbon and the Z-bend rod.
Slide the heat shrink over the carbon rod, then over the Z-bend rod, making sure the Z-bend is just off the edge of the carbon (on both sides of the carbon rod).
Shrink the heat shrink.
Pull 1 Z-bend rod out of 1 side of each carbon rod.
Insert 1 Z-bend into your servo arm, and one into the control horn.
Turn on the transmitter/airplane
Center your aileron servo
Slide the Z-bend that was removed from the heat shrink, back into the heat shrink where it was originally.
The heat shrink does not hold the carbon rod/Z-bends steady, you have to glue them, so shorten/lengthen the rod as needed.
Glue over each side of the carbon rod where the Z-bends attach.
Voila, perfectly centered ailerons.
Seth
Old Oct 30, 2009, 11:30 AM
Fast and getting faster!
Albany County, New York, United States
Joined Jul 2003
I have to agree with Seth, I was a believer in the plastic ez links as well, but then I tried the z bend method on a vrolet about 2 yrs ago, and was amazed at just how much they actually can weigh. the z bend method works, just have to make sure the carbon is cut right, I had cut the carbon 2 short once before at 11:00pm before a day of flying with no hobby shops open on sunday.
FASTALJR is offline Find More Posts by FASTALJR
Old Oct 30, 2009, 12:58 PM
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
I lock the surface in place using these simple jigs, that way they're always centered when you heat shrink the last piece. The strange material is something called balsa that we used in another life.
Azarr
Azarr is offline Find More Posts by Azarr
Old Oct 30, 2009, 01:36 PM
Joined Dec 2007
Azarr,you make too much work for yourself.I simply use a peice of tape.
stickbanger is offline Find More Posts by stickbanger
Old Oct 30, 2009, 02:07 PM
hpapilot's Avatar
Joined Nov 2006
I usually use a similar set of jigs, but mine are just made of 3mm depron with the center shim crushed down a little so it is a tight fit. They do make linkages easier to set up.
RJ
Old Oct 30, 2009, 02:38 PM
is it flying time?
Jerry Combs's Avatar
Wyandotte Oklahoma
Azarr
I too use a jig very much like this one, I still ended up with a slight (less than 1/32") sag in my surfaces. I need to make a new jig to allow for this or find a better way of bending my Z-bends to make them a little closer fitting.
Jerry Combs is offline Find More Posts by Jerry Combs
Old Oct 30, 2009, 08:51 PM
Resident giant scale guru
my c210's Avatar
Picayune, MS
Joined Oct 2007
what?!?!?! No feather light option?
my c210 is offline Find More Posts by my c210
Old Oct 30, 2009, 10:53 PM
hpapilot's Avatar
Joined Nov 2006
If you mean milled, it makes it too light. This plane is at its optimum weight unmilled with a stock setup, between 5 and 5.5 oz. Trust me... I've flown them all the way down to around 4 oz... haha.
Old Oct 30, 2009, 11:50 PM
3D-Seth's Avatar
Champaign, IL
Joined Jan 2007
Azarr
I've actually found the surfaces to sag slightly when I use a jig. I don't use one any more, there's normally enough friction in the heat shrink that keeps the rod from moving, so I get it centered, with no sag.
Seth
Old Oct 31, 2009, 04:10 PM
Joined Oct 2009
Got my MX2 built today, waitning on motor and esc to arrive. I plan on going to the JR indoor festival next weekend so I might have to let Seth or RJ wring it out
rcmaster12 is offline Find More Posts by rcmaster12
Old Oct 31, 2009, 04:14 PM
hpapilot's Avatar
Joined Nov 2006
Nah, you have to wring it out yourself with us!
I've got 2 more on the build table right now, so I might just be bringing 4 MX2's with me...
Old Oct 31, 2009, 06:57 PM
Joined Oct 2009
K sounds good have to wrok on them rollinig harriers anyway!
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
