Old Oct 28, 2009, 07:10 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
Originally Posted by rcmaster12 View Post
Actually RJ, I did some experimenting with the futaba JST connectors on a satelite reciever off my AR9100. If I am not mistaken, those are the same kind of JST plugs that spektrum uses for their AR6300. I was able to get the futaba conector in there, though it did take some moving around to do. Also, there was a gap between the futaba connector and the inside of the plug, though the fit was tight.
NOT the same plug.
If I'm not mistaken, they're wired differently too...
3D-Seth is offline Find More Posts by 3D-Seth
Old Oct 28, 2009, 07:13 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
They are definitely both wired differently and different connectors. However, you ca just swap pins to fix the polarity, so if you got the connectors to fit rcmaster, that's pretty cool!
hpapilot is offline Find More Posts by hpapilot
Old Oct 28, 2009, 08:08 PM
rcmaster12 is offline
Find More Posts by rcmaster12
Joined Oct 2009
yeah I noticed the polairty thing, I guess I'm confused why spektrum would do this. Oh well its no big deal. A little off-topic, but you will be competing in IMAC this spring right Seth?
rcmaster12 is offline Find More Posts by rcmaster12
Old Oct 28, 2009, 08:42 PM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
More than likely. Depends on college though. Thats priority once I start it!
Old Oct 28, 2009, 09:20 PM
Joined Oct 2009
cool are you going to be in the NC region or where you are going to fly near where you are going to college? Im pretty close to you actually, I live in cleveland.
Old Oct 29, 2009, 06:11 AM
FASTALJR is offline
Find More Posts by FASTALJR
Fast and getting faster!
Albany County, New York, United States
Joined Jul 2003
Got mine yesterday, very nice kit, I did have to ask, did u guys use the carbon all the way up to the nose???? I was thumbing thru the instructions and was curious. Now just waiting on the GF for her design, and then let the paint fly!!!!!!!!!!!!
FASTALJR is offline Find More Posts by FASTALJR
Old Oct 29, 2009, 06:50 AM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Yes, I designed it that way to keep the fuse as rigid as possible and keep the nose from torquing with fast power changes. It isn't totally necessary to run the trussing up past the wing bracing, but for the small weight penalty I think it's worth the stiffness.
Post pictures when you get started on it!
RJ
Old Oct 29, 2009, 08:40 AM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
Yup, should be. I'll either be here in Ohio, or somewhere else in the NC region.
Old Oct 29, 2009, 01:16 PM
stickbanger is offline
Find More Posts by stickbanger
Joined Dec 2007
RJ,could you explain to me how you mounted the MAMO unit to the Hacker motor? Also,are you using a 2 cell or 3 cell pack?
stickbanger is offline Find More Posts by stickbanger
Old Oct 29, 2009, 01:57 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
The A20-34S mounts to the back of the firewall with 2 screws with the shaft sticking out the front. Then, the Mamo prop hub attaches to the shaft with a set-screw. The Mamo unit should have pretty good instructions for installation, though honestly I never read them...
And, I'm using a 2S pack.
RJ
Old Oct 29, 2009, 02:53 PM
bighead93 is offline
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
I have the following (From my first FF Yak-55)
AXI 2203-46 - CC10ESC
3 Eflight S60
and a bunch of 2S 300-450's. How would that do?
bighead93 is offline Find More Posts by bighead93
Old Oct 29, 2009, 03:19 PM
Joined Oct 2009
Cool Seth sounds good. BTW, you may remeber me as Edgeman form realflight
Old Oct 29, 2009, 03:31 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
3 Eflight S60
That should work just fine! The only exception is the aileron servo, the S60 will probably get blowback, but it will work...
RJ
Old Oct 29, 2009, 06:54 PM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
Ah okay. Cool!
Old Oct 29, 2009, 09:19 PM
wcc963 is offline
Find More Posts by wcc963
wcc963's Avatar
United States, FL, Pompano Beach
Joined May 2006
hey do you guys use the standard Z-bend or mini e/z connectors? i used the Z-bend on my Yak but had some problems getting the ailerons set evenly when the servo is centered... i know mini e/z connectors would solve this problem
wcc963 is offline Find More Posts by wcc963
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
