Old Oct 24, 2009, 10:29 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Cool Mike!!
The kits are set up for pushrods. Modifying it for pull-pulls wouldn't be hard if you chose to, but the CG is perfect with the rods.
hpapilot is offline Find More Posts by hpapilot
Old Oct 24, 2009, 10:30 PM
FASTALJR is offline
Find More Posts by FASTALJR
Fast and getting faster!
Albany County, New York, United States
Joined Jul 2003
ok cool, will prolly set them up with the rods then, i may try one with the vpp setup later this winter! Now I have to get masks cut and order up me some paint.
FASTALJR is offline Find More Posts by FASTALJR
Old Oct 24, 2009, 11:46 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
Joined Jan 2007
Originally Posted by louu
hey seth should i put jr185's or jr188's on the rudder and elevader??? imm gona run to the lhs now and order em.
thats what I run on the tail. 188s.
Seth
3D-Seth is offline Find More Posts by 3D-Seth
Old Oct 25, 2009, 07:08 PM
sideways312 is online now
Find More Posts by sideways312
3D flyin
sideways312's Avatar
rochester hills MI
If anybody is interested the Vpp system that was used on the MX-2 is available from airlandseahobby.com
sideways312 is online now Find More Posts by sideways312
Old Oct 27, 2009, 05:10 PM
rcmaster12 is offline
Find More Posts by rcmaster12
Joined Oct 2009
I ordered my MX2 on sunday and I cant wait to get it so that the building can begin. I read through the online manual and it loooks like a really fun build. Just wondering, how long is each of the ETOC freestyle sequnces supposed to be? (ex: each of the XFC freestyle sequences are supposed to be 4 min.)
rcmaster12 is offline Find More Posts by rcmaster12
Old Oct 27, 2009, 06:40 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
ETOC freestyles are limited to 2 minutes... not much time to meet the criteria!
RJ
Old Oct 27, 2009, 06:42 PM
quazar1 is offline
Find More Posts by quazar1
Joined Feb 2007
Variable pitch setup
RJ what do you use for the variable pitch setup on the MX2 you had at KIEF 2009?
Tony
quazar1 is offline Find More Posts by quazar1
Old Oct 27, 2009, 06:46 PM
Joined Oct 2009
Thanks for the response, should get my MX2 tommorow!
Old Oct 27, 2009, 06:54 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Tony
Tony, I use the Mamo Models system. You can order it from www.airlandseahobby.com . They're the only ones importing them anymore.
RJ
Old Oct 28, 2009, 01:11 AM
flyerj66 is offline
Find More Posts by flyerj66
Joined Aug 2009
Originally Posted by hpapilot
It's been a long time coming, and I am now proud to introduce the Fancy Foam MX2!
I just built the first printed kit last night, and kits will be in production and for sale next week. The color scheme is based on my airbrushed MX2 that I flew at ETOC this year. Take a look!
RJ
where can I find info on the set up to allow stopping in the downhill vert/ nosedown hover etc.
flyerj66 is offline Find More Posts by flyerj66
Old Oct 28, 2009, 07:05 AM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
My VPP setup is posted several places in the thread. Basically you need the Mamo Models VPP system and a Hacker A20-34S motor.
Old Oct 28, 2009, 03:05 PM
wcc963 is offline
Find More Posts by wcc963
wcc963's Avatar
United States, FL, Pompano Beach
Joined May 2006
what motor do you recommend?
the A10-9L or the A20-34S?
wcc963 is offline Find More Posts by wcc963
Old Oct 28, 2009, 03:56 PM
Joined Oct 2009
I have a couple of futaba S3114m with the micro connctor laying around that I was going to use in my MX2. I wanted to buy the spektrum AR6300, does anyone know if the futaba connector will fit into the spektrum reciever?
Old Oct 28, 2009, 04:16 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
For VPP, you need to use the A20-34S. The A10-9L will not mount to the VPP unit.
For normal flying, I suggest the A10-9L.
No, they do not. Though they look similar, they are not the same connectors. You'd need to change the connectors to use the Spektrum receiver, or use the Futaba receiver with the correct plugs.
RJ
Old Oct 28, 2009, 08:03 PM
Joined Oct 2009
Actually RJ, I did some experimenting with the futaba JST connectors on a satelite reciever off my AR9100. If I am not mistaken, those are the same kind of JST plugs that spektrum uses for their AR6300. I was able to get the futaba conector in there, though it did take some moving around to do. Also, there was a gap between the futaba connector and the inside of the plug, though the fit was tight.
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 06:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 04:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 11:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 08:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 09:28 AM
