Old Dec 26, 2012, 09:10 AM
kevinjulieevan is offline
Find More Posts by kevinjulieevan
kevinjulieevan's Avatar
United States, TN, Maryville
Joined Dec 2010
Originally Posted by Boogie3D View Post
thanks. i actually have that dvd. bought it last year and the aj slick build video and forgot i had the foamie build dvd with it. just found it in a box
kevinjulieevan is offline Find More Posts by kevinjulieevan
Old Dec 29, 2012, 07:27 PM
Ducati Mechanic is online now
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
One of my Xmass presents to my self, was a MX2, three,HS35HB's, a Hacker A10, and a new Castle9..
My two season old Osiris, has been reduced to group flights....
Im looking forward to having a fresh, and Light MX-2 in the hanger, for the rest of this years indoor season.
So far the build is very clean, and straight forward. Very sharp plane!
Ducati Mechanic is online now Find More Posts by Ducati Mechanic
Old Dec 29, 2012, 08:09 PM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Nothing like a fresh build.
motorhead is offline Find More Posts by motorhead
Old Dec 29, 2012, 10:55 PM
RickC2009 is offline
Find More Posts by RickC2009
RickC2009's Avatar
USA, NY, Brookhaven
Joined Mar 2003
Nice, want to sell the Osiris?
Rickc
RickC2009 is offline Find More Posts by RickC2009
Old Dec 30, 2012, 04:52 AM
Joined Oct 2008
No way! You cant have this one! As you saw,I grove with it ..
It still flies incredibly, And will leave my hanger the way it came in.. in pieces..
Old Dec 30, 2012, 09:05 PM
Joined Oct 2008
Making good progress! I did change the landing gear set up a bit, but other than that everything looks great! The way the directions have you do the landing gear seemed too complicated? I've had good luck with assembling fancy foam gear this way in the past.. I also Crossed over a few carbon fiber braces and wrap them with Kevlar thread for extra Strength.
Old Jan 02, 2013, 08:54 PM
Joined Oct 2008
Spades???
To spade or not to spade? That is the question!
Okay guys Almost done with my build, and I have a quick question. I've had minimal experience with spades, I did put them on a edge that I had, and didn't really like the way it handled. are they must have with this airframe? Or is it one of those things that's designed to help someone get used to the fact that a profile plane doesn't dip into a corner?
Do experienced pilots use them?
Old Jan 03, 2013, 01:59 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
I am not a good pilot, but I do consider myself intermediate and well experienced.
I did not try flying it without them, so I have no true comparison; but I have flown with them and it was sooo perfect. Once I had my CG, mine required no mixing, had no coupling, and was just perfect.
I am curious how it flies without, post up if you give it a try.
RJ will likely chime in here, I would believe he tried the MX2 without them during the development of this plane and he might be able to shed some light in terms of a direct comparison.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Jan 03, 2013, 02:00 AM
USA, GA, Atlanta
Joined Nov 2008
BTW~ Your MX2 looks awesome!
Old Jan 03, 2013, 08:38 AM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Spades all the way! I fly them on all of my MX's. It'll fly fine without them, but it will sit a little differently in the air and you'll need a different CG to eliminate knifeedge coupling. This airplane is tuned for those spades and it should have no coupling at what I consider the correct CG. Give them a try!
That landing gear setup will work just fine too. I just prefer to mount the gear legs to the back side of the gear leg strip, as I think it makes the gear a bit more stable. It's really your preference though!
RJ
hpapilot is offline Find More Posts by hpapilot
Old Jan 03, 2013, 09:04 AM
Joined Oct 2008
Thanks!
RJ
Thanks for the Input RJ!
Spades it is.. Cant wait to huck this one!
Old Jan 22, 2013, 02:05 PM
Joined Dec 2010
mx2 maiden
finally got around to putting this plane together. only two flights so far. my son really likes it. here is a short video clip of the initial hover test. hope to do some airbrushing now and and record some outdoor flights when the weather improves. this is the first indoor type plane i've built and it was not as hard as i thought it would be. i even did the pull pull rudder and i think that's easier than running a pushrod!
Mx2maiden (0 min 43 sec)
Old Jan 22, 2013, 03:32 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Looks good. Now you need a skycart to make use of that skate ramp!
Old Jan 22, 2013, 05:33 PM
Joined Oct 2008
Looking good guys!! I was able to get a full night of indoor flying in with mine, and it's a gem! flys great, Very Precise..
Old Jan 22, 2013, 05:51 PM
Joined Dec 2010
yes a sky cart is on our list for future foamie projects. recorded two outdoor flights of the mx2 this afternoon. one flight is on a two cell and the second flight is on a three cell. i'm going to attempt airbrushing tomorrow!
Fancyfoammx2 (8 min 35 sec)
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
