Old Dec 06, 2012, 03:28 AM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
If you are using the surgical tubing bands you can double them up to hold the prop on better.
motorhead is offline Find More Posts by motorhead
Old Dec 06, 2012, 02:11 PM
darknrgy is offline
Find More Posts by darknrgy
darknrgy's Avatar
Joined Mar 2012
That's the plan, thanks! I'm actually not entirely sure I have the motor on correctly. I had to make some space for the shaft to fit into the fuselage as it sticks out some distance. Then the prop goes directly onto the motor with no other parts supporting it except the bands. It fits on snugly and is well balanced but it just seems to lack some structure. Good for a crash I suppose. Does this make sense? Would a pic help?
darknrgy is offline Find More Posts by darknrgy
Old Dec 06, 2012, 02:34 PM
Neil_SC is offline
Find More Posts by Neil_SC
Joined May 2004
I also had the prop come undone on my maiden and it really shook the plane. I just put on a second o-ring and everything was fine. Also make sure that the prop fits snugly on the motor with no slop. If the hole in the prop is too big, it will obviously cause vibration as if the prop was out of balance. And make sure the prop doesn't fit too snugly on the motor. You should be able to deflect the prop and let go and it should easily spring right back to position perpendicular to the shaft. If it's too tight, the prop won't spring back perpendicular to the shaft and that will also cause some good vibration.
Neil_SC is offline Find More Posts by Neil_SC
Old Dec 07, 2012, 08:36 AM
tacdriver is offline
Find More Posts by tacdriver
tacdriver's Avatar
United States, CO, Fort Collins
Joined Dec 2010
I had my Hacker stutter so bad, it actually broke the X mount and ripped out of the tape. This was with a Hacker ESC too. I just swapped in the backup mount, and make it a point to not take so long bumping up the idle on my tx. It stutters very badly otherwise. Everything is stock out of the box settings on the ESC.
tacdriver is offline Find More Posts by tacdriver
Old Dec 10, 2012, 09:47 PM
BladeScraper is offline
Find More Posts by BladeScraper
Custom User Title
Joined Jun 2011
Hey, I am planning to get one of these but I can't decide which servos to use.
I have:
-Hitec HS-55 (x2)
-Spektrum S75 (x2)
-TowerPro SG-90 (x1)
-TowerPro SG-50 (x1)
I don't know what to use. I measured up the hS-55's and Spektrum S75 and they weight the same, 8g. Now it's just a matter of torque. Anyone used either of those for this?
BladeScraper is offline Find More Posts by BladeScraper
Old Dec 10, 2012, 10:53 PM
Free is online now
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
I have used the HS-55s they work good. They are slow, but have a lot of torque.
That's my experience.(now I use s3114!)
Free
Free is online now Find More Posts by Free
Old Dec 11, 2012, 05:31 AM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
If you are not trying to build a feather light one I recommend (3) Fut. S3114.
Old Dec 11, 2012, 08:09 AM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
I recommend Futaba S3114's or S3154's (the digital version) either way. 3114's are not much more expensive and will far outperform the other options!
hpapilot is offline Find More Posts by hpapilot
Old Dec 11, 2012, 10:51 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
+1 to the Futaba Servos- they are hands down my favorite servos in that size.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Dec 11, 2012, 04:55 PM
Custom User Title
Joined Jun 2011
I am definitely trying to go as light as possible. I will use the HS-55's until I can afford the Futaba S3114's. Are the HS-55 and Futaba S3114 about the same size?
Old Dec 11, 2012, 05:12 PM
Free is online now
Free's Avatar
Joined Jan 2012
Yes
Old Dec 11, 2012, 05:31 PM
Custom User Title
Joined Jun 2011
awesome
Old Dec 13, 2012, 02:03 PM
3171scott is offline
Find More Posts by 3171scott
3171scott's Avatar
United States, OH, Youngstown
Joined Apr 2011
Futaba 3114 are 14.99 at my LHS. compaired to HS 55's they are WAY better. If you have to use HS servos i would go with the HS 45's. same price ae the futaba but better than the 55
3171scott is offline Find More Posts by 3171scott
Old Dec 13, 2012, 10:23 PM
Custom User Title
Joined Jun 2011
Okay, since I was considering the HS-45's I may as well go with the Futaba S3114. They sound great, and I want light but strong. It seems these servos can offer that. However, did you need to get bigger control arms for the servos to get the amount of throw for 3D or do the stock ones do it just fine? I mean, I want a huge amount of throw on these...
Old Dec 14, 2012, 07:34 AM
3171scott's Avatar
Joined Apr 2011
You should only need a 1 to 1 ratio. If you know how to set up and program properly stock should do fine. 1 to 1 means that whatever length the control horn is that what the servo length should be. Full end points and properly centered servo arms will get you the throws you need. Use an offset differential arm for ailerons. Remember, if you put a long arm on the servo you actually cut your torque down.
Also it takes one hell of a 3D pilot to actually be able to keep up with RJ’s MX2 with huge throws. You don’t have over throw this plane, it’s a great plane.
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
