Old Sep 23, 2012, 11:08 PM
roberted5 is offline
Find More Posts by roberted5
Joined Nov 2009
Will S3114 servo arms give enough throw?
Right angles fall right on the aileron push-rods from spline screw by using pre-cut control horn slots on the MX2 and last hole in the x-long servo arm that comes with the S3114's.
Do the servo arms from the S3114's give the MX2 enough throw?
roberted5 is offline Find More Posts by roberted5
Old Sep 24, 2012, 09:04 AM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Yes, they sure do give you enough throw, however you really should use an offset arm such as the ones from Radical RC to get proper geometry there. I'm not sure how you could get 90deg angles with a straight arm... the control horns on the ailerons are much further apart than the length of the servo arm that comes with the S3114. I use the RadicalRC .625" offset arm and typically use the second hole from the bottom. This gives me proper aileron differential (zero).
hpapilot is offline Find More Posts by hpapilot
Old Sep 24, 2012, 10:20 AM
Joined Nov 2009
Thanks for your help.
That's just it you get right angles from center of spline to push-rod line by using the last hole on the S3114's longest arm.That will do away with any differential.
Here's a picture it descibes it beter than words.I'm gettig the same geometery by using the last hole on the S3114's.
Old Sep 24, 2012, 10:27 AM
Joined Nov 2009
[QUOTE=roberted5;22819843]Thanks for your help.
Got to use off-set horns.
Old Oct 01, 2012, 11:34 PM
Joined Nov 2009
What kind of AUW are people getting with the A10-9L
I'm using the A10-9L,TP 2S 65C 325's,4.5 gram Frsky 4 channel fasst,and S3114's on all surfaces w/o landing gear.
AUW RTF right now is 6.5 oz.Too heavy for the A10-9L?
Old Oct 03, 2012, 01:06 AM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
That'll have marginal power on the A10-9L. An A20-34S would be a better option at that weight.
Old Oct 03, 2012, 01:17 AM
HaventFlownSince2014 is offline
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
Did they ever get the a10-9L and the CC10 to work well together? Was there an update released?
I love the motor but gave up on the ESC combo after tiring of the inconsistent throttle response (particularly when transitioning from non-powered down-lines to powered flight).
HaventFlownSince2014 is offline Find More Posts by HaventFlownSince2014
Latest blog entry: New Drone Movie :D
Old Oct 03, 2012, 06:37 AM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Many chose to use the trim or a mix on a switch to keep the prop spinning all the time. This overcame the starting issue in flight and improves throttle response. I have not checked for a newer version. Guess I need to check again.
Fancyfoam
motorhead is offline Find More Posts by motorhead
Old Oct 03, 2012, 09:51 AM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
I always run a slow idle-up as, for my flying, I don't see a good reason for the motor to turn completely off in flight. Downline braking is improved and and throttle response is improved with any motor/ESC when the motor stays at a slow idle. That said, with my idle-up I don't have any problem with the A10-9L and Phoenix 10 combination. None of them have the latest software either... once the ESC is direct-soldered to the receiver, it's kind of hard to program
Old Oct 03, 2012, 02:48 PM
Joined Nov 2009
I got a rebuilt a 2204,25gram motor that should work great.I could start shaving more weight but for outdoor flying not worth the time.
Old Oct 03, 2012, 11:37 PM
heliman92 is offline
Find More Posts by heliman92
AKA franky92 on HeliFreak
Canada, QC, Saint-Bruno
Joined Jan 2007
hey RJ, do you think this motor would do the trick? http://www.hobbyking.com/hobbyking/s...dProduct=21873
heliman92 is offline Find More Posts by heliman92
Old Oct 04, 2012, 12:32 AM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Is it for the indoor depron model or an EPP model? If it's depron, that motor should work just fine. For the EPP planes, it might be a little marginal...
Old Oct 04, 2012, 10:51 AM
Joined Jan 2007
it would be for the feather light depron one (the 75$ one)
Old Oct 04, 2012, 02:11 PM
Joined Nov 2009
I got the EPP version and for such a large bird I'm happy with an 6.7oz AUW.
Old Oct 11, 2012, 11:26 PM
jhicks is offline
Find More Posts by jhicks
jhicks's Avatar
United States, TX, Odessa
Joined Jan 2005
My MX2 airfoiled EPP is done. Should have video by the end of the weekend if weather permits.
Jamie hicks
jhicks is offline Find More Posts by jhicks
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 06:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 04:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 11:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 08:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 09:28 AM
