Old Feb 14, 2012, 07:10 PM
iloveflying is offline
Find More Posts by iloveflying
Joined Dec 2011
thanks
waaw thanks a lot john that is a nice design ...i just wanted to ask if the servo needs some glue to be fit or youre just using screw ....and im living in NY how many days it will take to deliver ....and thank you again for the help man
iloveflying is offline Find More Posts by iloveflying
Old Feb 14, 2012, 07:15 PM
xtremeRCpilot is offline
Find More Posts by xtremeRCpilot
xtremeRCpilot's Avatar
Cleveland, Ohio
Joined Sep 2006
My pleasure! It comes with two very small screws that fit through the servo and into the bridge piece. you could glue it in with CA but this way would make it easy to remove and they dont really weigh anything It would take maybe a day or two from OHio.
xtremeRCpilot is offline Find More Posts by xtremeRCpilot
Old Feb 14, 2012, 07:27 PM
Cleveland, Ohio
Joined Sep 2006
I forgot to mention that it was designed around the D47 servo specific, I have not tried other servos with it... If another servo is used you may have to exclude the bridge piece and glue it to the face of the mount but it would work either way
Old Feb 15, 2012, 05:22 PM
Joined Dec 2011
hi pilots does anyone nows the music that gernot brukman used in his ETOC 2011 Freestyle
Old Mar 13, 2012, 06:50 AM
Munyuk is offline
Find More Posts by Munyuk
Joined Nov 2008
Hey guys,
Im glad I found this thread, learned a lot from the last few pages (vpp, hinging, ball links etc).
RJ and Devin, what were the power set-ups you guys used in you mini mx3's.
From the vids on FlightPass I know RJ used the Rimfire 200 but for unspeakable reasons ... switched to the hacker A10 -15s (but was a too bit heavy and power full) and Devin used the Rimfire 200 but what were the servos (and weight), the li-po's and other gear used?
Cheers,
Zac
Munyuk is offline Find More Posts by Munyuk
Old Mar 13, 2012, 07:32 AM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Originally Posted by Munyuk View Post
Hey guys,
Cheers,
Zac
Hi Zac,
I actually never used the Rimfire 200, I broke a wire on it while soldering it to the ESC and then used the 15S right from the start. It actually isn't too heavy at all!! But it is heavier, and doesn't really overpower the Rimfire 200 by very much with that prop. It has a little more low-end power, but in a vertical drag race, the extra weight cancels out the extra power and the two are very well matched. We used cheapo 3g servos and 2S 180mah lipos, with direct-soldered 4-channel Futaba receivers. I think I have a Hacker X-5 ESC in mine, and Devin has a Thunderbird 6 or 9. We both use the GWS 7x3.5 DD prop which seems to work very well.
They're fun airplanes!
RJ
hpapilot is offline Find More Posts by hpapilot
Old Mar 13, 2012, 07:56 AM
Munyuk is offline
Joined Nov 2008
Originally Posted by hpapilot View Post
Hi Zac,
RJ
Haha, these are almost the exact words you said in the interview. I believe there is 2.6grams difference in weight between the motors. the vertical performance I have seen is really quite amazing.
What about flight time, does the hacker draw more than the Rimfire?
Zac
Old Mar 13, 2012, 08:09 AM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Devin said that he used a Castle Creations 10 amp speed control.
Free
Free is offline Find More Posts by Free
Old Mar 16, 2012, 01:53 AM
nagayama13 is offline
Find More Posts by nagayama13
OSMBuddha
nagayama13's Avatar
KC Mo
Joined Mar 2007
I still need alot (understatement) of practice, but here's a vid anyhow.....
Axi Mamo VPP Spring Hill Ks.mp4 (3 min 22 sec)
nagayama13 is offline Find More Posts by nagayama13
Old Mar 16, 2012, 09:14 AM
Free is offline
Free's Avatar
Joined Jan 2012
You're not that bad.
What was your setup and AUW?
Free
Old Mar 16, 2012, 09:36 AM
OSMBuddha
nagayama13's Avatar
KC Mo
Joined Mar 2007
Axi motor, mamo vpp, 9" blades, hitec servos, 2s 65c 350, about 6 1/4 oz.
Old Mar 16, 2012, 10:59 AM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I thought it was great!
motorhead is offline Find More Posts by motorhead
Old Mar 16, 2012, 12:38 PM
OSMBuddha
nagayama13's Avatar
KC Mo
Joined Mar 2007
Thanks Mike! Still don't have the pitch and throttle dialed in......
Old Mar 16, 2012, 05:15 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Sure looks dialed in! great flying!
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Please kill isis
Old Mar 17, 2012, 11:01 AM
air mail rcg is offline
Find More Posts by air mail rcg
Pittsburgh Allegheny, Pennsylvania, United States
Joined Mar 2004
http://www.youtube.com/watch?v=HSwFA3uxU_k
Great, Great video. Liked everything about it. What was the song?
air mail rcg is offline Find More Posts by air mail rcg
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
