Old Feb 03, 2012, 02:09 PM
Devin McGRath is offline
Find More Posts by Devin McGRath
Team Futaba
Devin McGRath's Avatar
Rochester New York
I have started my mx-building spree for E-Fest finished one for my friend Clay who will be coming down with me. Now Im working on the next two lol.... Pictures of the first one below.
Devin McGrath
Devin McGRath is offline Find More Posts by Devin McGRath
Old Feb 03, 2012, 02:23 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Devin , really nice paint job! Guess we'll get to see videos of it flying at efest?
Dennis R.
aerolite is offline Find More Posts by aerolite
Old Feb 03, 2012, 02:44 PM
Team Futaba
Rochester New York
Thanks this one actually was painted by another friend of mine locally here my pain skills aren't that up to par... This is the one I painted last night.
Devin McGrath
Old Feb 03, 2012, 06:01 PM
nagayama13 is offline
Find More Posts by nagayama13
OSMBuddha
nagayama13's Avatar
KC Mo
Joined Mar 2007
Now those are nice paint jobs!
nagayama13 is offline Find More Posts by nagayama13
Old Feb 05, 2012, 04:41 PM
brokeneck is offline
Find More Posts by brokeneck
salt lake ut
Joined Oct 2009
cg
Tip- manual says start cg 1" fwd of canopy, got about 30 packs on mine, I think 0"fwd is much better. 1" is pretty far fwd and dowbt many would like it there. Bad gouge.
rest.
great bird! ailerons are very very powerful, have some problems keeping gear glued straight, could be because i land on blacktop.
Think ill stick w epp next time, as depron is just a little too stressful.
brokeneck is offline Find More Posts by brokeneck
Old Feb 06, 2012, 08:44 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
These planes really serve an entirely different purpose than depron. Simply put, these are not designed to crash (but they do repair easily).
While a foamy, i dont think was intended for bashing; it is highly precise and light.
In regards to the landing gear, if flying outside the best way to avoid abusing your gear is to catch it out of the air in a close hover.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Feb 06, 2012, 12:31 PM
Max Se is offline
Find More Posts by Max Se
Joined Feb 2011
Devin McGrath
I have a little question please, I see you use a very powerfull vpp plane with only one servo for the ailerons. I would like to know what is your solution to make the hinges and control horn strong, because I have a lot of problems with that, every time I use reverse pitch, do manuever with the elevator and live the aileron servo at the neutral position, I break the hinges or the control horns !
Thanks.
Max Se is offline Find More Posts by Max Se
Old Feb 06, 2012, 01:06 PM
Team Futaba
Rochester New York
Now we are using a small Dubro hinge at the root of the aileron to hold everyhthing together nicely and then using glass over the top of each hinge to really hold everything together
I attached a picture of how I did it on my mini MX.
Devin
Old Feb 07, 2012, 01:06 PM
BR289 is offline
Find More Posts by BR289
BR289's Avatar
Sugar Hill, GA.
Joined Feb 2005
Nice Devin, I definately admire your skills....
BR289 is offline Find More Posts by BR289
Old Feb 07, 2012, 01:49 PM
Team Futaba
Rochester New York
Thank you !
Also its hard to tell but there is 1/2 oz glass cloth over each side of the hinge set with Zap foam safe CA. It cures slower than the bsi glue I use for everything else.
Devin McGrath
Old Feb 11, 2012, 08:51 AM
OSMBuddha
nagayama13's Avatar
KC Mo
Joined Mar 2007
Devin,
What micro swivels are you using? You probably said once already and I just over looked it.......my bad if you did! Lol
Old Feb 12, 2012, 03:49 AM
Team Futaba
Rochester New York
For the control links we use T-Rex 250 ball links.
,Devin McGrath
Old Feb 12, 2012, 08:43 AM
OSMBuddha
nagayama13's Avatar
KC Mo
Joined Mar 2007
Ahaaaaa, thanks!
Old Feb 13, 2012, 08:41 PM
iloveflying is offline
Find More Posts by iloveflying
Joined Dec 2011
hi pilots
i have tried the axi 2203 vpp with the vpp mont ...but the broblem is that when i click the nagetive pich the prop hits the servo on the mount so it cant go further ...so the plane doesnt have enough negative thrust....can anyone help pilots
iloveflying is offline Find More Posts by iloveflying
Old Feb 13, 2012, 09:50 PM
xtremeRCpilot is offline
Find More Posts by xtremeRCpilot
xtremeRCpilot's Avatar
Cleveland, Ohio
Joined Sep 2006
Hey iloveflying.... I designed a mount that works perfect for this set up and avoids that issue. Let me know if I can help, I am working on a thrust vectored mount as well Check out the site for pics... and if you could post pics of your issue this would help others!
John
http://www.freewebstore.org/XtremeFo...0_3189652.aspx
xtremeRCpilot is offline Find More Posts by xtremeRCpilot
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
