Old Dec 22, 2011, 09:08 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Mine too came with skids, no wheels; but that was well over a year ago...
I am due to put another one of these in my hangar, I just have too many projects to get off my bench right now.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Dec 23, 2011, 07:47 AM
DanLandis is offline
Find More Posts by DanLandis
Team Futaba
DanLandis's Avatar
Joined Dec 2011
Hey RJ,
What size micro tube did you use?
Dan
DanLandis is offline Find More Posts by DanLandis
Old Dec 23, 2011, 04:19 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Originally Posted by 3171scott View Post
RJ, What Futaba reciver are you using on your Vectered VPP? Im using a 8 FG, what would you recomend?
Thanks Scott.
Hi Scott, I use the 8FG and a 6106HF receiver (with the case removed) on my TVVPP MX's.
Hmm I guess I forgot they don't come with wheels. I actually never even use the skids, I build mine to skid on the foam of the bottom of the wheel pant. If building a normal MX2 kit that way, cut off the fake wheel profile from the bottom of the pant and just let it skid on the flat portion.
Originally Posted by DanLandis View Post
Hey RJ,
Dan
I use a whole variety of sizes on my airplanes. I use .020" rod, and .030,.040,.060, and .080 tube for various parts of the build.
RJ
hpapilot is offline Find More Posts by hpapilot
Old Dec 23, 2011, 04:45 PM
3171scott is offline
Find More Posts by 3171scott
3171scott's Avatar
United States, OH, Youngstown
Joined Apr 2011
Thanks RJ, just finished up putting the Mamo together and played around with TV last week. I just coupled the TV with the ruder servo. Worked well, but now need the extera channels to put it all together.
I know your factory Futaba but what do think about using the new HS 35's on both the TV and VPP servos?
Small, light, and decent power.
Thanks Again...
3171scott is offline Find More Posts by 3171scott
Old Dec 23, 2011, 04:49 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Actually, you're just fine leaving the vectoring coupled to the rudder servo. That's how my first TVVPP planes were, and I may go back to that setup. There's no need to have them separated. The extra servo just adds weight really, though it does make trimming easier.
I don't personally have any experience with those HS35's. I'm sure they'd be fine on the pitch control. Vectoring, I'm not sure... it might be borderline with that servo. What torque do they claim on those?
Old Dec 23, 2011, 04:55 PM
3171scott's Avatar
Joined Apr 2011
They are listed at 11 oz at 4.8 volt. no listing for 6 volts.
Old Dec 23, 2011, 04:59 PM
3171scott's Avatar
Joined Apr 2011
First atempt is going to be a 6mm EPP MX2. I just traced your plane and cut it out last night. Im planning on milling out the wings and elevator. Also my first atempt. I just might go with one servo for rudder and TV to keep the weight down.
Im using a Hacker A20 34s, Hoping to be able to make it work on 2cell.
Old Dec 23, 2011, 05:41 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Definitely keep the weight down as much as possible then, and run 9" blades. The HS35 would probably work on vectoring, if you wanted to go that route, if it actually puts out that much torque. But my experience is all with 8" blades on lighter motors and airplanes... so it might be too much. For now, I'd suggest sticking with the coupled setup.
Best of luck, let us know how it works!
RJ
Old Dec 24, 2011, 08:21 AM
iloveflying is offline
Find More Posts by iloveflying
Joined Dec 2011
hi rj
i just want to ask can i use AXi 2203/40 VPP
with the mx2 and how the perfomance will be? ...thank you
iloveflying is offline Find More Posts by iloveflying
Old Dec 24, 2011, 08:28 AM
Joined Dec 2011
and about the CD(AJ Takes RC to a Higher Plane, Vol1, Foamies and Indoor Flight
) does it include vpp building and its setup?
Old Dec 24, 2011, 08:38 AM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Honestly, I have no experience with that motor. I have heard that a lot of people have been disappointed with the power it has compared to other motors for VPP... but I don't know for sure. Maybe someone here has used it and can share their thoughts.
The DVD does not talk about VPP building and setup. It goes through a normal MX2 build and setup of the airframe, but not a VPP system. I do fly my printed/milled VPP MX2 in the video, but I don't think there are any details on its setup. Sorry!
There's lots of good info in this thread about typical VPP setups on this airplane. If you have any questions, just ask and I'll try to help!
RJ
Old Dec 24, 2011, 09:04 AM
Joined Dec 2011
aha...ok what motor are you using rj? and about the shaft of the motor how can you fit it with the vpp system? cause i think it will be diffrent
Old Dec 24, 2011, 01:21 PM
3171scott's Avatar
Joined Apr 2011
I beleave he is Factory Hacker, I think he is running one of the A10 series motors, not sure witch one tho.
RJ, I have a a10 9L, would this work beter than the A20 34s for my VPP set up? What do you have to do to make the mamo fit the 9L? I also have access to a A10 13L, but i know that this motor does not like 2cell, its an ape on 3cell but trying to stay away from having to run a 3cell. If i have to i will have to pick up a few 250 mah's to try to keep the weight down.
Also where do you order your CF tube in the small diameter?
Thanks for all your help!
Old Dec 24, 2011, 02:00 PM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
If I remember from an earlier post he is running an A10-9L with a custom shaft to fit the Mamo unit. He has also built the plane light so that the weight with VPP is about the same as with out.
Most use the Hacker A20-34s with 9" blades on 2s or 8" blades on 3s.
The Axi 2203/40 is the other recommended motor for the Mamo setup.
Fancyfoam
motorhead is offline Find More Posts by motorhead
Old Dec 24, 2011, 02:03 PM
3171scott's Avatar
Joined Apr 2011
Thanks i did purchase the 9" blades and plan on trying the A20 34s!
Any plans on a milled EPP MX2 in the future?? MY fingers are not up tp depron yet. LOL...
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
