Old Nov 20, 2011, 09:08 AM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
First of all, this was my 2010 ETOC freestyle airplane. Honestly there's not much special to it. The entire airplane is milled. Almost all the carbon is micro-tube with a little bit of .020" rod. It has relatively little carbon compared to my newer plane and one less servo, hence the weight difference. The airplane has a nice light airbrush paint job. It has all Futaba S3114 and S3154 servos, hardly the lightest choice but the best servos in my opinion. A Futaba 6106 receiver, Castle Phoenix 10 ESC, Hacker A10-9L, Thunder Power 2S 325mah 65C packs, the Mamo variable-pitch unit, and my personal thrust-vectoring setup.
This poor thing is kinda beat up now and covered in dust... but here are some pictures of it.
I built one milled with an A10-12S and no vectoring/VPP, that one was only about 115 grams! It was fun but too light and slow for me for a freestyle airplane.
hpapilot is offline Find More Posts by hpapilot
Old Nov 20, 2011, 11:15 AM
Boogie3D is offline
Find More Posts by Boogie3D
United States, FL, Daytona Beach
Joined Sep 2005
I am using similar equipment - although an Axi 2203/40VPP instead of the Hacker. Servos- lightened 3154 and 3157M (on paper they look the same, although the 3157M has a different case and a micro plug, the advantage of it is that it is 10 bucks cheaper) plus a JR 188 for the elevator.
My batteries are 27g, so that is the best way to save another 5g.
Thanks for all the information- one more thing- I see that you only use one strip of carbon on the LE- is that ok with those huge counterbalances? They must twist the LE of aileron/TE of wing. What size carbon tubes did you use for the wing stiffeners?
Boogie3D is offline Find More Posts by Boogie3D
Old Nov 20, 2011, 03:22 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
My wing will not twist at all. The carbon V-bracing on the bottom totally eliminates that... my bracing method yields the stiffest wings I have ever seen. I do normally run a very thin carbon strip on the TE of the aileron, too, but just to help eliminate aileron torsional flex. The V-bracing tubes on the bottom are .040".
Old Nov 22, 2011, 07:40 AM
21Matthias21 is offline
Find More Posts by 21Matthias21
Joined Feb 2009
That airplane is cool :-)
I hope I will get my MX2 soon... shipping to germany will take a while :-(
What is the reason why you are using a extra servo for the vector on your newer airplane?
Matthias
21Matthias21 is offline Find More Posts by 21Matthias21
Old Dec 04, 2011, 03:21 PM
Max Se is offline
Find More Posts by Max Se
Joined Feb 2011
I just test the hacker A20 34s, I'm little bit disapointed, the power is about the same than the axi 2203/40, but it's a 10 gr heavier motor. The axi 2204/28 has about one and the half more power!
With the axi 2204/28 and a 160 gr plane, I have about the same power than RJ and Devin one the video, the only problem is I use about 250 mha to do my freestyle ( 2 min both slow part,3d, 4d ...).
I 'm very surprised about the power of the A10 9L with the mamo prop, he is not modified? You use only 2s ?!!
Max Se is offline Find More Posts by Max Se
Old Dec 05, 2011, 12:26 AM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
With the A20-34S, you really need to run a 3S battery to get good power for VPP. It's relatively low Kv. Some guys have run 3S 250mah packs on them with good luck though!
Nothing wrong with using only 250mah in a flight... I totally kill a 325mah 2S pack during my 2-minute freestyles.
Old Dec 07, 2011, 04:55 PM
brokeneck is offline
Find More Posts by brokeneck
salt lake ut
Joined Oct 2009
any kits for sale at arizonaz efest?
think ill be down to arizona for efest in jan, any mx2 kits going to be down there for sale?
brokeneck is offline Find More Posts by brokeneck
Old Dec 07, 2011, 05:10 PM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Looks like the Az efest is an outdoor event. The hobbico efest in Il is indoor. Both are in Jan but if i go to one it will probsbly be in Il.
I try to always have them in stock onine.
motorhead is offline Find More Posts by motorhead
Old Dec 10, 2011, 12:17 PM
JonathanZ is offline
Find More Posts by JonathanZ
Joined Jan 2009
I'm thinking about getting this plane, but I'm wondering if I should get the milled or standard version?
Thanks, Jonathan
JonathanZ is offline Find More Posts by JonathanZ
Old Dec 10, 2011, 02:20 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Jonathan, it depends what you want to do with it. If you want it very light for slow indoor flying in a small space, go with milled. If you want to use a VPP setup, milled. But, if you want to fly it outdoors or in a larger indoor area, go with the unmilled one.
RJ
Old Dec 10, 2011, 06:49 PM
Joined Jan 2009
RJ
Thanks, I think I'm going to go with the milled one. I'll try to get some build pictures and flight video on this thread. Christmas list finished
Jonathan
Old Dec 12, 2011, 10:24 AM
F3Pflyer is offline
Find More Posts by F3Pflyer
F3Pflyer's Avatar
United States, TX, North Richland Hills
Joined Dec 2011
Is anyone modifying there's with wheels?
F3Pflyer is offline Find More Posts by F3Pflyer
Old Dec 12, 2011, 07:40 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
The kit should come with wheels, and it's extremely easy to install them. Instead of using a music wire skid, just bend the wire out, slide the wheel on, and bend it over to retain the wheel. I still put wheels on some airplanes that I plan to fly at E-fest or other events with a rough floor.
Old Dec 13, 2011, 08:55 AM
F3Pflyer is offline
F3Pflyer's Avatar
Joined Dec 2011
Thanks RJ. My first kit only came with wire skids. No wheels
Old Dec 22, 2011, 08:42 PM
3171scott is offline
Find More Posts by 3171scott
3171scott's Avatar
United States, OH, Youngstown
Joined Apr 2011
RJ, What Futaba reciver are you using on your Vectered VPP? Im using a 8 FG, what would you recomend?
Thanks Scott.
3171scott is offline Find More Posts by 3171scott
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
