Old Nov 18, 2011, 08:03 AM
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Hi Matthias,
Thanks!
The zero position is further back than the middle. It's probably around 1/3 from the bottom to the top.
hpapilot is offline Find More Posts by hpapilot
Old Nov 18, 2011, 02:02 PM
Joined Feb 2011
Wow, your vpp flights are so crazy !
Hi RJ, I don't whant to bother you, but can you tell me few thinks about your set up? Me, last year, I was using an axi 2203/40 on 2s, the power is good, but not so crazy like your, this year, I use an axi 2204/28 (27 gr motor with 2700 kv !) I think I have the same power than you, but only 2min of fligth with tp batteries 325 65 c 2s and 160gr plane. I know last year you were using an A20 34 s on 2s, and this year an A10 right? Can you tell me what is the best set up for you please? and what is the weight of your model ? Thanks very much.
Max Se is offline Find More Posts by Max Se
Old Nov 18, 2011, 02:09 PM
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
I'm also using the axi 2204-28 in a 190g model with 325's and get around 2 1/2 to 3 minutes of VPP flight. I am only using 8" blades and find this plenty of power even at the 190g mark, more than I had using the Hacker A20 34s on the same packs and 9" blades.
Andy
Andycap is offline Find More Posts by Andycap
Old Nov 18, 2011, 02:23 PM
hpapilot's Avatar
Joined Nov 2006
I started using a modified A10-9L three years ago when I started flying VPP. I have used the A20-34S, but only on one airplane. That flight time is about right... I only fly for about 2 minutes normally with the same 65C batteries. The A20-34S setup is definitely the easiest to build and has the best power, but it is a little heavier, so I still use the A10. My last thrust-vectored VPP model is right at 150g ready to fly weight. Before that, my green TVVPP model was about 140 grams, and of course it had the best power.
Old Nov 18, 2011, 02:31 PM
Andycap's Avatar
Leeds
Joined Mar 2003
150g is a real lightweight but no good to those of us who still "Tap" the floor
A milled depron Model would last me an evening and little more
Could I ask you how you modified the A10 RJ ?
Old Nov 18, 2011, 02:42 PM
Team Futaba
Devin McGRath's Avatar
Rochester New York
The lighter they are the lighter they hit the ground
Devin McGRath is online now Find More Posts by Devin McGRath
Old Nov 18, 2011, 02:59 PM
Andycap's Avatar
Leeds
Joined Mar 2003
Only if you push the throttle / pitch stick the right way
Old Nov 18, 2011, 03:21 PM
Joined Feb 2011
Thanks guys for your responses.
Andycap, you think axi 2204/28 has more power than A20 34s ? Mine works so much better with 9" blades.
RJ, 140 gr with an A20 34s in the nose !? What is your secret ?
Old Nov 19, 2011, 01:35 AM
Andycap's Avatar
Leeds
Joined Mar 2003
Axi for me definatley works better than the 34S did and definatley more than enough power on 8" blades with everything running sweet and not over hot
Old Nov 19, 2011, 07:53 AM
hpapilot's Avatar
Joined Nov 2006
It's an A10, not an A20 . Even with the A20 it only would have been 150g though! And it wasn't even built especially light!
Old Nov 19, 2011, 07:55 AM
hpapilot's Avatar
Joined Nov 2006
It just has a custom titanium shaft that steps from the normal A10-9L shaft diameter up to 1/8" for the Mamo prop hub. It's a pretty simple part, but not much fun to make! Tolerances are measured in ten-thousandths of an inch.
Old Nov 19, 2011, 08:00 AM
Andycap's Avatar
Leeds
Joined Mar 2003
Originally Posted by hpapilot View Post
It just has a custom titanium shaft that steps from the normal A10-9L motor diameter up to 1/8" for the Mamo prop hub. It's a pretty simple part, but not much fun to make! Tolerances are measured in ten-thousandths of an inch.
Thanks RJ That makes sense as the Mamo is only available with 3mm or 3.17mm (1/8") fittings. I'll have to get an adaptor made and give the A10 a try as I always said it was the best bang for Bucks motor in the class.
I'm nearing the point I would like to try a light depron model for VPP and see 140-150g as a realistic weight target especially with Depron Aero
Andy
Old Nov 19, 2011, 10:56 PM
Team Futaba
Rochester New York
That's one small motor you got there only 1/8" diameter?
Old Nov 19, 2011, 11:00 PM
hpapilot's Avatar
Joined Nov 2006
Yes, it's a new micro brushless pager motor. Amazing I can get that much torque out of such a small motor, isn't it?
Shut it McGRRRRRath!
Old Nov 20, 2011, 06:56 AM
Warsaw & Gdynia, Poland
Joined Sep 2005
RJ, could you give us more details how you made it so light? Any photos? More info about the setup? I can't get a lighter airplane than 150g and was wondering what is your secret.
Boogie3D is offline Find More Posts by Boogie3D
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
