Old Jun 25, 2011, 07:55 AM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
The Showstopper unit is a hollow-shaft system that requires a larger (generally 1.5oz) motor to work. It really isn't suitable for a light-weight indoor model.
hpapilot is offline Find More Posts by hpapilot
Old Jun 25, 2011, 03:10 PM
JanneL is offline
Find More Posts by JanneL
Janne Lappi, F3A Team Finland
JanneL's Avatar
Helsinki, Finland
Joined Sep 2008
Yes, it doesn't work in these planes. The Mamo system is the best one, the lightest and the strongest. RJ, did you see my post on the previous page about the Hacker motor and VPP?
Originally Posted by lamafever View Post
Jannel, where did u got ur VPP system? I wonder if they are selling the whole set including the motor mounting with servo bracket ?
I'm just planning to get one to try out and have fun By the way ain't the A20-34S-EVO is suitable for the Mamo VPP ? Do i need to modify the A10-9L for it ?
Are you running 2S or 3S with the 9" blades ?
No, you have to make the mount yourself but it is not a big job. I have bought my VPP systems from Mamo-Models and Electricwingman.
A10-9L has a 2mm shaft and the Mamo VPP mounting adapters require a 3mm or 3,175mm shaft. I replaced the shaft with a longer steel rod and glued a piece of 3mm carbon fiber tube on the part of the shaft that comes out of the back of the motor. But aluminium tube would be better if you can find one which has 2mm inner diameter.
But I don't recommend to use 10-9L. As I wrote, the performance is not good with VPP. I recommend to use Axi instead. In addition Axi is many grams lighter than Hacker. With this Hacker or Axi 2203 motors and VPP the plane mustn't weigh more than about 150g if you want to have sufficient performance. Hacker 20-series motors are powerfull but very heavy. If it's ok that a plane weighs a lot I would suggest you try A20, but personally I don't like to fly a plane weighing over 150g.
I'm running with 2s.
Janne
JanneL is offline Find More Posts by JanneL
Old Jul 25, 2011, 12:04 AM
PinkYakRC is offline
Find More Posts by PinkYakRC
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
Wow. Lots of cool guys posting in this thread, and I would like to join 'em.
I dont really have a indoor flying site so my flying would be mostly outside.
Can you use the Hacker A10-9L with the GWS 8 x 4.3 prop on a 3s setup? Say 3s, 500mah? I dont see anything on the Hacker motor listing that talks about 3-cell.
PinkYakRC is offline Find More Posts by PinkYakRC
Old Jul 25, 2011, 12:07 AM
pvtzemerak is offline
Find More Posts by pvtzemerak
JR > Futaba
pvtzemerak's Avatar
Green Lane, PA
Joined Mar 2008
I wouldn't suggest it. 3S on a 9L is probably too much for it to handle. Stick with 2s, it has gobbbbbs of power.
---PvT
pvtzemerak is offline Find More Posts by pvtzemerak
Old Jul 25, 2011, 12:18 AM
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
---PvT
Thanks!
Old Jul 25, 2011, 09:59 AM
ChrisBowker is offline
Find More Posts by ChrisBowker
RC Bum 4 Hire
ChrisBowker's Avatar
United States, NM, Albuquerque
Joined May 2004
if you want to do 3s on a 10mm hacker check out the 13L http://www.aero-model.com/Hacker-Brushless-A10-13L.aspx I have one I got experimenting with vpp setups but I have not had the time yet.
Chris
ChrisBowker is offline Find More Posts by ChrisBowker
Old Jul 25, 2011, 11:18 AM
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
I have a question for you guys.
What is the purpose of anhedral (negitive-dihedral) on the elevator of some RC planes? I noticed the E-Flite Habu-32 has it, and in the 2008 ETOC event, Jason Noll's biplane has it.
Is it for more stability when inverted? In his free style he does some nice smooth inverted turns.
(starting at 1:34)
Jason Noll ETOC 2008 - STLFLYER.com - (2 min 40 sec)
Old Jul 25, 2011, 06:19 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
It basically modifies the pitch behavior of the plane with rudder input. Essentially, when you apply rudder, it adds down force on the tail, which either causes the nose to pitch up, or counteracts some coupling and keeps the nose from pitching down.
It's not something that would be a benefit on the MX2, which doesn't tend to have any bad tendencies with rudder input.
Old Jul 25, 2011, 08:48 PM
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
So cool to get a reply from the actual RC Gritter!!
That's really interesting, I never would have thought of that! I guess i'm ordering my MX2 tonight!
Old Aug 16, 2011, 05:44 AM
sd2602 is offline
Find More Posts by sd2602
Will work for batteries..
sd2602's Avatar
USA, UT, Kaysville
Joined Feb 2005
Has FF stopped selling pull-pull for their planes? Went to the site and can't find it. Thanks!
sd2602 is offline Find More Posts by sd2602
Old Aug 16, 2011, 12:53 PM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I still have it and meant to put it on the site by now but never got around to it. I will get it on there.
motorhead is offline Find More Posts by motorhead
Old Aug 16, 2011, 02:58 PM
sd2602 is offline
sd2602's Avatar
USA, UT, Kaysville
Joined Feb 2005
Thanks Mike!
Old Aug 17, 2011, 12:52 PM
sd2602 is offline
sd2602's Avatar
USA, UT, Kaysville
Joined Feb 2005
Mike, do you also have the biased servo horn or do those have to be purchased through Radical RC? Which one is the correct one? I thought I heard the smaller one is made to work with the horns you include in the kit? THanks again!
-Sean
Old Aug 17, 2011, 01:24 PM
sd2602 is offline
sd2602's Avatar
USA, UT, Kaysville
Joined Feb 2005
Nevermind, i think i found it. Will this do the trick?
http://www.fancyfoam.com/index.php?m...products_id=69
Old Aug 17, 2011, 01:28 PM
sd2602 is offline
sd2602's Avatar
USA, UT, Kaysville
Joined Feb 2005
I have each of these not being used and was thinking of giving them a shot. Opinions?
http://www.hobbyking.com/hobbyking/s...idProduct=9070
http://www.hobbyking.com/hobbyking/s...idProduct=9378
I am thinking the 1800kv would be better? Thanks!
-Sean
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
