Old Apr 21, 2011, 08:30 PM
Kungfubadboy is offline
Find More Posts by Kungfubadboy
Kungfubadboy's Avatar
Atlanta, GA
Joined Jul 2006
Hey Bradley,
I just put a new Hacker A10-9L and cheapy PowerUp 10A esc from headsuprc.com on my 3DHS Extra 330. The combo works great. You are welcome to try out my esc with your motor to see if that fixes your problem. Just send me a pm if you want to meet up. I'm just up the street from you.
Fausto
Kungfubadboy is offline Find More Posts by Kungfubadboy
Old Apr 22, 2011, 06:01 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
After a bunch of aggravation with the Castle/Hacker combo and having to flick start with the Hacker X5 I switched to the Turnigy plush and haven't looked back. Cheap and effective, with a linear throttle response and no low end deadband. I just set the ATV low and the motor starts immediately when you move the stick.
Azarr
Azarr is offline Find More Posts by Azarr
Old Apr 22, 2011, 08:11 AM
Balsa Breaker is offline
Find More Posts by Balsa Breaker
Balsa Breaker's Avatar
United States, MI, Lambertville
Joined Feb 2011
Azarr
Thats amazing, they better get their crap together or nobody will buy the more expensive equipment.
Balsa Breaker is offline Find More Posts by Balsa Breaker
Old Apr 22, 2011, 09:47 AM
HaventFlownSince2014 is offline
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
Fausto, I am definitely going to take you up on that; are you around today or this weekend?
give me a call around lunch and let me know your schedule, I will meet you at your convenience.
Ive found some great fly-spots in Buckhead; call me around lunch or after work and we can figure it out the details.
BB
404.931.9412
HaventFlownSince2014 is offline Find More Posts by HaventFlownSince2014
Latest blog entry: New Drone Movie :D
Old Apr 22, 2011, 09:59 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Originally Posted by pvtzemerak View Post
I too dont like the dead band. But with my plush, i was screwing around with throttle positions when i turned on the Tx, and i somehow removed the deadband. But, it was after 15 minutes of messing with it. I think for CC10 and X-7's there is very little deadband, but not as much as my "programmed" plush. Either way ill agree with you, deadband sucks
--PvT
With the Plush series it is easy to calibrate the throttle range:
Power up with the stick at full throttle.
Wait for 2 beeps
Move the stick to low
It will beep twice (for a 2S pack) then a pause then a longer beep.
Done
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Apr 23, 2011, 05:11 AM
JanneL is offline
Find More Posts by JanneL
Janne Lappi, F3A Team Finland
JanneL's Avatar
Helsinki, Finland
Joined Sep 2008
Yep, Plush is an OK controller but after trying a Castle you will find its throttle response just awesome Before I was also satisfied with Plush but since I got my first PHX10 I have used Plush no longer.
Janne
JanneL is offline Find More Posts by JanneL
Old Apr 23, 2011, 11:26 AM
USA, GA, Atlanta
Joined Nov 2008
Jan, I take it your Castle/Hacker combo works better than the one I posted in the video previously... I still have not changed firmware on the esc yet, will post once I get it done...
Old Apr 23, 2011, 10:06 PM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Just an fyi, the MX2 is back in stock at Fancy Foam.
motorhead is offline Find More Posts by motorhead
Old May 09, 2011, 10:34 AM
USA, GA, Atlanta
Joined Nov 2008
Well, I have directly soldered my A10-9L to some no-name chineese ESC and all is well with it
... I will not be buying another CC9 amp again since aparently any other controler will perform so much better with these motors.
Old May 09, 2011, 11:43 PM
mustang347 is offline
Find More Posts by mustang347
I drank it, and it is good.
United States, OH, Powell
Joined Sep 2009
Thanks Mike!
mustang347 is offline Find More Posts by mustang347
Old May 10, 2011, 10:48 AM
USA, GA, Atlanta
Joined Nov 2008
Thanks Fausto, I just saw this! Its all working now... Have you been going ot any of the Early Bird fly-ins in Peachtree Hills? I want to go but those guys start way too d@m early for me
Originally Posted by Kungfubadboy View Post
Hey Bradley,
Fausto
Old Jun 20, 2011, 12:39 PM
JanneL is offline
JanneL's Avatar
Helsinki, Finland
Joined Sep 2008
Hello.
RJ, I made a few tests with A10-9L and Mamo's VPP. With 8" blades the motor draws about 9A with the pitch adjusted at the most efficient position by testing it in flight. With 9" blades it draws about 11A and the performance is significantly better. The motor doesn't get too hot. I recommend you try the 9" blades, you would get much better performance.
Axi 2203/40 with 9" blades was slightly more powerfull and it is also many grams lighter. A couple friends of mine are flying with Axi Race and 8" blades. Although their planes weigh about 155g the performance is rather good, better than with 2203/40 & 9". According to our experiences and tests the Race with 8" seems to be the most powerfull VPP equipment at these weights.
The batteries that I used within these tests and that we all are using are Hyperion G3 450 mAh.
Janne
Old Jun 23, 2011, 08:43 PM
lamafever is offline
Find More Posts by lamafever
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Jun 2007
Jannel, where did u got ur VPP system? I wonder if they are selling the whole set including the motor mounting with servo bracket ?
I'm just planning to get one to try out and have fun By the way ain't the A20-34S-EVO is suitable for the Mamo VPP ? Do i need to modify the A10-9L for it ?
Are you running 2S or 3S with the 9" blades ?
lamafever is offline Find More Posts by lamafever
Old Jun 23, 2011, 10:54 PM
pvtzemerak is offline
Find More Posts by pvtzemerak
JR > Futaba
pvtzemerak's Avatar
Green Lane, PA
Joined Mar 2008
Yes, the A20-34S is suitible. Im pretty sure you have to modify the shaft of the A10-9L to get it to work with the mamo VPP system, But i would suggest the A20-34S
http://www.rcgroups.com/forums/showp...&postcount=434
pvtzemerak is offline Find More Posts by pvtzemerak
Old Jun 24, 2011, 12:27 AM
USA, GA, Atlanta
Joined Nov 2008
Is anyone using that e-flite "Showstopper" VPP system?
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 06:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 04:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 11:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 08:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 09:28 AM
