Old Oct 20, 2009, 12:46 PM
wcc963 is offline
Find More Posts by wcc963
wcc963's Avatar
United States, FL, Pompano Beach
Joined May 2006
Originally Posted by hpapilot
By blowback I mean the servo does not have enough torque to push the ailerons to full deflection against the air pressure at flying speeds. I am using Futaba S3114's or S3154's all around on my airplanes. Both have about 23 oz of torque, but the 3154 is digital so a little more expensive.
im using 3114's on my charger rc axilion... they're bigger than that JR's. whats your AUW?
wcc963 is offline Find More Posts by wcc963
Old Oct 20, 2009, 01:00 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
My MX2 from ETOC with the VPP stuff and 3 cell battery was just under 6oz. I think they're coming in around 5.25oz with no VPP system, and on 2cells.
Seth
3D-Seth is offline Find More Posts by 3D-Seth
Old Oct 20, 2009, 01:32 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
The servo cutouts in the MX2 are perfectly sized for the S3114's, which are only very slightly larger than the S185. As Seth and Dave said, if you want to go with S185's, I would suggest two of them.
I need to weigh the new plane, but I'm guessing it's right around 5 ounces. Whatever it is seems perfect... the printed kit with stock setup is at a really good weight for a balance of inertia for 3D and floatiness for slow stuff.
RJ
hpapilot is offline Find More Posts by hpapilot
Old Oct 20, 2009, 01:56 PM
eli5539 is offline
Find More Posts by eli5539
eli5539's Avatar
Western New York
Joined Dec 2007
Have you folks come up with a firm date on when we will be able to get our hands on this bird?
eli5539 is offline Find More Posts by eli5539
Old Oct 20, 2009, 02:41 PM
mycamel is offline
Find More Posts by mycamel
south central kansas
Joined Jul 2003
Should be this weekend.
mycamel is offline Find More Posts by mycamel
Old Oct 20, 2009, 02:50 PM
wcc963 is offline
wcc963's Avatar
Joined May 2006
Originally Posted by 3D-Seth
I would recommend two 185s per aileron. 1 185 really isn't quite enough because of the blowback they get on those large ailerons.
Seth
is that what is happening with my FF yak-55? i have one spektrum DSP60 on there and it will freak out and ocilate very rapidly at random?
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Nah... that's pretty typical of those servos. Blowback just means the plane won't roll as fast as it should.
Old Oct 20, 2009, 03:23 PM
wcc963 is offline
wcc963's Avatar
Joined May 2006
ok, its just weird. only the ailerons do it. the rudder and elevator are fine, would it help to put two servos on the ailerons?
Old Oct 20, 2009, 03:37 PM
DaveL322 is offline
Find More Posts by DaveL322
Team JR
DaveL322's Avatar
Medford, NJ
Joined Jan 2004
WCC,
2 servos will likely help. Changing to a different type of servo will also likely help.
The oscillation is generally caused by two things -
1. the natural frequency of the servo matches up to a resonance in the control surface (or surfaces for ailerons)
2. the pot on the servo is getting worn, and it is "hunting" trying to stay perfectly centered.
A combination of 1 and 2 can lead to pretty nasty oscillations.
Even a brand new servo can have an oscillation issue if it happens to be in resonance with the control surface.
What helps -
- more expensive servos (in most cases, try a JR 185 or 188)
- lighter control surfaces (this has a big effect on the DSP60s)
- no slop/flex in linkages
Regards,
Dave Lockhart
Team Horizon/JR/Spektrum
DaveL322 is offline Find More Posts by DaveL322
Old Oct 20, 2009, 03:41 PM
wcc963 is offline
wcc963's Avatar
Joined May 2006
Originally Posted by DaveL322
WCC,
What helps -
Regards,
Dave Lockhart
thanks,
since my axilion had its nose ripped of i'll probably just drop a 3114 in for the ailerons
Old Oct 20, 2009, 07:33 PM
louu is offline
Find More Posts by louu
when i say gas i mean gasoline
louu's Avatar
NJ
Joined Apr 2008
will a jr285 be too much for the ailerons?
will a jeti 8a speed controller be good for the Hacker A10-9L
hey dave are you going to pitman on thursday or mt laurel tommorow?
imm goin thursday, gotta warch the phillies tommorow.
louu is offline Find More Posts by louu
Old Oct 20, 2009, 07:46 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Louu, from the specs, the 285 looks okay for the ailerons. It looks a bit heavier but should be enough torque. I haven't used a Jeti 8 on the 9L, but it should also work just fine, 8 amps is plenty.
Old Oct 20, 2009, 08:39 PM
eli5539 is offline
eli5539's Avatar
Western New York
Joined Dec 2007
WCC,
What helps -
Regards,
Dave Lockhart
Okay Dave,
I ran the DSP60 servo's with the AR6300 receiver on the Osiris and did not seem to have a problem. I like them because they are light weight and digital. From what you have posted you are saying that I should use the JR 185 or 188, is that correct. If so will the JR's plug into the AR6300
Thanks for the input
Old Oct 20, 2009, 09:19 PM
DaveL322 is offline
Team JR
DaveL322's Avatar
Medford, NJ
Joined Jan 2004
Eli,
If you aren't having problems with the DSP60s, keep running them. I run them on a variety of planes, and they are usually fine, it is just that the 188 is better (as it should be since it costs more). The 185 is a very high quality non digital servo, and from my experience is less likely to oscillate than the DSP60s.
The 185s and 188s have a standard JR style plug and won't fit the AR6300 (micro JST) without an adapter. The 185/188s work with the 6110 and 6100 RXs.
Now...back to the MX2.
Dave
Okay Dave,
Old Oct 20, 2009, 09:21 PM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
Eli,
Dave
Although they don't fit without an adapter, you can also cut the lead, and solder the little white JST plugs onto them (however, I'm sure this voids the warranty).
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
