Old Apr 06, 2010, 11:03 AM
pilotpie4 is offline
Find More Posts by pilotpie4
Joined Feb 2010
The motor problems is that when I fly, the motor stops in midair and then putters a little bit. I dont know what the problem is. What I mean my sensitive is that if I put in a little stick, the airplane moves alot. I am using a GWS 8X4 prop,Dualsky 7.4v 400 mah lipo with 20C discharge and a 10 amp speed control
pilotpie4 is offline Find More Posts by pilotpie4
Old Apr 06, 2010, 12:17 PM
djmoose is offline
Find More Posts by djmoose
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
1. Check your solder connections. This is more then likely what is causing your motor problems.
2. Dial in some low rates and expo to get used to it at first. This plane is made to have HUGE deflections.
djmoose is offline Find More Posts by djmoose
Old Apr 06, 2010, 12:32 PM
Joined Feb 2010
Well when I took the motor off, it ran just fine. the solder connections are good. I didn't solder anyting
Old Apr 06, 2010, 04:04 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
If your connections are good, it's probably an ESC programming problem. I don't know what ESC you're using so I can't give you any specific advice there.
As far as sensitive, do you have much experience with other foamies like this? Most of them are "sensitive" compared to more normal airplanes. Dial in some expo (around 60% is good), set up low rates (around 60% of full throw) and see if that helps.
RJ
hpapilot is offline Find More Posts by hpapilot
Old Apr 06, 2010, 07:37 PM
wcc963 is offline
Find More Posts by wcc963
wcc963's Avatar
United States, FL, Pompano Beach
Joined May 2006
ok, second MX2, everything is done, just waiting for the Mamo VPP to show up to finish it.
wcc963 is offline Find More Posts by wcc963
Old Apr 08, 2010, 12:10 PM
Joined Feb 2010
I have had some experience with foamies like this. The thing is that my radio has no expo on it. I am using the spektrum DX5e
RJ
Old Apr 08, 2010, 12:47 PM
wcc963 is offline
wcc963's Avatar
Joined May 2006
hey what material do you guys use for pull pull? im using a braided fishing line but there seems to be a little stretch in it. is there anything that won't stretch as much?
Old Apr 14, 2010, 08:40 AM
mattk0 is offline
Find More Posts by mattk0
mattk0's Avatar
United States, MN, Apple Valley
Joined Jan 2004
RJ-
Awesome job with this past weekends ETOC - I think that has convinced me to looking into the MX2 with VPP. Any plans on giving details/pics of your Vector Thrust unit? Thanks,
mattk0 is offline Find More Posts by mattk0
Old Apr 14, 2010, 04:14 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Originally Posted by mattk0 View Post
RJ-
Thanks! My advice is to master plain old VPP first. VPP can sometimes get out of hand quickly, and the vectoring just makes it easier to get in a bad situation fast. It will do some cool things, but definitely takes some work.
Right now I don't want to even look at a foamy, but maybe in the future I'll post some info on that setup.
RJ
Old Apr 15, 2010, 02:21 AM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
Nice flying at ETOC RJ, You certainly were the master of VPP
Andycap is offline Find More Posts by Andycap
Old Apr 15, 2010, 02:50 AM
EnzoFalconi is offline
Find More Posts by EnzoFalconi
Joined Nov 2006
Hi Matt,
This is a thread on this forum showing Martin's VPP with thrust vectoring. He flew it last year at the World Air Games in Torino, Italy.
Extra 300 and TVR-Prop "by MM"
EnzoFalconi is offline Find More Posts by EnzoFalconi
Old Apr 23, 2010, 12:33 PM
wcc963 is offline
wcc963's Avatar
Joined May 2006
well after a bit of a wait and a tech problem, i finally recieved my mamo VPP unit, thanks Ross at Air land sea hobby for the quick fix to my problem. will post pictures later... just waiting for my VPP servo to arrive then i'll be set to go
Old Apr 24, 2010, 10:59 PM
high alpha is offline
Find More Posts by high alpha
new jersey
Joined Aug 2003
I'm really interested in hearing how the 9l can be modded to the mamo unit.Looks like that was the motor of choice at the ETOC.
high alpha is offline Find More Posts by high alpha
Old Apr 25, 2010, 05:30 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Nope, I was the only one who ran a 9L for VPP. Everyone else who had VPP used the Hacker A20-34S, except (I think) Matt Stringer who used the 50S.
It basically requires a precision machined shaft to replace the stock shaft. My shaft was difficult for experienced aerospace machinists to get perfect... it isn't an easy task when dealing with such a small diameter. I just used my motor/shaft from last year's airplane.
The other thing to consider is that to get acceptable power out of that setup, it takes some extreme lightening of the airframe. My ETOC MX2 was 5.0oz RTF.
RJ
Old Apr 25, 2010, 06:57 PM
new jersey
Joined Aug 2003
Sweet!I was guessing it was a 3mm shaft taken down on a lathe to 2mm where it goes through the motor.
I'm sure it's not easy,but thats the fun part about the hobby,always a challenge!!
Did you use you the 9" blades on a 325mah TPG4?
You plane looked great!I see you even milled the wheel pants!!
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
