Old Jan 13, 2010, 05:28 PM
D C is offline
D C
Find More Posts by D C
D C
I'm Out Sky Dancing!
D C's Avatar
United States, TX, Bryan
Joined Jan 2009
Cool, thanks RJ....
Don C
D C is offline Find More Posts by D C
Old Jan 26, 2010, 10:21 PM
pootman is offline
Find More Posts by pootman
pootman's Avatar
Goleta, CA
Joined Mar 2006
Fun Fun Fun
Finished my MX2 because of all the rain we've had here in CA. Got a couple of quick test flights and man this plane is fun!!! I have to move the control rods in on the servo arm, the throws are crazy. I've had to turn all my end points down to 60-70 to keep it from pushing the control surfaces off the plane. If I remember right, lowering end point will cause a loss in resolution, right? Seems to feel kinda jerky around center (even with 70% expos).
AUW 5oz.
pootman
pootman is offline Find More Posts by pootman
Old Jan 26, 2010, 11:22 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Glad you enjoyed it!! You usually want to use a hole on the servo arm that allows you to use at least 100% ATV (130ish is better). Back your aileron throw down a bit... you want just enough throw for the spade to hit the wingon the down-moving aileron. Too much more throw than that tends to add so much drag that it will decrease roll-rate.
RJ
hpapilot is offline Find More Posts by hpapilot
Old Jan 26, 2010, 11:57 PM
pootman is offline
pootman's Avatar
Goleta, CA
Joined Mar 2006
Thanks, I'll definitely back the throws off. Kinda funny to see so much throw, so I had to snap a pic of it.
Old Jan 27, 2010, 08:11 AM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
Joined Jan 2007
RJ
Not to mention the differential makes it bobble when you roll...
3D-Seth is offline Find More Posts by 3D-Seth
Old Jan 27, 2010, 10:43 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I have been dubbing around with my MX, but I handed it to a very talented pilot (and plane designer) last weekend and he loved it. He said it did "exactly what he asked it to do." He was exremely impressed with this plane. He did 8 point hesitation rolls that were unbelievably precise, rolling circles, hesitation rolling circles, inverted square loops, knife edges up, down and around the (very small) gym, hovers, a hover where he "hung" it on the gym wall and skittered about for a while, and about everything else a good pilot might do, ending, of course with a hover around his body and a snatch. All and all he put on a great show for all involved.
I should point out that my plane has the (great) Hacker A10-9L motor, it also has the cheap Tower Pro servos and a cheap Tower Pro ESC, so even with less than top notch equipment, this fellow was very impressed.
u2builder is offline Find More Posts by u2builder
Old Jan 29, 2010, 02:58 PM
jmd3002 is offline
Find More Posts by jmd3002
jmd3002's Avatar
Danville, VA
Joined Jan 2010
I have had my MX2 going for about three weeks now and I must say it is a blast! I have not had it indoors yet, but the hayfield does fine for now.
Setup: Futaba S3114s all around, rimfire250 for the powerplant and electrifly 8A esc.
I took a gamble on the rimfire not knowing much about it or seeing any other post on how it does. Well I can hover around midstick and pull out with ease so the power is there. As for other performance issues I hadn't found any yet. It will pull the Mx2 around with authority. The specs for the rimfire 250 is pretty much identical to the AXI recommended. Price also swayed me in the rimfire direction as well, have to keep the budget in mind!
I would like to try the hacker one day but for now I'm having a blast with this setup, thats whats its about anyway... just having fun
RJ maybe I'll run in to ya at the gym in Eden, NC I seen you fly there this past july 4.
jmd3002 is offline Find More Posts by jmd3002
Old Jan 31, 2010, 04:20 PM
simon737 is offline
Find More Posts by simon737
Triple boxed goodness!
simon737's Avatar
United Kingdom, Doncaster
Joined Sep 2008
Having been to my first indoor flying session today with my UM 4-site, I'm hooked already!
So i've just ordered the MX-2, my setup will be the Hacker A10-9L with X12 ESC, 2xS60's and 1 S75 flown on a 8x4.3 prop on 2s 350, AR6110E RX.
Cannot wait!
simon737 is offline Find More Posts by simon737
Old Jan 31, 2010, 04:36 PM
djmoose is offline
Find More Posts by djmoose
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
Just ordered my MX2....anyone used the new Scorpion S-2503-1610 F3P yet?
djmoose is offline Find More Posts by djmoose
Old Jan 31, 2010, 05:02 PM
louu is offline
Find More Posts by louu
when i say gas i mean gasoline
louu's Avatar
NJ
Joined Apr 2008
Cannot wait!
i would recomend you put a better servo on your aielerons, i had a bunch of s75's and they had a very bad jittering problem so i had to cut them out of my plane and now they just collect dust in a drawer. i have the eflight version of that servo on the aielerons of my osiris and it does not center at all.
you would be much happier if you put either a jr188 on your aielerons, not the 185.
or the futaba servo that Rj recomends on the front page, it acually has more power than the jr188 and if its good enough for Rj its good enough for anybody.
good luck with your new plane buddy you cant go wrong with the mx2.
louu is offline Find More Posts by louu
Old Jan 31, 2010, 05:24 PM
simon737 is offline
simon737's Avatar
Joined Sep 2008
Thanks for the heads up, I've gone for the S3114's instead
Old Jan 31, 2010, 07:50 PM
Don McCullough is offline
Find More Posts by Don McCullough
SBSS, SVSS, SCCMAS, EBRC
Don McCullough's Avatar
United States, CA, San Jose
Joined Jan 2004
My son Jon and I just put a MX2 together using four JR S188 servos. They work great with no jitter like the S60s. Four of the S188 is about the same weight as three S3114/S3154 servos. Easier to dial in the ailerons that way.
Don
Don McCullough is offline Find More Posts by Don McCullough
Old Jan 31, 2010, 09:00 PM
mahak213 is offline
Find More Posts by mahak213
Joined Nov 2008
Here's a video of me flying my MX2 over the R/C track I work at. Kind of tight, but still fun. I have a park 300 and 3s lipo's on it, so it isn't quite as light as I would like it, but still flies fantastic!
Flying the Fancyfoam MX2 and new micro 4site (7 min 55 sec)
mahak213 is offline Find More Posts by mahak213
Old Feb 01, 2010, 01:47 PM
simon737 is offline
simon737's Avatar
Joined Sep 2008
Using the Futaba S3114 servo on the aileron, do the stock arms produce enough throw? If not can anyone point me in the right direction of the right arms to use. Thanks.
Old Feb 01, 2010, 02:19 PM
FASTALJR is offline
Find More Posts by FASTALJR
Fast and getting faster!
Albany County, New York, United States
Joined Jul 2003
im using an arm from radical rc, its fiberglass. I have the recommended throws and its perfect.
FASTALJR is offline Find More Posts by FASTALJR
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 06:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 04:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 11:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 08:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 09:28 AM
