Old Dec 01, 2009, 05:54 PM
Joined Nov 2006
I've taken bends and wrinkles out of 3mm printed depron with heat by using a Monokote iron and a damp smooth textured paper towel. It's important to use a paper towel with as smooth a surface as possible. Some paper towels have a very textured surface and I think it would transfer that roughness to the depron. I lay the depron on a flat surface and then put the damp paper towel on top of it. I use the iron to lightly steam press the depron. It usually takes a couple of passes to remove the wrinkle or bend. The steam seems to make the dents puff back up very close to the original thickness of the foam. I keep the iron set about medium or maybe higher and carefuly check the foam after each pass. I do it the same for warped parts, but after I iron them with the damp towel I put a flat surface on top of the warped part and let it cool. So far I've been able to take out some pretty severe warps and wrinkles. I found this method of repair on another RC Groups thread, but I don't remember which one or I'd give credit to the original poster.
Good luck
Michael
EnzoFalconi is offline Find More Posts by EnzoFalconi
Old Dec 01, 2009, 10:23 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Originally Posted by hpapilot View Post
That should work just fine! The only exception is the aileron servo, the S60 will probably get blowback, but it will work...
RJ
I am ordering my MX soon...I am going to run the S60's on the tail and plan to get one of these.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNCV6
That is the servo you use correct? Heck I think I will just order 3! Thanks in advance...great videos BTW
bighead93 is online now Find More Posts by bighead93
Old Dec 01, 2009, 10:24 PM
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Yep that's the one. I sometimes use an S3154 on the ailerons instead, but they have the same specs, the 54 is just digital.
Thanks!
hpapilot is offline Find More Posts by hpapilot
Old Dec 01, 2009, 10:54 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Thanks!
You feel a difference? The S60's should be good on the tail...so $35 for one high performance servo sounds like a deal!
Old Dec 02, 2009, 05:30 AM
hpapilot's Avatar
Joined Nov 2006
I can feel a difference, though it isn't much. If I had the choice, I think I'd put 3114's all around instead of a 3154 and S60's on the tail. The 3114's will perform much more precisely than the S60's.
Old Dec 02, 2009, 10:21 AM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Got it! Thanks for the info
Old Dec 03, 2009, 11:32 AM
D C
I'm Out Sky Dancing!
D C's Avatar
San Anonio, TX
Joined Jan 2009
Hi Seth & RJ,
On the non VPP version, do you have any photos showing the bottom side of your MX-2's revealing the location of your radio installation and wiring (motor, ESC, Lipo, RX, servo wiring).
Don C
D C is offline Find More Posts by D C
Old Dec 03, 2009, 01:56 PM
hpapilot's Avatar
Joined Nov 2006
Originally Posted by D C View Post
Hi Seth & RJ,
Don C
Yep, it's already posted on this thread, but I just put it up on FG for you too.
RJ
Old Dec 03, 2009, 04:16 PM
D C
D C's Avatar
San Anonio, TX
Joined Jan 2009
Thanks RJ.... You're right, I'd seen that photo and it's very informative. I was just curious as to how everyone was grouping the wires as well.
Don C
Old Dec 08, 2009, 04:47 AM
Fast and getting faster!
Albany County, New York, United States
Joined Jul 2003
Well finally started painting my mx2s should have one done tonight and the 2nd one done by weeks end. Would like to have the 1st one flying by the weekend too. Looks good will post pics when it's done!!
FASTALJR is offline Find More Posts by FASTALJR
Old Dec 08, 2009, 09:19 PM
Joined Jul 2003
Pics up Mx2 #1 Painted #2 will look just like this just trying to figure out a different color LOL!!!!
Old Dec 09, 2009, 03:34 AM
hpapilot's Avatar
Joined Nov 2006
Sweeeeeet!!!!
Old Dec 09, 2009, 09:26 AM
is it flying time?
Jerry Combs's Avatar
Wyandotte Oklahoma
RJ,
Are you going to make it to Wichita?
Jerry
Jerry Combs is offline Find More Posts by Jerry Combs
Old Dec 09, 2009, 10:04 AM
hpapilot's Avatar
Joined Nov 2006
Originally Posted by Jerry Combs View Post
RJ,
Jerry
Hey Jerry, I wish I could make it, but it's just too expensive a trip to make it this year. Maybe next time it'll work out better...
Old Dec 12, 2009, 11:16 AM
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
Good luck
Michael
I've taken the liberty of copying this gem over to "best build tips" sticky in "builders workshop", hope it's okay Michael! A magic trick this good shouldn't get lost...just tried it on a pretty beat up (creased, warped,bent, indented) Breeze Pro kit I received, crushed by the USPS monkeys. Very impressive results, made an unbuildable kit usable again. Thanks!
Sorry O/T
maukabud is offline Find More Posts by maukabud
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
