Old Nov 22, 2009, 08:11 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Here are some!
http://flightpass.higherplaneproduct...udio-H264s.mov
KIEF RJGritter (2 min 29 sec)
KIEF JamieHicks (2 min 35 sec)
http://www.youtube.com/watch?v=KtvcQ...eature=related
hpapilot is offline Find More Posts by hpapilot
Old Nov 23, 2009, 05:49 PM
louu is offline
Find More Posts by louu
when i say gas i mean gasoline
louu's Avatar
NJ
Joined Apr 2008
sssssooooooo all i gotta do is play that song and my plane will do all that stuff???
louu is offline Find More Posts by louu
Old Nov 23, 2009, 06:48 PM
FASTALJR is offline
Find More Posts by FASTALJR
Fast and getting faster!
Albany County, New York, United States
Joined Jul 2003
lou I tested that theory, with all kinds of music, plane just sat on the ground.....Further Research is needed! LOL
FASTALJR is offline Find More Posts by FASTALJR
Old Nov 23, 2009, 09:21 PM
DaveL322 is offline
Find More Posts by DaveL322
Team JR
DaveL322's Avatar
Medford, NJ
Joined Jan 2004
More BASS!!!!
DaveL322 is offline Find More Posts by DaveL322
Old Nov 23, 2009, 09:24 PM
FASTALJR is offline
Joined Jul 2003
tried that dave plane jumped around a bit on the floor still nothing LOL!!!
Old Nov 23, 2009, 11:10 PM
D C is offline
D C
Find More Posts by D C
D C
I'm Out Sky Dancing!
D C's Avatar
United States, TX, Bryan
Joined Jan 2009
Hi Seth,
What kind of servo arm do you use on the Futaba S3114 servo on Aileron? Where can I get some?
Don C
D C is offline Find More Posts by D C
Old Nov 24, 2009, 12:09 AM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
Originally Posted by D C View Post
Hi Seth,
Don C
Hi Don,
I don't run the 3114 on the ailerons, but the arm I use will still work. I get mine from Radical RC HERE, about halfway down the page. "F3P Biased Servo Horn #1"
Seth
3D-Seth is offline Find More Posts by 3D-Seth
Old Nov 24, 2009, 12:24 AM
skippy78 is offline
Find More Posts by skippy78
skippy78's Avatar
USA, VA, Narrows
Joined Mar 2009
Found RJ on ebaums would not sure if that is good or bad http://www.ebaumsworld.com/video/watch/80822596/
skippy78 is offline Find More Posts by skippy78
Old Nov 24, 2009, 06:30 AM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Originally Posted by 3D-Seth View Post
Hi Don,
Seth
But I do, and that's the arm I use.
RJ
Old Nov 24, 2009, 12:55 PM
D C is offline
D C
D C
D C's Avatar
Joined Jan 2009
Thanks Seth and RJ....
Which holes (on this aileron servo arm) do you recommend to work best for the aileron linkage?
Also, do you use their pushrod standoffs too?
Don C
Old Nov 24, 2009, 01:05 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Don C
I believe the second hole from the bottom on the arm gives the most even amount of up/down deflection. I have used the third hole up and that also works well.
The MX2 kit comes with pushrod standoffs for the elevator and rudder pushrods. The aileron pushrods do not need standoffs because they are made with thicker 1.5mm carbon rod to resist flexing.
RJ
Old Nov 24, 2009, 01:09 PM
D C is offline
D C
D C
D C's Avatar
Joined Jan 2009
Cool....
Thanks RJ.
Any suggestions on appling the CA sparingly? (applicators, tips)
Don C
Old Nov 24, 2009, 01:13 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Cool....
Thanks RJ.
Don C
No problem!
I dont do anything special really. I just use the normal nozzle on the BSI Thin-CA bottles and make sure not to cut a large hole in the top when I cut open the bottle the first time. Then I try to just "tack" everything together... I never run beads down the length of a joint, and I don't pre-glue any parts before I push them together. Just dry-assemble the parts and then put a little glue in the corner of the joint every 2 or 3 inches. Common sense usually tells you where you need some extra. A little too much is better than not enough, but it usually doesn't take much...
RJ
Old Nov 24, 2009, 01:20 PM
D C is offline
D C
D C
D C's Avatar
Joined Jan 2009
To cool....
Thanks RJ....
Great suggestion, I sure would have thought I'd need to run CA the length of each joint.
Don C
Old Nov 24, 2009, 05:01 PM
louu is offline
louu's Avatar
NJ
Joined Apr 2008
hey rj in that first flight pass video is the elevader milled on that plane or is that just some weird shadow? and why do they blow the horn half way through the flight, is that a 10 second warning or something?
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
