Old Nov 16, 2009, 11:49 AM
Brian Chitty is offline
Find More Posts by Brian Chitty
sponsored by labor
Brian Chitty's Avatar
United States, OK, Broken Arrow
Joined Jan 2006
Hey guys, Have you tried a 3 cell lipo on the A20 34s with the mamo vpp unit? I know the hacker site says the motor is made for a 2 cell, but wondering if you might have tried the 3 cell..... Thanks in advance!
Brian Chitty is offline Find More Posts by Brian Chitty
Old Nov 16, 2009, 12:02 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
I flew mine at ETOC last year with a 3s pack.
I am using 2s this year though, keeps the airplane closer to the "normal" weight.
Seth
3D-Seth is offline Find More Posts by 3D-Seth
Old Nov 16, 2009, 01:46 PM
sponsored by labor
Joined Jan 2006
Thanks Seth, I have 4 hot 3 cells and didn't want to buy anymore batteries!
Old Nov 17, 2009, 09:44 AM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
No problem
Old Nov 17, 2009, 09:50 AM
maxer is offline
Find More Posts by maxer
United States, CO, Boulder
Joined Jan 2006
how does the vpp pitch lever hold itself into the pivot bracket? it seems like a screw should be there. yet no hole in the pivot shaft. Am I missing somthing(mamo unit)
thanks,
skip
maxer is offline Find More Posts by maxer
Old Nov 17, 2009, 10:27 AM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
thanks,
skip
There is a little nylon bracket that the pitch lever goes into. Then on the lever itself, there is a little "half moon" circle type of thing on the bottom of the lever. There is a little silver screw included with the unit. Screw goes through the nylon piece and into the carbon, BUT don't tighten it down all the way, because the half moon circle thing catches on the screw head and holds the arm in place. My little nylon piece actually wouldn't stay on very well, so I tacked it with a little CA as well.
Hope this makes sense. I'll see if I can find my camera to take a picture for you.
Seth
Old Nov 17, 2009, 01:22 PM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
thanks,
skip
I had exactly the same problem until Seth told me to glue the bracket to the motor mount. The problem really is that the bracket has a slot instead of a hole. As you tighten the retaining screw it works it's way up the bracket and then the arm just flops around. As Seth said, the solution is to glue the bracket to the motor mount, then it works like a charm.
Azarr
(ignore the foam bits in the picture, it's a long story )
Azarr is offline Find More Posts by Azarr
Old Nov 17, 2009, 06:30 PM
maxer is offline
Joined Jan 2006
thanks guys,now I just have to figure out the geometry. My half moon is on top instead of bottom. I at least now have an idea what I'm after. Rest of mechanism is working perfectly.
Skip
Old Nov 17, 2009, 06:36 PM
maxer is offline
Joined Jan 2006
the tips worked ...got it...almost ready to hover in reverse..yeah sure!
skip
Old Nov 17, 2009, 10:10 PM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
Azarr
Skip
skip
Thanks for posting a picture Azarr!
Glad you got it working Skip!
Old Nov 20, 2009, 12:32 PM
AeroControl is offline
Find More Posts by AeroControl
AeroControl's Avatar
Grand Rapids, MI
Joined Mar 2008
Originally Posted by hpapilot View Post
I've been meaning to put up pictures to show this but I've been sick all week and just haven't been up to it. Hopefully this drawing will clear things up a little bit...
Thanks for the picture, it helped a lot.
Even with my RX and ESC in the suggested position, I still needed to put my 19g Rhino 360 2C battery almost full forward to get the cg right. My first flight went great. I broke down and had to eventually install some light wheels. The paper clip skids and foam wheel pants did not last long on the indoor soccer field turf.
AeroControl is offline Find More Posts by AeroControl
Old Nov 20, 2009, 02:45 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Glad the picture helped. Out of curiosity, what did you base the "right" CG off of, the 'around 1" in front of the canopy' suggestion, or the flight characteristics? With the proper CG, the airplane should have zero coupling on knifeedge.
Yeah, the skids are definitely not intended for turf. At events that don't have a smooth floor, we always just hand-launch and catch our airplanes.
RJ
hpapilot is offline Find More Posts by hpapilot
Old Nov 21, 2009, 09:48 AM
Grand Rapids, MI
Joined Mar 2008
RJ
Hey RJ,
I started the CG at the 1" in front of canopy suggestion point. I had a friend of mine (who has more experience with indoor 3D planes) fly it for a while and he said it felt a little tail heavy. He said it felt much better in a hover with the CG a bit more forward. I plan on flying indoors again next week and will play with the CG a little more doing knife edges (like you suggest) and inverted fllight. This is my first indoor 3D acrobatic plane and so far I really like it.
Old Nov 21, 2009, 11:04 AM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
Originally Posted by AeroControl View Post
Hey RJ,
While it may feel "tail heavy" to some pilots, its actually a very good CG. Flies precision well, but yet can still do all of the 3D waterfalls and such.
The CG that is correct is where it has ZERO coupling.
All of our non VPP MX2s fly at 1" in front of the canopy.
Seth
Old Nov 22, 2009, 07:45 PM
stickbanger is offline
Find More Posts by stickbanger
Joined Dec 2007
Hey guys,how bout posting some vids of the MX2 in action!!
stickbanger is offline Find More Posts by stickbanger
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
