Old Oct 31, 2009, 08:06 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
Originally Posted by rcmaster12 View Post
Got my MX2 built today, waitning on motor and esc to arrive. I plan on going to the JR indoor festival next weekend so I might have to let Seth or RJ wring it out
I should have two there myself, so enjoy yours!
3D-Seth is offline Find More Posts by 3D-Seth
Old Oct 31, 2009, 08:10 PM
rcmaster12 is offline
Find More Posts by rcmaster12
Joined Oct 2009
Sounds good. I will be using the AR6300 with my futaba S3114m servos and a hacker A10 9l with an x-5 esc. I ordered a white one and did my own color scheme. I ran into one problem though, and that was wen I attatched the pushrod supports the glue seemed to eat through the foam. I was using the BSI thin CA and accelorator as Mike recomended
rcmaster12 is offline Find More Posts by rcmaster12
Old Oct 31, 2009, 09:30 PM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
It will still do that even though its "foam safe".
Its because there was too much CA/ too much kicker on that location.
I push the pushrod supports in, and put 1, maybe 2 drops on the hole they are in, while they are in, wait a minute or two, and lightly mist it with kicker from about 1 1/2 ft away. Never had a problem.
Seth
Old Oct 31, 2009, 09:45 PM
Joined Oct 2009
Im probably spraying the kicker to close in then. I will have to remeber that for my next build. Thanks anyway though!
Old Nov 03, 2009, 08:30 AM
Brian Chitty is offline
Find More Posts by Brian Chitty
sponsored by labor
Brian Chitty's Avatar
United States, OK, Broken Arrow
Joined Jan 2006
Hey RJ,
What amp/ESC are you using with your Hacker/Vpp setup. I think I just Blew up my castle 10 with the 3 cell I was using..... Thanks in advance for your help!
Brian Chitty is offline Find More Posts by Brian Chitty
Old Nov 03, 2009, 08:55 AM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
I'm using a Phoenix 10, but on 2S. It should handle 3S just fine though... just make sure to set your curves to keep the RPM in a normal range and keep from drawing a TON of amps, but it should be pretty forgiving...
hpapilot is offline Find More Posts by hpapilot
Old Nov 03, 2009, 11:21 AM
sponsored by labor
Joined Jan 2006
I'll keep that in mid, thanks for the help.
Old Nov 03, 2009, 11:25 AM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
What happened when it fried exactly?
Old Nov 03, 2009, 11:45 AM
sponsored by labor
Joined Jan 2006
Was trying to program my 12FG and I think I let it run with no load too long.... Now when ever it has pwr, it gives a beep ever second no matter what I do. I contacted Castle Creations and they said to send it in because the processor is messed up. He also said that if I didn't need the extra programing features of the Phx 10, I could buy the cheap Thunderbird 9 instead. Are you using any advance programming freatures for the vpp? thx.
Old Nov 03, 2009, 12:44 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Ahh I see. No, I'm not using anything really special, just the normal programming. I'm not familiar with the options the Thunderbird offers though, so I can't say for sure...
Old Nov 03, 2009, 05:05 PM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
I'm pretty sure the TBird only has a 1.5A BEC while the PH10 has a 3A BEC. Wouldn't that be a concern for VPP?
Azarr
Azarr is offline Find More Posts by Azarr
Old Nov 03, 2009, 07:18 PM
sponsored by labor
Joined Jan 2006
That makes a good point, as i moved all the servos and the motor at the same time that thunderbird was cookin'! Sorry didn't mean to hijack the thread. Thats for all the helpful information!
Old Nov 03, 2009, 10:15 PM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
#1 of two for the JR Indoor Electric Festival.
Old Nov 04, 2009, 08:38 AM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
what servos are you using?
aerolite
aerolite is offline Find More Posts by aerolite
Old Nov 04, 2009, 08:50 AM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
Aerolite
jr 185/188
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 05:27 PM
Edge 540 by Fancy Foam JWarren Foamies (Kits) 27 Aug 03, 2005 03:53 PM
Edge 540 by Fancy Foam Models JWarren 3D Flying 0 Oct 22, 2004 10:32 AM
Fancy Foam Models - Take a look! mycamel Product Announcements 2 Feb 18, 2004 07:12 PM
WTB vintage foam slopers by Combat Models AMTJIM Aircraft - Sailplanes (FS/W) 2 Jun 12, 2003 08:28 AM
