Old Oct 15, 2009, 06:41 PM
zackesch is offline
Find More Posts by zackesch
Got lift?
zackesch's Avatar
Milwaukee, Wisconsin
Joined Apr 2006
First build Sig Riser 2M **update July 29th**
Hey all, i picked up a sig riser 2 meter the other day and its my first build. Im thinking of making this into a build thread. I plan on installing the spoilers and installing a brushless motor instead of keeping it pure.
zackesch is offline Find More Posts by zackesch
Old Oct 15, 2009, 07:27 PM
wds is offline
wds
Find More Posts by wds
wds
Just fly
wds's Avatar
Castro Valley, CA
Joined Nov 2004
Do it.
Go for it. Take and post pictures. Talk about it. That's what this is all about. Have fun!
Cheers,
Bill
wds is offline Find More Posts by wds
Old Oct 16, 2009, 10:41 AM
Lockley is offline
Find More Posts by Lockley
KI4UBK
Lockley's Avatar
USA, NC, Old Fort
Joined Nov 2007
You will like the Riser. Do put spoilers you will need them. I have a KDA 22-15 in mine and it's one of my favorite planes. Dave
Lockley is offline Find More Posts by Lockley
Old Oct 18, 2009, 10:16 PM
zero2444 is offline
Find More Posts by zero2444
Mcminnville, Or USA
Joined Jul 2009
I would definately like to see your progress.
Nothing better than seeing new wood go together.
Good luck and keep us posted.
zero2444 is offline Find More Posts by zero2444
Old Oct 18, 2009, 11:48 PM
zackesch is offline
Got lift?
zackesch's Avatar
Joined Apr 2006
Its been busy for me the past few days. So far all ive done is make by building board " two 1'x4' waffle board with 3/4" beaded foam glued on top" and for the build i started laying the base of the wing and got done gluing in the spruce base to lay the ribs. I will get some pictures tomorrow. As much as for the colors, im going to go with a white fuse, with trans. yellow and trans. purple for the wings. The spoilers will be white. For most of the gluing for this project im going to use wood glue. CA will be used as a liquid pin for some jobs, like when i start putting on the ribs and use yellow glue for the rest.
Old Oct 19, 2009, 09:09 AM
Windependence is offline
Find More Posts by Windependence
The King Moonracer of balsa.
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
Having built this exact plane 2 years ago allow me to offer a couple of suggestions.
1. Reinforce the wing joiners with some .007 carbon. It will make the wing joints stronger. I have only evern seen wing failures at the wing joints on this plane. Mine has never failed with the reinforcements.
2. Think about setting up the spoilers with a small servo in each wing. It is much easier than the string and tube method spelled out in the plans.
3. Secure the control rods and multiple points as they go down the fuselage. If you don't you will get some flexing and your control surfaces will not be as accurate as they could be.
4. When you place the control rods in the fuselage have them run along the sides not down the middle. By running them down the sides this leaves you lots of room under the wing for ballast for those windy days.
I am still flying my Riser 2M and still loving it. I am certain you will enjoy yours.
Wayne
Windependence is offline Find More Posts by Windependence
Old Oct 20, 2009, 11:52 PM
zackesch is offline
Got lift?
zackesch's Avatar
Joined Apr 2006
Tonight's progress.
Old Dec 16, 2009, 11:04 PM
USA, MN, Rochester
Joined Mar 2008
Any new progress on the Riser build?
Wayne
Old Jul 29, 2010, 10:56 AM
zackesch is offline
Got lift?
zackesch's Avatar
Joined Apr 2006
Its been quite some time since i had time to build. My class schedule got uber heavy so the build was put off. Now that I graduated, time is somthing i once again have.
I will post some pics tonight of what i have done so far. The wings are almost complete and i started the fuse.
Old Jul 30, 2010, 05:59 AM
Captain Canardly is offline
Find More Posts by Captain Canardly
who has rabbit ears down
Captain Canardly's Avatar
United States, MN, Buffalo
Joined Jan 2007
Hi Zack!
I remember the first Hand toss for Wayne, I forgot how this puppy just goes and goes!
it was an 81 pace first 'test' launch, very flat slope to the glide! I think I have to find one myself!
Your gonna love it!
Johnny
Captain Canardly is offline Find More Posts by Captain Canardly
Latest blog entry: Have a laugh on me!
Old Jul 30, 2010, 01:47 PM
zackesch is offline
Got lift?
zackesch's Avatar
Joined Apr 2006
It has been a very enjoyable build so far. The only major "oops" i had so far is when I put the dihedral in, one side has more then the other due to i measured the wrong spot. If i remember right from a few months ago, it was .25 to .5 inch off... not happy about that.
Old Jul 30, 2010, 05:09 PM
Joined Jan 2007
That's certainly not worth putting too much worry into! worst case scenario, is a bit of thermal 'leaning'
Old Jul 30, 2010, 05:15 PM
zackesch is offline
Got lift?
zackesch's Avatar
Joined Apr 2006
If needed, i can always add a small amount of weight in the wingtip if needed
The First Build! Drunken_Rockstar Beginner Training Area (Aircraft-Electric) 6 Jun 25, 2004 05:05 PM
CSD Aircobra Solartex bubbling (first build of this type) ugotoslope Slope 12 Jun 21, 2004 05:21 AM
Humbly, my first build..."The Bubba/Boom Stick" bubbadice Parkflyers 35 Nov 04, 2003 09:44 PM
What model for first build.? NewHummer Parkflyers 11 Sep 01, 2003 04:02 PM
Picture - My very first build, the DuskStik Hollywood Flyer Parkflyers 7 May 09, 2003 05:53 AM
