Great job on the repair!
I wouldn't hold my breath about doing any kind of actual hovering with it though. My Durafly SE5a has more than enough thrust to lift out of my hands, but hover...it will do no such thing! In fact, I have a lot of non-3D planes that will lift out of my hands, but I've only gotten one to hover longer than a second and that's a JPower P38 with differential thrust believe it or not. Give it lots of aft CG, full control throws, and enough thrust to accelerate vertically...then you'll be able to hover the sttiP
I think you'll be more than happy with it as-is. It doesn't need to hover, so long as vertical is unlimited. The sttiP really wasn't designed for 3D stuff anyway.
Although, come to think of it, the only aerobatic fs planes I've seen hover in airshow routines have been Pitts....maybe they're just predisposed for 3D maneuvers? |
United States, NC, Charlotte
Joined Jan 2007
Check this one out, the finish and engineering is much better than Stitts. Not sure how it flies been too cold and windy to maiden. Hope it flies as well the craftsmanship and overall design is much better
Tim http://www.rcgroups.com/forums/showthread.php?t=1749382 . |
Joined Jan 2007
Air frame is painted, and decals seem to be Stuck Down and may stay on. The attachments for wing struts is far superior to Art-tech. A bit smaller on wingspan but that is OK with me if it flys well. Landing gear is not much to brag about will need to Test it out a few times to see if it holds up. Foam seems stronger and finish is nice. Smaller prop so I believe that is reason for 4C. Tim |
First flight with the new dx6 was good!! Had it's expo set: Aile 100% / 35% expo Elev 65% / 35% expo Rudd 65% / 35% expo Love this clip, just makes me want to do some inverts ![]() ![]()
The sttiP is actually a good platform to experiment with expo, just to see what it does at higher and lower rates.
The video is of an Acrosport II, it's actually not a Pitts...but the market is pretty well over-saturated with tiny little biplanes like the Pitts and few of them make any significant departures from the Pitts they copied. Some are better than others, but the Starduster is a real POS unless you hang 300HP on the nose. |
Inverted flight sucks...it doesn't matter how tight you get those lap belts, when you start pulling negative G's it always feels like you're going to fall out of the stupid plane LOL
All the dirt and pebbles you brought into the plane via your shoes flies up into your eyeballs (and if it's a cropduster, most likely chemical-laden as well), your wallet and cigarettes fly out of your pocket and into the wild blue yonder, the tools you keep in that little pocket underneath the throttle quadrant hit the mag switch and kill the engine, and that drink that you just opened sprays all over the windshield further inhibiting your dirt encrusted vision (and if it's a cropduster, the seals on the hopper door don't work and spray chemical on the outside of the windshield too). Fortunately, the roll of paper towels you keep to clean the windshield off have anticipated the issue and are currently unrolling to fill the empty spaces of the cockpit and whipping around in an attempt to clean everything off. Of course, this is in addition to what happened on takeoff, where the left tire ran over a cow patty and covered your shoulder with steaming globs while the other one flings mud on your right shoulder, the top of your head smeared with blood and feathers from the dove you scared up and flew into the prop, and since there's a crisp wind blowing in the morning...snot running across your cheeks because there is no heater and you're wearing leather flying gloves. Ah yes, the thrill of an open-cockpit biplane... Now where was I....oh yes. The worst maneuver in aerobatics is starting into the box inverted for several seconds then immediately snapping to a 6G pull. During inverted flight the capillaries in your brain constrict due to excess blood, so when you start pulling positive G's not only does your heart have to pump your blood at 6G's, it also has to do it through restricted blood vessels. It's only impressive by order of the pilot's health and stamina, not so much visually... |
Hahahahahahahahahaha!!!!!
That was, BY FAR, the best post in this entire forum!
![]() ![]() ![]() You're a natural, Tex, and when all the mystery and magic of open-cockpit flight one day is no longer available to you, it will be time to write up all those favored memories of joy .I'm still snickering....... |
| Thread Tools | |
| Herr Engineering Pitts Special | crashnburn | Sport Planes | 9 | Aug 16, 2003 12:41 PM |
| Robbe Pitts Special | JeffD | Aircraft - Electric - Airplanes (FS/W) | 3 | Nov 13, 2001 06:29 PM |
| Herr Pitts Special rubber-to-electric conversion | mkirsch1 | Sport Planes | 11 | Oct 25, 2001 10:59 PM |
| Robbe Pitts Special | GMILL47 | Scale Electric Planes | 3 | Oct 03, 2001 09:15 PM |
| Herr Engineering Pitts Special | crashnburn | Sport Planes | 7 | Jul 05, 2001 10:06 AM |
