Go Back   RC Groups > Aircraft - Electric - Jets > Electric Ducted Fan Jet Talk
Old Oct 18, 2009, 01:27 AM   #61
deltas are cool
AIR SALLY's Avatar
sounds like the ducts need another layer of glass to stiffen them up for the dyna max fan .
AIR SALLY is offline Find More Posts by AIR SALLY   Reply With Quote
Old Oct 18, 2009, 03:28 AM   #62
Originally Posted by Ron101
Long Day Guys!
Dyn-E-Max Scorpion 630 KV on 12s 30c 5000 TP pro power packs
Throttle******Watts*******Amps*******pounds installed thrust
1/2*********(1650)*******(35)************(6 lbs 12 oz)
3/4*********(3100)*******(73)*************(10)
Full*********(4200)*******(98)************(12 lbs 6 oz)
Compared to the DS:
Ready to fly weight is 17 lbs 9 oz
DS-94 1521 2y on 12s 30c 5000 TP pro power packs
1/2*********(1680)*******(35)************(3.14)
3/4*********(2540)*******(56)*************(8)
Full*********(3950)*******(90)************(10.2)
Ron i have been following your progress on this and after seeing these numbers, you are starting to convince me to try my Dynemax fan in my Skymaster F-16, it goes very well on the current DS-94 1527-1.5y. im currently pulling 4500watts and if i could reduce that to 4000watts and still maintain performance or increase it slightly, then that would be a real winner. i think id have to make some mods to the intakes also, after seeing how you modded your intakes it might not be that hard after all.
Simon
EDF Crazy is offline Find More Posts by EDF Crazy   Reply With Quote
Old Oct 18, 2009, 09:59 PM   #63
20,000 Screaming Watts!
rvincent's Avatar
Well?
rvincent is online now Find More Posts by rvincent   Reply With Quote
Old Oct 18, 2009, 10:02 PM   #64
Well all I can say is WOW!
This fan has a lot of power! I guess to the ones flying it that's no surprise... but I'm shocked that a 20+ year old fan and outrunner can beat the snot out of state of the carbon fiber fan with an inrunner and sound so nice doing it.
The Dyn-E-Max is very smooth running and quite... right there with the Stu Max... but has a great deep growl. At full throttle the rush of air out the tail and in the ducts sounds amazing pulling vertical... that's something you just have to hear in person... but the video does pick it up some...
The numbers on the ground did show me something... that extra 3.5 pounds static thrust at half throttle is amazing... My A-4 flies very well at half throttle... (In fact in the video you hear my shock when I say "That’s half power") one could do a whole scale type flight at half throttle. Now that I can power back so much and fly well longer flights will not be a problem. I did two short flights today...3:00 and 3:30 on my timer. The first only brought the cells to 3.9 per cell and the second 3.85. Next week I'm going to set two timers...one for a scale 5:00 flight. The other more aggressive 4:00 flight. This gives me over a 1:00 on the DS setup... the vertical was very impressive, I pulled a huge loop which my bud missed (he caught some of it)
I'm so pleased with this setup... Being that this is a 2 pound fan and makes so much power it's a real winner. I thank Fred for the great setup...it has made a real believer out of me... in fact it has so much power I don't think 6500 mah pack would be a problem at all.. Maybe down the road I'll mess with it...
My friend Tom (helps me with video) couldn't make it out today... so my bud at the field helped out ... he has never shot video and did his best... the second flight a 3d plane took off right after me.. So we have to hear the glow engine
I'll open her up next time out... these flights are almost all 1/2 throttle except the vertical...
The second flight is still loading and will be up in an hour...
Here’s the first flight:
Tam Jets A-4 with Dyn-E-Max Scorpion 630 KV (3 min 44 sec)
Ron101 is offline Find More Posts by Ron101   Reply With Quote
Old Oct 18, 2009, 10:13 PM   #65
Sweet Ron nice flying
mavdriver is offline Find More Posts by mavdriver   Reply With Quote
Old Oct 18, 2009, 10:20 PM   #66
on a vacation
Nice. How would you judge the speed between this setup and the previous setup at the same throttle setting? As far as the dynamax having more thrust, that's a no brainer. It has always been known as a thrust fan. Did I hear flutter at about 2:30 in the video?
FlyRCJets01 is offline Find More Posts by FlyRCJets01   Reply With Quote
Old Oct 18, 2009, 10:22 PM   #67
Ron,
Very nice ! I can't wait to get mine installed in my YA F-4. We're hoping to keep the weight around 12 - 14 lbs. I've still got a lot of building to do, but I'm hoping for a couple of months max. If your's is any indication, it should go like a bat out of !
wrp7317 is offline Find More Posts by wrp7317   Reply With Quote
Old Oct 18, 2009, 10:25 PM   #68
Registered EDF abUser
kevin's Avatar
now you can see why i love the vertical in my 13lb 12oz hawk
I had a feeling you might like it....nice job
kevin is online now Find More Posts by kevin   Reply With Quote
Old Oct 18, 2009, 10:33 PM   #69
To fly as fast as the Dyn-E-Max at Half throttle I'd be a click under 3/4 with the DS
Kevin your plane must be so impressive in person.. videos just don't do these things justice
Thanks Guys
flight two will be up soon
Old Oct 18, 2009, 10:53 PM   #70
kevin's Avatar
you gonna bring that to E-Jets next year....
Old Oct 18, 2009, 11:04 PM   #71
150mph 90mm JHH COUGAR 3.5KW:D
corsair nut's Avatar
flys sweet ron!!! sounds wicked too.
corsair nut is offline Find More Posts by corsair nut   Reply With Quote
Old Oct 18, 2009, 11:13 PM   #72
you bet ... if it's still in one piece
one year for a RC Planes like seven...lol... like dog years
Thanks CN ... I'm really happy with the sound now...well worth the swap alone... I didn't even expect more performance that a bonus
Old Oct 18, 2009, 11:21 PM   #73
BladeRunner
Bronze Member
Nothing but the best!
Hi Ron,
Excellent flight and at half throttle, I'm impressed. Well done!
Mach .5, Maximum Efficiency.
Fred / Dyn-E-Max.com
  • Name: DSC01512.jpg
Description: The system, motor, controller, batteries. Everything must be properly matched! The system, motor, controller, batteries. Everything must be properly matched! 29.3 KB · Views: 87
bladexz2 is offline Find More Posts by bladexz2   Reply With Quote
Old Oct 18, 2009, 11:25 PM   #74
Gold Member
monkamarm2000's Avatar
Send a message via Yahoo to monkamarm2000
very nice ron! good job!
monkamarm2000 is offline Find More Posts by monkamarm2000   Reply With Quote
Old Oct 18, 2009, 11:34 PM   #75
Thanks Much Fred and Barry
Fred you make a great product
Flight #2 (with a glow plane pissing me off )
Tam Jets A-4 Dyn-E-Max 630 KV Flight #2 (4 min 20 sec)
Discussion Dyn-E-Max Ducted Fan bladexz2 Electric Ducted Fan Jet Talk 801 Today 07:11 PM
Discussion AMD / JHH HAWK - Dyn-E-Max kevin Electric Ducted Fan Jet Talk 87 Aug 28, 2009 09:46 PM
Video Cook F-4 / twin Dyn-e-max kevin Airplanes - Electric Videos 10 Aug 17, 2009 03:37 PM
Discussion Dyn-E-Max variable exhaust nozzle bladexz2 Electric Ducted Fan Jet Talk 10 Feb 04, 2009 02:39 PM
Discussion Tam Jet F-16 w/ Dyn-e-max Eagle15 Electric Ducted Fan Jet Talk 28 Jan 23, 2009 09:33 AM
Bored? Want to fight?
Join the RCGroups clan!
