Old Oct 14, 2009, 03:25 PM
MOfroggy is offline
Find More Posts by MOfroggy
East Texas
Joined Nov 2008
Motor numbers
How can I decipher all of the different numbers associated with electric motors?
Ex.: CF2805
2409-18T
2836-11
2836-22
4248-06
It seems like there is some reasoning behind the numbering system but I can't figure it out!
Joe
MOfroggy is offline Find More Posts by MOfroggy
Old Oct 14, 2009, 03:38 PM
Ken Myers is online now
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
While the motor numbers usually have some significance for the manufacturer, different manufacturers use different numbers.
The two most significant numbers when comparing motors, and I assume that is what you might want to do, is motor weight and Kv, even if you don't know what Kv means.
Ken Myers is online now Find More Posts by Ken Myers
Old Oct 14, 2009, 04:11 PM
HappyKillmore is offline
Find More Posts by HappyKillmore
Brunswick, OH
Joined Nov 2005
In those examples, the first number is the motor's diameter. The second number is the length. The last number is the Kv rating. IE 12 = 1,200 kv. That's the motor constant.
IE: 2836-11
Diameter: 28mm
Length: 36mm
Kv: 1,100
Typically, the numbers thatare missing (for me) are the Max Amp draw which is really what you need to know to keep from smoking your motor and the motor weight.
Not all manufacturers use this numbering format. But it does help a little when they do.
HappyKillmore is offline Find More Posts by HappyKillmore
Reply With Quote  (Disabled)
Old Oct 14, 2009, 04:46 PM
Xpress.. is online now
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
^Well, the most important numbers would be Kv, Diameter, and MAX amps. From there, you can select a motor for a specific plane
Xpress.. is online now Find More Posts by Xpress..
Old Oct 14, 2009, 08:01 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
You need to know max amps and max volts as well. Alternatively you need to know max watts, but there is no standard for any of these measurements -- some manufacturers will give a conservative value, and others will inflate their numbers.
A "peak" power rating is of limited value. What really matters is the continuous power rating.
A general rule of thumb is 100 watts per ounce of motor weight. And if anyone knows of significant deviations from that rule, I'd be interested.
rafe_b is offline Find More Posts by rafe_b
Old Oct 14, 2009, 08:14 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
IE: 2836-11
Diameter: 28mm
Length: 36mm
Kv: 1,100
I don't believe those numbers represent the same thing for every motor type or manufacturer. For instance...
What does 2212-6 mean?
Size: 27.8 mm x 31 mm
Kv: 2200 RPM/V
What does 2212-13 mean?
Dimensions: 28mm x 30mm
Kv: 1000
Bombay is offline Find More Posts by Bombay
Old Oct 14, 2009, 09:23 PM
Mayday!Mayday! is offline
Find More Posts by Mayday!Mayday!
Check my blog-updated
Mayday!Mayday!'s Avatar
Columbus,Ohio
Joined Nov 2005
Another example is Mega motors. Thet don't use the outside dia/length/turn.
They use the inside rotor #'s like this--
ACn16/15/3 is a 16mm diameter rotor X 15mm length rotor with three turns of wire per pole
Mayday!Mayday! is offline Find More Posts by Mayday!Mayday!
Old Oct 14, 2009, 09:29 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
This is another non-standard in the industry. Just like balancing taps on batteries.
Sure wish companies would have standardized this for us.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Oct 14, 2009, 09:30 PM
MOfroggy is offline
East Texas
Joined Nov 2008
Motor Grams
What does it mean when the motors are referred to in "grams" Like one post I saw said "don't use larger than a 20 gram motor".
Old Oct 14, 2009, 09:33 PM
Columbus,Ohio
Joined Nov 2005
It means don't use a motor that weighs more than 20 grams or 0.70 ounces
Old Oct 15, 2009, 06:01 AM
Ken Myers's Avatar
Joined Aug 2001
IE: 2836-11
Diameter: 28mm
Length: 36mm
Kv: 1,100
Sorry Happy, your description is incorrect for most motors, and shows why the "numbers" by themselves mean very little.
When you see numbers after the - (dash) as in your example that are one or two digits it is the number of turns.
So someone's 2836-11 would indicate an 11-turn motor and a 2836-6 would be a six turn.
Some other manufacture might have a 2830-850 or 2830-1100. If it is a three or four digit number following the size designation (which varies by manufacturer) it is the Kv.
Old Oct 15, 2009, 04:19 PM
Xpress..'s Avatar
Joined Oct 2007
For seeing what the numbers mean, a good manufacturer will give you a guide, like ElectriFly, or Himax motors
Old Oct 16, 2009, 11:47 AM
Brunswick, OH
Joined Nov 2005
As near as I can tell this 2212-6 is using it's own crazy numbering system (which is not really that suprising). Maybe it's 22 for 2,200 kv, 12 for 12V? and 6 for 6 turns?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=110419964998
EDIT: Nope, this doesn't follow
http://cgi.ebay.com/RC-1500KV-Outrun...item1c0d326b59
There is no rhyme or reason to this mfg's numbering system.
EDIT2: Here's one that is diameter, length, # turns
http://cgi.ebay.com/RC-750KV-Outrunn...item1c0d38384a
Microtex Motor numbers GBR2 Power Systems 2 Mar 25, 2004 05:11 PM
mega brushless motor Numbers.. tomi Power Systems 19 Oct 23, 2003 09:47 AM
GWS 300 motor numbers tygerman Power Systems 0 Aug 16, 2003 10:34 PM
What do the Brushless motor numbers mean? pohlmeyr Power Systems 12 Dec 08, 2002 11:29 PM
mabushi ferrite motor numbers Harry Mueller Parkflyers 2 Jul 07, 2001 12:55 AM
