Old Oct 13, 2009, 11:53 PM
RCFUN12 is offline
Find More Posts by RCFUN12
Joined Sep 2005
90 degree servos arms
How is everyone adjusting their servo arms to 90, are you guys just eye balling or use some type of tool?? What is the best way?
RCFUN12 is offline Find More Posts by RCFUN12
Old Oct 14, 2009, 12:07 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
After finding the arm that will get closest to 90deg I use Sub-Trim.
1320fastback is offline Find More Posts by 1320fastback
Old Oct 14, 2009, 04:57 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
You should find that depending which way round you put the arm on the servo, it lines up better one way than the other.
To explain that a bit better, (if my memory is correct), there is an odd number of splines on the servo shaft and arm, and if you have a servo arm that has an arm out each side try it, then take it off, turn the arm 180deg and try again. Quit often it will line up better one way round than the other. (Ok so that may not have been any better )
If you have a spare servo output with four arms, try it in the four rotations, (90deg), to see the difference.
If you only have single arm ones then I eyeball, plus have the greater movement side to the control I prefer.
Another explanation ? , ask and I'll do a drawing, it's easier.
eflightray is offline Find More Posts by eflightray
Old Oct 14, 2009, 05:28 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Here's the better explanation of that last statement.
It's basically differential movement. Often used for ailerons where more up movement than down is required. Similarly it can be used on elevator where you may want more up than down. Though it's not a lot of help on rudder .
So the arm doesn't have to be exactly 90deg, a few degrees in the right direction can help.
Anyway here's the picture.
Old Oct 14, 2009, 07:19 AM
Mode One is offline
Find More Posts by Mode One
Closed Account
Joined Dec 2006
Simply put, I get it as close as I can and then don't worry about it.
Mode One is offline Find More Posts by Mode One
Old Oct 14, 2009, 07:41 AM
TomCrump is online now
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
That idea has worked for me, for over 20 years.
TomCrump is online now Find More Posts by TomCrump
Old Oct 14, 2009, 08:02 AM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Assuming you are trying to simply get the arm at 90 degrees to the servo case, and you want an equal amount of throw in each direction, then see this mini-tutorial on how to use sub-trim to dial in the servo. Also, make sure you don't dial in too much sub-trim, as you can overdrive the servo by doing so.
Using Sub-Trim to set servos at 90 degrees
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Oct 14, 2009, 11:52 AM
Mode One is offline
Closed Account
Joined Dec 2006
Chuck
Chuck, 90 degrees to the servo case accomplishes nothing. It's more important to have the servo arm 90 degrees to the pushrod travel and I think this is what the O.P. was talking about.
Old Oct 14, 2009, 11:59 AM
Joined Jul 2006
But if he learns how to use the case as a reference point, then he has learned how to set the arm for any angle from 1 degree to 360 degrees; since the process is exactly the same, right?
Chuck
By the way, if that's what you think he wanted to learn, then why, pray tell did you just tell him to set it close and not worry about it if it's important to have the arm at 90 degrees?
Discussion DX6i monitor and 90 degree servos WyDiablo Mini Helis 2 Sep 28, 2008 07:09 PM
Question Any servos with 90 degree rotation? topforce Radios 8 Oct 27, 2003 10:01 PM
Logo 10 and 4 servo, 90 degree CCPM Fred Bronk Electric Heli Talk 17 Dec 26, 2001 03:58 PM
90 degree CCPM on Hitec Eclipse! Jon h Electric Heli Talk 2 Nov 24, 2001 10:02 AM
TX with 90 degree ccpm? rcastab Electric Heli Talk 26 Jul 23, 2001 10:41 PM
