This thread is privately moderated by PMB-NZ, who may elect to delete unwanted replies.
Old Oct 13, 2009, 09:27 PM
PMB-NZ is offline
Find More Posts by PMB-NZ
PMB-NZ's Avatar
Wellington, New Zealand
Joined Aug 2009
Double check before flying
On the back of my transmitter I have a slide switch that sets the RF output to normal or low power. I installed this ages ago for testing antennas, receivers and installations so that I didn't have to walk 100m for each test. On the low power setting with the TX antenna half collapsed the range is 5m good to 8m nothing.
Before flying I check the switch is in the up (high) position. But a few days ago my check failed and I launched the plane with the switch set to low with the TX antenna fully extended. The plane flew off as planned and at about 100m out and 30m up I started a gentle left turn. It didn't feel right; the plane was very sluggish to respond but otherwise seemed OK. I thought maybe a servo problem and continued the turn to head back. After landing and checking the control surfaces again, I found the switch was set to low power.
I wouldn't have done this test deliberately as it's too high-risk and I wouldn't expect more than 50m or so. I was pleasantly surprised it worked out past 100m and that loss of control was minimal and gradual. A lucky save.
PMB-NZ is offline Find More Posts by PMB-NZ
Ideas Needed so I can Double Check Plane before 2nd Attempt "crash" JIMJAM Parkflyers 22 Oct 14, 2003 05:27 PM
Battery Check Before Lift-off........ fred420 Batteries and Chargers 4 May 22, 2003 07:46 AM
Night flying? Make sure you double check your lights! eBird Parkflyers 18 May 04, 2003 02:06 AM
555 extra channel ,double check please Bob K Radios 5 Nov 12, 2002 09:55 PM
Twas the Night Before Flying... Slow Riser Power Systems 1 May 27, 2002 05:31 AM
