Yeah it was the angle of the pic I think. I just flew it and got it down to waist high inverted. It was 34 degrees and my hands were too cold to go any lower. Low inverted flight, flips, and rolls is about the extent of my 3d ability. Been working on piro flips on the sim...man that has my brain working over time! So now that it is flying well, hopefully I can have fun with it for a while. It's had its share of bugs but I am glad I got it and I am happy with it.
Brian Quote:
Tumbler, If I'm mistaken, there have been 2 other people complain of the black Hobbymate frying. Either on this thread or the EXI 500 thread. I have the red hobbymate but have not tried it yet (it's a spare). I have seen several others with red Hobbymates fly to sucess. We got ours from Dealextreme.
Did you blue-loctite those tail screws? all of them? |
Yeah I have heard a of someone havign a prob with the motor. I wasn't aware there was a difference between the 2 colors as far as quality. I think I will play it safe and just get somethign else.
I did take the whole taile case apart and loctite everything. Even so, I just looked it all over and a couple wiggled loose. I will have to add some more. Brian Quote:
WOW, I have waaaaaay too much negative! I forgot to adjust the curves after I added the longer servo arms. I probabaly have 14-15 degrees now! You can see how touchy it is when it is inverted from the videos. It makes it very hard to hold a steady altitude. I will have to tweak it.
COUPLE SHORT VIDS
Brian |
HAHA, thanks man. I had a .30 size heli about 8 years ago before I started jets.
I just flew it again after adjusting the pitch curves and it is way better. I just reduced the amount of negative around the 1/4 throttle position. It was like adding expo to the pitch control and is perfectly stable in an inverted hover now. Brian |
No not that one, but as some small help I can say the CC Phoenix 25 and 35 I've been using on 450's works very very well in gov mode. Setup is easy with the USB link dongle too, as is any firmware updates.
I bought a Phoenix 60 for my HK-500GT but not used it yet (or the heli). Martin |
CC ESC's probably have the best and most reliable governor mode for heli's, though on most electric heli setups a governor should not be necessary. Governor's play a more significant role in Nitro-powered heli's.
A brushless heli motor (inrunner or outrunner) will operate at its best efficiency at 100% throttle, so if you select the appropriate pinion size, battery, and motor Kv, you should be able to achieve optimal head speeds at 100% throttle while being able to tweak the throttle curve in your radio for optimal climb-outs at full negative/positive pitch. |
It's a great heli though, and it's even better to see your videos posted in the thread showing off what this bird is capable of doing on mainly stock parts using reasonably-priced electronics.
Thank you! I got it so its not so bouncy now after fixing the pitch curves. When flying anything I kinda have a no fear attitude which helps me learn things faster but need to repair a alot more too haha. I use the sim to get the muscle memory down so its instinctive but you are right, you still have to overcome wthe fear of doing it with the real thing. When learning anything new like nose in or inverted I just go ahead and do it but keep an out for myself. For nose in I am ready to punch the throttle if I am in trouble and full negative if I am inverted and get in trouble. I am working on nose in inverted now and no matter what happens, I know if I just remember to punch full neagative, then I have a chance to save it.
You are right, this thing can do pretty mch anything an intermediate pilot wants, usuing basic stuff. You can't go any cheaper than I did and it still does a lot of stuff. I ripped it around hard today in fast forward flight and really yanked it and she held together. I am upgrading to metal arms though. Brian Quote:
| Thread Tools | |
| I got some Fan Fold what to build thread part II started by emoone!!! | Don Sims | Foamies (Kits) | 188 | Jan 23, 2010 08:28 PM |
| Mountain Models Tantrum Partial Build Thread.. | Tram | Parkflyers | 142 | Apr 03, 2004 10:41 PM |
| My Bobolink Build Thread (very Colibri like) | Jim Poor | Hand Launch | 65 | Dec 10, 2003 04:48 PM |
| Laird Super Solution Build Thread! | boomerace | Parkflyers | 178 | Oct 29, 2003 07:20 PM |
| Switchback re-build thread (or What the $#*& was that!) | Biggles604 | Parkflyers | 17 | Jun 23, 2003 09:34 PM |
